Forced Induction Turbo, Supercharger, Methanol, Nitrous |
04-01-2021, 03:43 AM | #1 |
Whats next?
Drives: '13 Asphalt FRS MT
Tuner says wastegate spring is too tight..help please!
I know there’s a JDL specific thread however I’m hoping to reach out to anyone that could help me troubleshoot where my problem might be.
Here’s everything performance oriented installed for reference: JDL v2 turbo kit w/ gtx2860r Turbosmart wastegate w/ a 7psi spring (here is my confusion) Dw 700cc injectors Walbro 485 fuel pump Delicious tuning flex fuel kit Delicious tuning 3port boost solenoid Omni 3 bar map sensor Dyno Tuned with ecutek Alright guys so I’ve had my car tuned a little over a month now, my tuner told me my wastegate spring is too tight and that I need to loosen it. I know wastegate springs are set values so I’m confused as to what he means. In the JDL thread some mentioned adjusting my bov, which I did but when reading on turbosmarts website this is more so to have your piston closed at idle properly and open properly. This did help solve the rpms dropping below idle which was something that was irritating me so glad that was solved. so if my spring is rated as 7psi shouldn’t my setup be able to have a minimum of 7psi- to about 14psi of range especially since I’m using the 3 port boost solenoid. When I go into the ecutek connect app my atmospheric pressure (from what I understand is my boost pressure) is stating 13psi. I do not want this much boost I was only wanting 8-10psi which is what my tuner tried to achieve but clearly something isn’t allowing him too do so. Does anyone have some ideas for me to start troubleshooting with? All thoughts welcomed I really want to get this figured out so I can actually drive my frs and have some fun with and not just having it sit in the garage everyday. If you need any more info just ask me!
Life is too short to drive a boring car...
Instagram: @angelb_af |
04-01-2021, 07:48 AM | #2 |
Rust bucket enthusiast
We tried to help before, you have to find another tuner. This person is obviously just dumb, or doesn't want to tune your car. The wastegate spring cannot be too tight. Do they understand how wastegate duty cycle works?
It'd be neat if they could give you the map file so we can look at it and see what looks wrong.
04-01-2021, 10:00 AM | #3 | |
Whats next?
04-01-2021, 10:40 AM | #4 | |
LMGTFY
Drives: 13 FRS, 91 Miata
The Following User Says Thank You to x808drifter For This Useful Post: | DarkPira7e (04-01-2021) |
04-01-2021, 12:00 PM | #5 |
I wonder if they mean the pressure FROM the spring is too tight? Like "you need to use a weaker spring"
04-01-2021, 12:32 PM | #6 |
Whats next?
Maybe there’s a reason I’m not. Try rephrasing your comment next time so that you don’t come off as an asshole. I wouldn’t be here asking other people if I haven’t already tried the most obvious route. I will say I remember why the forums aren’t much help either because of comments like these. I am dumb for thinking I’d receive a better result from some people in this community.
04-01-2021, 02:29 PM | #7 | |
LMGTFY
Trust me, I do not care if I come off as an a-hole. You said you were confused by what he meant by loosening the wastegate spring. Didn't say anything about you asking him to clarify what he meant and what answer he gave you. So I assume you didn't bother asking what they meant and went straight for a 2nd opinion. This is how troubleshooting works. Start small and easy and work your way up. If loosen the wastegate spring was the clarification and the tuner couldn't get more in depth about it, YES 100% what DarkPira7e said. G.I.G.O. |
04-01-2021, 03:21 PM | #8 |
Drives: 2014 BRZ Limited, Satin White Pearl
Just noticed you are looking at atmospheric pressure.
Talk with your tuner. They can show you which value you should be looking at.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
04-03-2021, 06:20 PM | #9 |
He is probably talking about preload on the spring? Yes you can reduce that by shortening your waste-gate rod. The ECU reports absolute pressure you have to subtract your pressure of the day to get boost. Standard day at sea level is 14psi. Your number will vary due to altitude, temp and barometric pressure.
The Following User Says Thank You to Grady For This Useful Post: | FRS_FIEND (04-18-2021) |
04-08-2021, 08:03 PM | #10 | |
Drives: Q5 + BRZ + M796
In the above scenarios, the tight spring that holds its position until the last possible minute can be susceptible to boost spike. I don’t know if this is what the OP is experiencing, but it might be. Over-boosting is either a boost creep issue, which is unlikely because this is an off-the-shelf kit. The other possibility is not having the vacuum lines hooked up correctly to the EBC. The other possibility is having a boost leak on the vacuum line. The other issue is setting up the EBC to force the wastegate closed until the last possible second, which is like having a stiff spring.
04-09-2021, 12:14 AM | #11 |
Drives: brz 2017 hksv2
i haven t understood why OP is looking at the value if atmosferic pressure to see the boost..
Atmosferic pression is atmosferic pression and nothing else Did the tuner say to you he relocated somehow the value of atmosferi presure to show the Manifold Relative Pressure? Still no logs in this thread. |
04-09-2021, 09:28 AM | #12 | |
The Following User Says Thank You to Tcoat For This Useful Post: | tomm.brz (04-09-2021) |
04-09-2021, 02:40 PM | #13 | |
Atmospheric pressure should be 1 bar or 14.7 psi, or it should be less if he lives at altitude, so Reno/Tahoe might be 12.5-13 psi. A turbocharged car will still hit wastegate pressure under load, but it will just take longer at altitude, so his absolute pressure should be the same anywhere. With that said, the delta will be higher, meaning, it will take 1-1.5 more psi of turbo pressure to get to wastegate pressure because there is 1-1.5 less psi of atmospheric pressure. This would lead to more heat and less efficiency. Hopefully he isn’t confusing atmospheric pressure and absolute pressure. Absolute pressure should be atmospheric pressure + boost pressure, so hopefully he doesn’t look at that larger number and freak out even more, thinking it is solely his boost pressure.
04-09-2021, 02:46 PM | #14 |
I PM’d him offering help, so he might.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Tcoat (04-09-2021) |
Similar Threads | ||||
make me less dumb - how tight is too tight for brake pads? | slowmow | Tracking / Autocross / HPDE / Drifting | 9 | 11-03-2020 09:32 AM |
Clicking when turning tight | Impureclient | Issues | Warranty | Recalls / TSB | 7 | 06-23-2020 05:36 AM |
17x8+45 with 8.3” tread width tires = tight spring perch to tire clearance | Chuckable | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 06-03-2019 01:09 PM |
Oi Takashi in USA, driving for Import Tuner Magazine FRS tuner impressions. | Moto-P | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-19-2015 04:39 PM |
Fuel Lid Tight or Loose? | JiB | Issues | Warranty | Recalls / TSB | 18 | 09-20-2012 12:50 PM |
