Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
#15 | |
Drives: Ultramarine FR-S
#16 | |
Sent from my ONEPLUS A5010 using Tapatalk |
#17 | |
Drives: 2017 Toyota 86
The 4.3 ratio is a solid upgrade across the board for ATs. When you're cruising the 4.1 and 4.3 FDs are equally as efficient even though one sits a little higher in the revs. The only real downside is an extra shift before you can hit 60mph, but ratios are usually optimized for 0-60 times (Note the 4.1FD + 2nd tops out right at 60MPH, that's not a coincidence, that's for the reviews.) The real deciding factor is where you want to compromise. AutoX tends to drift to longer ratios and an extended rev limit so you can work the course in 1st and 2nd. Track days are going to be course dependent, some might benefit from longer gears if the turns spiral out and normally require a shift that might upset the balance, others might benefit more from shorter gears if you're never getting past 3rd or 4th already. Street driving is entirely up to the driver. If I had an AT I'd definitely be looking at a 4.3, maybe even a 4.5 now that the term "Daily Driver" is a very loose description of how I use the 86. |
#18 | |
Drives: 2017 toyota 86
A 4.88 i think puts 4th redline around 106mph A 4.56 was around 114 A 4.3 was around 120. Stock 4.1 I think was 128. Can just find gear ratios online and calculate if you want exact can’t remember exact off top of head. I also had a 25” tire vs stock 24.6 so 2nd with a 4.3 and 7500 limiter i could hit 60 in 2nd before fuel cut. Choosing a FD is highly use specific. For a fun DD/street/canyon carver backroader, NA up to about 240whp 4.56 is good FI 240-300whp 4.3 is good. At 300whp+ 4.1 is good. Personally I liked to Hwy pulls and a 4.88 makes 4th too short. Who wants to only be able to pull to 105mph. For track or autox FD ratio there is a very specific way to figure out best ratio. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | new2subaru (11-11-2020) |
#19 |
Weight Weenie
Drives: 15 FR-S
Choose you FD based on your top speed. Here's a MT 4.3 vs AT 5.29 5th is close to the same and 5th is usable in the AT. Some check all the numbers for accuracy.
http://www.teammfactory.com/calculat...200/7200/1/1/2 |
The Following User Says Thank You to new2subaru For This Useful Post: | Devil 86 (11-11-2020) |
#20 |
Drives: 2013 FR-S Argento
I don't really understand why anything higher than stock is needed on a Vortrch equipped car - I am Vortech supercharged and my first gear is pretty unusable if I floor it. Actually I sort of get it, it gives the perception that your car is faster overall because it pulls harder in each gear, but really it doesn't make all that much of a difference to acceleration over time. Especially if you have a hard time putting the power down.
Sent from my SM-G965U using Tapatalk |
#21 |
Weight Weenie
Drives: 15 FR-S
There was one member with FI and a 4.88. Can't recall the username atm.
#22 |
AutoX-10/10ths every run
My AT with a Cusco 4.556 and the EB SC at about 300WHP was a hoot.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
#23 | |
#24 |
My FRS is a dedicated track car. The fastest ive gone on track is 126 mph down the back straight of watkins glen and thats reclining 4th gear. I've never used 5th and 6th gear on track and don't mind extra shifting if that means staying in the power band exiting corners. I guess I should consider something shorter than a 4.8. I plan to stay N/A
#25 | |
Consider a rolling drag race between a car with a 4.1 and a 4.8 FD, starting at the same speed in say 2nd gear, both cars are in the power band (above 4000). The lower geared car would instantly start pulling ahead due to the mechanical advantage of the 4.8, but will have to shift sooner to 3rd gear while the 4.1 car gets to stay in 2nd. For that time before the 4.1 car has to shift into 3rd, the 4.1 car has the mechanical advantage and will just barely catch the 4.8 car before the 4.1 car has to shift to 3rd. Mathematically that's how it works (we are disregarding shift times here, infinitely fast shifts). So while a 4.8 car will pull ahead, the higher geared car will always just catch up before having to shift - the 4.8 car is faster but not as fast as you think, or not as fast as it might feel in a single gear. Clear advantages of a lower geared car: 1) from a standing start on a car that can put the power down, a lower geared car will get you up into your power band quicker, which is a true advantage the higher geared car won't recoup 2) if you are gearing for a very specific application where you want to work in a set of gears, i.e. someone mentioned AutoX where a stock geared car might not take advantage of all of 2nd gear - it depends though, on a larger course a stock geared car might not have to shift to 3rd where a 4.8 car would in some spots, there the 4.1 car would be faster to the end of the straight (again not even factoring in shift time, which is something else to consider). Another scenario might be like the post above this one, where a lower FD might optimize your acceleration corner to corner on a track for a specific track/situation, but you have to be careful you don't shoot yourself in the foot in other places on that track (or other tracks). Considering most well tuned FI cars can't put power down in first, that gear is a waste because you can't even use it from a standing start to get you up into the power band, you have to feather the throttle. IMHO for acceleration you'd be better off spending the FD money on a smaller pulley plus flex fuel (or meth injection if you don't have access to ethanol). One last thing to point out, FD changes do not change your gear spacing - if you are looking to keep your tach higher in the rev range in between gears like the OP mentioned, you need a new gearset. Apologies for the novel, probably too much coffee this morning ![]() Sent from my SM-G965U using Tapatalk |
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post: | jcw99 (11-14-2020), new2subaru (11-12-2020) |
#26 |
Weight Weenie
Drives: 15 FR-S
Here's a good thread on FD's
https://www.ft86club.com/forums/showthread.php?t=111688 It's a good read |
The Following User Says Thank You to new2subaru For This Useful Post: | bfrank1972 (11-12-2020) |
#27 |
Drives: 2016 BRZ Premium
Do like others have suggested and find a 4.30 rear end from a manual 2017+ car. The code on the 4.30 differential is Y58.
I found one from a 2019 that had 4800 miles for $460. It was a definite improvement and more gearing would be nicer but it's hard to beat for under $500. |
FRS Fitment help !! | FRS Megan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 04-03-2020 09:17 PM |
How's the fitment of 1320's dual res fp fitment on AT | aznchris | Engine, Exhaust, Transmission | 0 | 04-16-2019 06:02 AM |
TRD Kit fitment | Ds3ire | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 03-16-2016 03:11 PM |
Help on Fitment! | lxsedan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-07-2015 10:01 AM |
