Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-11-2021, 04:16 PM | #1 |
Drives: turbo frs
Ej20x swap frs
Dear
I have project FRS I had finished fab every thing and engine now ready But I need help to connect ej20x ecu to FRS ecu To start and run odometer Thnx in advanced.. |
09-11-2021, 04:50 PM | #2 |
friendly
Drives: 17' 86
Why?
Seems like the ej20 will have the same issues as the FA20 with non of the perks (direct & port injection)
Seek comfort in discomfort.
09-11-2021, 11:02 PM | #3 |
Drives: turbo frs
Why!!
Because fa20 damage 2nd time because of bad oil pump .. First time 47mil 5w30 oil Here engine price much expansive Ej20x can found full part at cheap price .. |
09-12-2021, 05:51 AM | #4 |
LMGTFY
Drives: 13 FRS, 91 Miata
You will need a full standalone system most likely if you want everything to work.
All in your already probably at the cost of 2 more OEM motors. Sorry to say its you or whoever is tuning/building your engines not the FA20 that's at fault here. |
The Following User Says Thank You to x808drifter For This Useful Post: | alphasaur (09-12-2021) |
09-12-2021, 10:02 AM | #5 | |
Drives: turbo frs
Thnx bro Fa20 used one cost Herr 2k All fab and used ej20x my friend spent around 1300$ I told him better to use standalone ecu .. Good thing not Alfred of bad oil pump With good hp around 286hp stock motors So now way to connect fa20 to ej20 ecu?? Thnx again |
09-12-2021, 12:11 PM | #6 |
Drives: JRSC BRZ SOLD
Custom harness and or standalone ECU.
09-12-2021, 01:09 PM | #7 |
Rust bucket enthusiast
Just to throw it out there... If you had engine failure and reused your timing cover, you're doomed to repeat failure. The oil pump gets compacted fragments in it.
Nothing inherently wrong with an EJ20X swap, but it's going to be so much work for possibly nothing. I can't fathom how this would work without investing as much as any other engine swap.
Similar Threads | ||||
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
Nav swap | Dadillac | Electronics | Audio | NAV | Infotainment | 4 | 10-21-2018 05:36 PM |
Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
LQ4 V8 Swap | nmctacticz | Engine Swaps | 42 | 05-02-2017 04:24 PM |
