Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 05-13-2021, 08:30 AM   #15
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by TommyW View Post
It’s like why not put a decent engine in for replacement. Why stick with a Subaru, especially if you have an FRS or 86.
Maybe trying to keep the low center of gravity? Tim Schrick is participating in the VLN Endurance Racing Nürburgring championship and he replaced the engine with an older EJ20 motor. This year replaced it again with a six-cylinder EG33 motor.
https://www.motul.com/de/en/news/eve...z-in-the-world
Old 05-13-2021, 09:46 AM   #16
Ernest72
My thought was you blow an engine and if the swap was easy you just put the new one in. If it was as complicated as putting any engine in there, then there may be better options. Keeping the lower center of gravity and lightweight would be important to me. No LS swaps for me. Sounds like if my engine goes I just put a similar one in.
I had not seen anyone mention it so I figure let’s throw it out there and let the greatest minds on the internet figure it out.
Old 05-13-2021, 11:18 AM   #17
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Yes the CG is important however I THINK the Honda motor is lighter which may cancel out the higher CG of the motor.
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
nikitopo (05-13-2021)
Old 05-13-2021, 05:45 PM   #18
T-Steve
Drives: 2014 BRZ
I'm in on a FA24 swap when it becomes viable. I'm too old for exhausts, rumble, and edgy motors.
When a drop-in FA24 is available I'll have funding ready.
I'm hoping that I can take a bare FA24 long block, swap over all the sensors/injection/etc., and RUN IT (with a tune and maybe bigger injectors).
In a year or two...
T-Steve is offline   Reply With Quote
Old 05-13-2021, 06:26 PM   #19
Tokay444
Anti stance.
Tokay444's Avatar
While the engine itself has a low centre of gravity, it sits very high in the engine bay. If I remember correctly, the K24 swap actually lowers the COG because they can lower the entire engine.
Old 05-13-2021, 07:15 PM   #20
Jordanwolf
Rice King
Jordanwolf's Avatar
The Honda K24 looks like a better option.
This guy knows.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 05-13-2021, 07:26 PM   #21
In a year or two...
Even going from the pre 17 to post 17 engines is not as simple as that.
The FA24 will never be a straight drop in swap. This is the same as people that figured they could just drop in the EJ engine and found it just wasn't going to happen. The one Niki mentioned earlier and one other were the only swaps I ever recall hearing about.
Besides if you are too old now you will be positively ancient by the time the 24 will come down in price to even make it a reasonably cost effective swap. Gotta wait for the kids to wreck a bunch first.
NoHaveMSG (05-13-2021), soundman98 (05-13-2021)
Old 05-14-2021, 12:24 AM   #22
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I don't think you can have a lower COG with engines other than a boxer. It not only about how much low or high the engine sits in the bay. It is about the overall height of the engine and of not being top heavy. The main advantage of a K24 swap would be its higher power output and lower weight, so you would have also a bit better front to rear weight distribution with the expense of a bit worse COG. I believe K24 weights around 413 lbs. (including transmission), while FA20 is in the range of 480 lbs.
Old 05-14-2021, 08:18 AM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
The benefits of a boxer engine giving a lower c.g. is usually somewhat overstated. They end up sitting quite high at the crank for exhaust clearance. This puts the engine's heavy bottom-end structure and crank, as well as the flywheel, clutch, and the front half of the transmission a good 2-3 inches higher vs. typical inline and V engines. I'd give the nod to a V-configuration for best low-c.g. potential, then flat, then upright inline, but I think there's not nearly as much in it as marketing suggests. Also, the flat FA20 in our cars sits *way* forward apparently for steering-shaft clearance, contributing to craptastic 55/45 weight distribution.
I would bet a low-mounted K-swap FT86 would have overall c.g. height close to stock (maybe 1/4" higher), while being ~100 lb. lighter (KPower's is 140 lb. lighter, supposedly "like vs. like") and with ~2-3% better F/R distribution.
I'd rather have ~2700 lb. Kswap with 52.5/47.5 weight distribution and (pessimistically) 18.5" c.g. height vs. 2800 lb. FA with 55/45 distribution and 18" c.g. height.
What would be interesting would be a low- and aft-mounted compact V4...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
NoHaveMSG (05-14-2021), Tokay444 (05-14-2021)
Old 05-14-2021, 12:10 PM   #24
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Not sure how the lower c.g. of a boxer engine is overstated, if twins managed to have one of the lowest numbers of the segment. How come that typical inline and V engines don't have better figures? I wouldn't trust much statements of tuners like Kswap . These guys don't have the restrictions of a road based car, like being safe and not end up killing you in a front collision event. So, they can move transmission as far back as possible by simply ignoring crash zones and the like. I would never trust such engine swaps and the only way I would have one is if I had a race dedicated car that I could transport between race events using a trailer .
Old 05-14-2021, 12:38 PM   #25
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
And the GM LS is an even better option.
Originally Posted by klearfade View Post
Is that gel in your hair?!
Originally Posted by HueyLooie View Post
Nah, homes. It's your dadda's hot goopey goop.
Old 05-14-2021, 12:39 PM   #26
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
i'm sure someone in japan will have a swapped one within the year ^^
HKz is offline   Reply With Quote
Old 05-14-2021, 12:54 PM   #27
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Someone will wrap the new one around a pole, put it into a curb or otherwise cause it to be totaled.
Then someone will buy the car and pull the engine.
I give it less than a year.
Old 05-14-2021, 12:54 PM   #28
KR-S
Sporadic Member
KR-S's Avatar
Most likely, and we'll probably have some people in the US swapping in an FA24 into their first-gens not long after.
However, you know what I'd actually like to see, no joke? The GR Yaris G16E-GTS three-cylinder. It's small as hell but already makes more power than the upcoming FA24 let alone the current FA20 in our cars.
The Following User Says Thank You to KR-S For This Useful Post:
HKz (05-14-2021)
Looking for previous owner MasterBandit Southern California 3 11-04-2019 11:13 PM
Your previous car. EzyBrzy Northern California 37 12-06-2015 02:34 PM
What do you do in your FRS/BRZ that you never did in your previous cars? Thehermdawg FR-S / BRZ vs.... 17 05-23-2014 01:35 PM
Sure the FR-S is awesome, but do you miss your previous car? Frs x3 Other Vehicles & General Automotive Discussions 132 05-20-2014 02:28 PM
Any previous Miata owners out there? x96nax Tracking / Autocross / HPDE / Drifting 26 07-27-2013 07:29 AM
