08-18-2021, 09:30 AM | #169 | |
TRACKBREAD
IIRC correctly it was specifically mentioned in the Japanese comparison thread that the rear subframe was less tight to the body to encourage toe-out under compression. The toe arms are mounted to the subframe so letting the subframe rotate around the Z axis could provide a similar effect without having to make different toe arm assemblies for the Toyota. I’m so curious to see the front suspension of those cars they had. |
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | timurrrr (08-18-2021) |
08-18-2021, 09:43 AM | #170 | |
Drives: 2016 Subaru BRZ
In the Throttle House video it seems that good tires would make up the difference on the track considering a 1G had a better time. The camera man has an FRS and ran a "low 1:15" compared to the 1:15.90 of the 2G. I would have liked to see them do a drag race between the two. |
08-18-2021, 09:55 AM | #171 |
Drives: Some rust bucket
really comparing apples to oranges.
i would like to see lap times from pobst in showroom spec (factory tires) on a real race track. i'm not a fan of trying to equalize the cars with the same tire spec. |
08-18-2021, 10:21 AM | #172 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
08-18-2021, 10:26 AM | #173 | |
Drives: 22 BRZ
Thanks to Paul at TFL for getting the info.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
08-18-2021, 10:29 AM | #174 | |
Toyota is quoting 6.1 seconds for this new one. Magazines should be able to get that down to the mid 5’s or better with a similarly aggressive launch. Jason Camissa has already said he’s done an “easy” 5.6 seconds with the new one.
2022 BRZ Build 2013 FR-S Build |
08-18-2021, 11:00 AM | #175 | ||
TRACKBREAD
GR86 first drive reviews thread
Fair, the geometry doesn’t technically change, it’s the thrust axis. It can provide a similar corner entry effect though, provoking the car to step out. Quote:
Follow up: I did a quick scrub on YouTube and managed to find a shot where the top of the front knuckle peeks above the brake disc. It was confirmed further in the thread these are aluminum. Brz knuckle for reference: Last edited by Yoshoobaroo; 08-19-2021 at 02:06 PM. |
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post: |
08-18-2021, 11:53 AM | #176 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
I think that what the journalists said was the upgrade was pretty clear. They drove them back to back (the TRD updated version too). |
The Following User Says Thank You to Blighty For This Useful Post: | Dadhawk (08-18-2021) |
08-18-2021, 11:58 AM | #177 | |
Also the new integra coming out! |
08-18-2021, 12:00 PM | #178 |
All of this strangeness and we dont even know what size swaybars those cars were running!
The Following 2 Users Say Thank You to RZNT4R For This Useful Post: | Pete (08-18-2021), Yoshoobaroo (08-18-2021) |
08-18-2021, 12:36 PM | #179 |
Drives: 2013 Scion FR-S Series 10
Saved?
Matt Farah found his footage, I guess. |
08-18-2021, 12:51 PM | #180 | |
Drives: 2022 GR86
Almost nobody does time trials on stock tires, and only "spec" classes designed to be beginner friendly run 215s. Why should results of performance tests depend on what comes from the factory? What if I buy a car in winter and it comes on winter tires? |
08-18-2021, 12:53 PM | #181 |
Drives: 2022 GR86
On our cars, the tires only really matter for the first few feet of a drag race. In the TH video, the 2nd gen was clearly pulling away more and more as the speed increased.
08-18-2021, 12:58 PM | #182 | |
but i still prefer to see lap times with 0 modifications/straight in showroom spec. the data is too messy when you start modifying the car. |
Similar Threads | ||||
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 37 | 07-18-2021 03:38 PM |
Real World MPG | Be-Are-Zee | BRZ First-Gen (2012+) -- General Topics | 302 | 07-13-2014 03:06 PM |
Full Report: Road & Track tests stickier FR-S/BRZ tires | poormans_LFA | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 74 | 08-15-2013 01:10 AM |
