Tracking / Autocross / HPDE / Drifting What these cars were built for! |
11-06-2020, 09:35 AM | #1 |
Sean 86
Drives: 2019 Toyota 86 TRD SE
Oil for track usage?
I couldn't find any threads (partly because typing "oil" is too broad for the search function and I'm a little lazy) but what engine oils do you guys use and recommend for the occasional track day? My closest track is the nurburgring if that makes a difference to what you'd recommend. The coldest it gets here in Germany where I live is probably the 30s and I would be dailying the car as well. All help would be appreciated
11-06-2020, 09:45 AM | #2 |
30 minute maintenance
Drives: My18 wrxsti My19 brzts
30f is freezing 30c is hot
The Following User Says Thank You to gen3v8 For This Useful Post: | soundman98 (11-06-2020) |
11-06-2020, 11:10 AM | #3 | |
Drives: 2013 WRB BRZ
Using context clues, I can imagine he is using Fahrenheit.
There is a bunch of threads and I understand there are so many thoughts on what to do and its hard to sift through. Its more about the oil pressure at high temps than the actual temperature. My vote would be 5W-30 for the occasional track day and just keep an eye on the temps on track.
11-06-2020, 11:27 AM | #4 |
Drives: Miata
11-06-2020, 12:40 PM | #6 | |
This is pretty much the conclusion I got from reading a couple of the oil temp threads. During my first track day a few weeks ago, my oil temps (factory 0W20) peaked at a toasty 264F during each session. A session typically consisted of 1 warm-up, 6 hot laps, and 1 cool-down lap. Keep in mind though, the ambient temp was also only around 45F. I think a good 30 weight oil would be a minimum for any mild track use to cope with the heat and ensure high rpm oil pressure. |
11-06-2020, 01:24 PM | #7 |
Drives: '13 Whiteout
I have an IAG Stage 1 motor and to keep their warranty intact I need to use 0-20 Motul synthetic. These blocks have very close tolerances and improved oil flow. With my oil cooler I’m around 230 on the track. The thinner oil also helps keep the engine cooler. I never thought I’d be using that low of a viscosity however I understand the benefits especially on a cold start
The Following User Says Thank You to TommyW For This Useful Post: | CSG Mike (11-06-2020) |
11-06-2020, 01:59 PM | #8 |
Drives: Nevermorange FRS
I have an oil cooler and I race with valvoline full syn high mileage oil. 5w-30. I’ll change out to a 10w-40 if it’s going to be super hot that weekend and I’ll be drafting a lot. HM oils tend to have more zinc and I don’t think expensive boutique oils are necessary. A good syn gets you there, just make sure to keep oil pressure up.
For endurance racing I’ll likely go thicker. The TAPG team that did the 25 hours of Thunderhill I believe used a 50wt oil for the sake of reliability.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | CSG Mike (11-06-2020) |
11-06-2020, 05:22 PM | #9 |
Would 5w-30 be good daily use in 30c+ Temps.
Sorry for slightly off Topic but Oil Gurus are here. |
11-06-2020, 08:10 PM | #10 |
Wheels for Brains
0W20. If you are a proficient driver, get an oil cooler and continue to run 0W20. If you don't have much track driving experience, you can still run 0W20 without an oil cooler for the first few times if you watch your oil temperature (keep it under 265F).
5W30 without an oil cooler can be okay if you need to band-aid high oil temperatures on track, but it can only take you so far. Plus there is the added downside that your engine will see higher than ideal oil pressure when the car is cold. Cold engine oil pressure is already really high even with 0W20 |
The Following User Says Thank You to EndlessAzure For This Useful Post: | TommyW (11-09-2020) |
11-07-2020, 07:09 AM | #11 |
6/22/12-2/6/24
https://www.eneos.us/product/eneos-racing-street-0w-20/
VI of 239 gives a bit more protection than other oils as the temps start to creep up I'm also excited to try toyota's GR with a VI of 335 https://toyotagazooracing.com/jp/gr/...pEpyB51cA_O2P0
The Following User Says Thank You to Bonburner For This Useful Post: | glhs386 (11-09-2020) |
11-09-2020, 05:58 AM | #12 | |
Drives: 2014 FR-S Monogram
Tags |
oil, track |
Similar Threads | ||||
Best Diff Fluid & ATF for Track Usage? | Tristor | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 04-23-2019 03:52 PM |
Oil Weight Poll For Track Usage | brillo | Tracking / Autocross / HPDE / Drifting | 49 | 07-01-2015 05:34 PM |
Custom tunes safe for track usage? | Sleepless | Software Tuning | 21 | 12-23-2014 08:54 PM |
Custom tunes safe for track usage? | Sleepless | Tracking / Autocross / HPDE / Drifting | 46 | 10-29-2014 08:52 PM |
Best kit for occasional track usage | yomny | Forced Induction | 14 | 02-06-2014 08:10 AM |
