Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
#57 | |
Drives: 2015 FRS
Plus, from the powerband point of view, I'm still a bit too low in RPM on alot of 3rd gear corners, and the 4.556 will help with that as well. 4.88 is too short, and I think 4.556 is honestly the sweet spot. No, it's a wing setup from Europe. Similar foil width, ~48", but sits higher in clean air, and is perfect for when you don't run a front splitter. The balance is phenomenal.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos |
The Following User Says Thank You to prandelia For This Useful Post: | NoHaveMSG (10-15-2020) |
#58 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Before & After dyno plots (For N/A)
This was on my build thread ages ago. The pics were lost when tinypic hosting closed down
[CENTER]
Build thread |
The Following User Says Thank You to stevo_12v For This Useful Post: | captain awesome (11-14-2020) |
#59 | ||
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Any idea what the torque curve looks like? The 10ish hp bump around 4750 is awesome. Also what other mods were involved in this? What fuel? Edit: I see you mentioned some of this earlier in the thread. Quote:
#60 | |
Drives: 2015 FRS
![]() Expecting my new peak hp to be around 7600-7800rpm from 7150, on E85 spun to 8K for racing. Hoping it shows up in time as my Xmas present.....
'15 FRS - GLTC spec
The Following User Says Thank You to prandelia For This Useful Post: | sato (11-23-2020) |
#61 |
Drives: Dodge Patitas
Moto East / Deatschwerks Drop-in Surge Tank - tech & discussion | Xero-Limit | Engine, Exhaust, Transmission | 42 | 04-27-2017 09:16 PM |
Automatic Transmission Surge | N1rve | Issues | Warranty | Recalls / TSB | 25 | 03-16-2016 10:58 PM |
Fuel surge issue??? | owenxguo | Tracking / Autocross / HPDE / Drifting | 1 | 12-22-2014 09:58 PM |
SBD turbo surge?? | shif7i7down | Forced Induction | 72 | 11-20-2014 09:49 AM |
Automatic FRS Surge in Manual Mode | N1rve | Issues | Warranty | Recalls / TSB | 5 | 02-08-2014 12:28 PM |
