Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
09-16-2021, 04:27 AM | #15 | |
Drives: 2013 Toyota 86
I'm finding it really hard to believe it's rod knock as the car has had the recall done 20.000 miles ago and has had zero issues. If not a blocked oil passage what else could cause rod knock? Also the car has had a new short block replacement at around 40k miles, now the odo reading 70k miles. |
09-16-2021, 11:47 AM | #16 |
Drives: BLue 2013 frs
do you know where in the engine bay that sound coming from? have you got someone else to turn on the car while you record/watch/listen to where that sound is coming from? It might narrow where the issue is coming from, or it might not, probably wouldn't hurt to check, though.
09-16-2021, 12:49 PM | #17 | |
chicken tonight
Come to think of it, @Opie mentioned something about the timing chain tensioner preload being critical. If not preloaded enough, the chain slaps until it pumps up. I think that's only potentially an issue after a reassembly. Seems like an outside shot but might as well mention it.
09-16-2021, 01:39 PM | #18 | |
09-16-2021, 01:40 PM | #19 | |
I will be changing the oil soon to 5w30 anyway. |
09-16-2021, 02:49 PM | #20 | |
Drives: 2015 FR-S
Worn timing chain? tensioner needs to take up more of the slack until oil pressure meets amount of slack needed to be taken up.
OP how many miles on the engine Quote:
The Following User Says Thank You to FrickingReallySlow For This Useful Post: | Ultramaroon (09-16-2021) |
09-16-2021, 03:50 PM | #21 | |
chicken tonight
Let us know! If I'm wrong, then we can put that info into our collective forum knowledge base. edit: Used Oil Analysis will clearly show elevated soft journal metals if one is scuffed.
Last edited by Ultramaroon; 09-17-2021 at 03:14 PM. Reason: Realized after review that I had my terms backward. |
09-16-2021, 03:58 PM | #22 |
Drives: Crapcan
A UOA will help tell you if it is the rod bearing. Should be showing excessive amounts of material. Bearing can be bad without being spun.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (09-17-2021) |
09-17-2021, 05:05 AM | #23 | |
I was already planning a UOA and ordered a Blackstone kit a while ago. I'll keep you guys updated on my findings. |
The Following 2 Users Say Thank You to Sniepster For This Useful Post: | Dzmitry (09-17-2021), Ultramaroon (09-17-2021) |
09-17-2021, 10:21 AM | #24 | |
Drives: 2018 Subaru BRZ Limited with PP
Or is this because you are saying he already has some kind of damage and therefore slowing down oil flow in some way? |
The Following User Says Thank You to Dzmitry For This Useful Post: | Ultramaroon (09-17-2021) |
09-17-2021, 10:59 AM | #25 | |
I am also quite perplexed as to how would this happen. It is 5w40 after all, not a thick-ass 10w60 racing oil. And i find it weird the issue has started happening during the hot summer months (when the oil is already warm and should flow quite well) and not during the freezing temps in winter. |
The Following User Says Thank You to Sniepster For This Useful Post: | Ultramaroon (09-17-2021) |
09-17-2021, 03:08 PM | #26 | ||
chicken tonight
The problem with worn bearings is that the gap is wide enough to allow the cyclic loads to overcome the boundary. We get that hammering effect. That's where it all goes to shit.
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
09-17-2021, 03:26 PM | #27 |
chicken tonight
Another correction before I get slammed. Boundary lubrication isn't necessarily only for cases where relative motion is slow. It's just that the lubricant must be able to withstand the heat generated from being worked.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Dzmitry (09-17-2021) |
09-17-2021, 09:14 PM | #28 | |
I had this sound on my shitty old Mazda6 back then. Slightly for a different reason which is why your explanation confused me a bit at first. I was well aware of what the sound was of course. I had bought it used and didn't know any better as I was young. But the engine already had leaky head gaskets. Minor for some time but that developed into major within a year. I was adding 5 quarts of oil per week at one point. But in my case, it was because the oil was leaking out so quickly, and sometimes I would get down to probably a couple quarts before I added a bunch more. When it would get very low, that was the sound I experienced. Always cringed and drove like a baby when it would happen. It was amazing how many times I got it to happen though, and that engine still lasted some how. I probably drove like that for several months before finally finding another car and selling this one off. The car sat for a while before I sold it. I got it to start when a guy came to check it out, and that sound came on for a solid 5-6 seconds on the initial start lol. Then it calmed down and it was good. He was like oh that's not good! I told him it had an oil leak and he will need to be topping it off with oil. Didn't tell him how much But I sold it for like 300 so I wasn't trying to screw him over haha. On a rant here... anyways the reason I brought up the story is because I didn't think there would be any lubrication issues unless the oil was low enough or something. Didn't know that wear on parts would cause the oil to actually lack flow. But the more I think about it, it's kind of obvious and makes sense. |
Similar Threads | ||||
Cold cold(under 30dg) start sounds super weird | vladniko86 | Engine, Exhaust, Transmission | 9 | 11-19-2020 09:08 PM |
Question about cold start knock, battery | radroach | Issues | Warranty | Recalls / TSB | 24 | 12-17-2016 08:24 AM |
(Spark?) Knock on cold start idle | nickw14 | Software Tuning | 0 | 04-07-2015 12:41 PM |
LOUD KNOCK during cold start | Flat_4_Life | Issues | Warranty | Recalls / TSB | 23 | 03-18-2015 05:30 PM |
White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
