Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-11-2020, 06:06 PM | #15 |
Drives: brz
im torn. I would love to replace just the master cylinder, but the first few reply's from people think its a dead clutch. 2 very different, expensive, and time consuming things lol.
10-11-2020, 06:08 PM | #16 | |
Sent from my ONEPLUS A5010 using Tapatalk |
10-11-2020, 06:11 PM | #17 | |
Drives: 2013 frs raven
You can also pickup a second hand master cylinder for less than $50 and replace it in under an hour. |
10-11-2020, 06:15 PM | #18 |
10-11-2020, 06:22 PM | #19 | |
Drives: brz
If there was a leak inside of it or its just broken or whatever, would my clutch pedal feel normal? My pedal feels/felt normal |
10-11-2020, 06:29 PM | #20 | |
10-11-2020, 07:03 PM | #21 |
10-11-2020, 07:03 PM | #22 |
The Following User Says Thank You to Ashikabi For This Useful Post: | Ultramaroon (10-11-2020) |
10-11-2020, 07:06 PM | #23 | |
You also have to consider that the master cylinder has not completely failed its still retaining some pressure. As noted by him saying that he can see the fork moving. It's just not moving enough. |
10-11-2020, 07:24 PM | #24 | |
chicken tonight
Even if the pedal is mushy, with a shitty cylinder on either end, you should still be able to give it a quick pre-pump just like with a failing brake master. I vote for sticky pressure plate on the input shaft splines, or some other B.S. under the bell housing.
10-11-2020, 07:39 PM | #25 |
TOB
It will still move but no longer throws out
10-16-2020, 12:03 AM | #26 |
Drives: brz
okay thank you everybody for all the insight. I am going to have a shop do the work this time around (pain in the ass first time). IF it is the clutch that needs a complete replacement, does anybody have good recommendations that will work fine with the SBD turbo? my current clutch is "competition stage 2" and i will stay away from this brand due to the early failure of this clutch.
11-28-2020, 10:07 PM | #28 |
Drives: brz
not sure yet. its still sitting dead in the drive way. I actually last week replaced the master cylinder and that didnt fix it :/ so its most likely a clutch problem.
Im still researching what clutch to get.... so many damn mixed reviews about everything that is making it hard to decide. but I gotta take advantage of this black friday weekend sale lol |
Similar Threads | ||||
Gear indicator not registering 5 th gear on 6mt | sroby | Engine, Exhaust, Transmission | 20 | 03-18-2020 11:43 PM |
Gear indicator (G-on) shows 2 when in 3rd gear | c8Face | BRZ First-Gen (2012+) -- General Topics | 31 | 07-07-2017 07:23 PM |
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl | jakebrz | Issues | Warranty | Recalls / TSB | 14 | 06-06-2016 06:28 PM |
No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 08:39 PM |
Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 01-29-2012 01:21 PM |
