Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
08-12-2019, 01:03 PM | #71 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Maybe a small slide on spacer would do the trick
08-12-2019, 01:06 PM | #72 | |
Drives: 2022 GR86
12-08-2020, 02:24 PM | #73 |
Drives: 2022 GR86
Ordered as set of Hypergrams in 17x9 et40 5x100 with Bridgestone RE71R in 245/40 for autox next year.
Took some pictures on my Performance Package Brembos for other folks to have a better idea how these look. As you can see, there's plenty of clearance even if you turn the bleeder cap the wrong way |
12-19-2020, 12:30 AM | #74 | |
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | SuperTom (02-12-2022) |
12-22-2020, 07:06 PM | #75 |
Drives: 2022 GR86
The Following User Says Thank You to timurrrr For This Useful Post: | jflogerzi (12-22-2020) |
12-22-2020, 07:20 PM | #76 |
Drives: 2019 BRZ w/ PP
Man that looks good...
The Following User Says Thank You to NaturallyAspirated For This Useful Post: | timurrrr (12-23-2020) |
12-22-2020, 07:34 PM | #77 |
Second. Super clean
The Following User Says Thank You to jflogerzi For This Useful Post: | timurrrr (12-23-2020) |
12-22-2020, 09:18 PM | #78 | |
Drives: FR-S Whiteout
a lot of yes.
Intent > Content
cowardice is the mother of cruelty. |
05-22-2021, 03:04 PM | #79 |
Drives: 2017 BRZ PP (White)
05-22-2021, 03:54 PM | #80 |
Not my car, but I did have aluminum hubcentric ring in my aftermarket wheels.
Intent > Content
05-22-2021, 05:35 PM | #81 |
I will have some 17x8 hypergrams up for sale soon if your in the SoCal area
09-13-2021, 10:43 AM | #82 |
Dr. Fünke, Analrapist
Drives: 2013 BRZ Limited, 2004 WRX STI
Recently purchased some 17x9 +40 Hypergrams in gunmetal for my BRZ. Had them wrapped in Yokohama Advan A052 235/40/17s. I'm running stock dampers lowered 1" on Eibach springs. Heads up I needed 3mm spacers to clear the spring perch. Also with the meatier tires, on track I consistently knocked out my side markers.
Hat tip to @ATL BRZ for the tip on the 3mm spacers, I would've been a sad panda without them Also as noted by @jflogerzi, the 17x9s easily clear BBKs. I'm running the Stoptech C43 kit on mine and have plenty of clearance.
Last edited by weepel; 09-13-2021 at 10:54 AM. Reason: Photos were initially added as URLs, not embedded |
The Following 2 Users Say Thank You to weepel For This Useful Post: | ATL BRZ (09-21-2021), SockMonkey (09-14-2021) |
09-14-2021, 01:09 PM | #83 | |
Drives: '13 BRZ Limited
09-14-2021, 01:55 PM | #84 | |
I do plan on upgrading eventually to a decent set of coilovers as after ~7 years of tracking the car, the stock dampers have taken a beating and it would be nice to get more camber and to not have to run the 3mm spacers for these wheels.
Similar Threads | ||||
Konig Rims- what do you think? | KatrinaR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-25-2015 01:35 PM |
Konig Torch 18x8.0 +35 | khan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-21-2014 12:27 AM |
WTB- Konig Daylites | solort | Want-To-Buy Requests | 0 | 01-07-2014 11:07 PM |
Konig Wheels | pghfan19 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 04-25-2013 12:24 AM |
Konig deception | oaroyale | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 02-02-2013 09:02 PM |
