Old 06-15-2020, 08:55 PM   #155
Route
Route's Avatar
Drives: 2007 GT3 | 22' BRZ
Originally Posted by Desain2137 View Post
Hey babe, nice to see that AG battery working for ya!
imy
Route is offline   Reply With Quote
Old 06-21-2020, 09:58 PM   #156
Route
Route's Avatar
A052's, Hotchkis sway bars and my compressor kit for the air cups have arrived. Car is in the shop currently for an alignment and SPL front arm install.
Old 06-24-2020, 02:54 PM   #157
Route
Route's Avatar
Picked up a Recaro Pro Ricer RMS, A052's mounted on the TE's and fitment is tight.
After driving around with the Moton's I can give a quick review about how they drive on the street and I must say they are incredible. Even with the 16K spring rates they are miles more comfortable than the KW Clubsports and handle the small cracks on the road beautifully. Took some on/off ramps fairly aggressively and they have blown my mind with their performance. Moton has a new lifelong customer.
These stupid air cups are giving me so much headache.
The Following User Says Thank You to Route For This Useful Post:
Berserker (07-06-2020)
Old 06-24-2020, 03:50 PM   #158
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
What made you decide to get the SPL front lower control arms?
Mike_ZN6 is offline   Reply With Quote
Old 06-24-2020, 03:56 PM   #159
Route
Route's Avatar
The air cups make the width of the coilovers similar to the stock shocks so it introduces clearance issues on the inside if you adjust camber with a camber bolt. I had to move the eccentric lockout on my Motons to full positive and max out the camber plate up top to compensate for the loss of camber but it still wasn't enough which is where the SPL arm comes in. The issue is I have extended the track width a bit too far to meet the camber numbers I want.
Old 06-24-2020, 04:40 PM   #160
Mike_ZN6
Mike_ZN6's Avatar
I have been following your build and I didn't even notice you installed air cups! I recently got a set of the same wheels (we spoke on FB recently) and I will have them mounted up and aligned in the next few weeks when I get some time. I am considering the SPL front control arms to narrow the front track if I feel like the +36 pokes a bit too much for my taste.
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
Route (06-24-2020)
Old 07-03-2020, 08:45 PM   #161
daviddgaf21
daviddgaf21's Avatar
Drives: 2014 Scion FR-S
Amazing build man, I’m drooling over the TRD fins lol
daviddgaf21 is offline   Reply With Quote
The Following User Says Thank You to daviddgaf21 For This Useful Post:
Route (07-03-2020)
Old 07-14-2020, 12:24 PM   #162
Route
Route's Avatar
Car is finally ready to hit the track. Only had an hour of track time and was on eyeball alignment after sorting out all the fitment issues.
It is now properly aligned with some decent specs so curious to see how the car responds to the new upgrades.
-3.8 degrees of camber in the front, 0 toe, 6.7 degrees of caster
-2.8 degrees of camber in the rear, 0 toe
The Following 3 Users Say Thank You to Route For This Useful Post:
Berserker (07-14-2020), thedollarbill (07-14-2020), TylerLieberman (07-14-2020)
Old 07-14-2020, 02:02 PM   #163
Berserker
The first pic at Cayuga? no way you went to the track and didn't get on it lol. Car is looking great as always man. Keeping the TE's on for now?
Berserker is offline   Reply With Quote
Old 07-15-2020, 03:28 PM   #164
Route
Route's Avatar
I did like 15 laps to shake down the suspension and that was about it. TE's will stay, CE's will most likely go sometime in the future.
Berserker (07-20-2020)
Old 07-15-2020, 06:47 PM   #165
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Yaaaaaas. TEs are the way
The Following User Says Thank You to TylerLieberman For This Useful Post:
Route (07-16-2020)
Old 07-20-2020, 02:14 PM   #166
Route
Route's Avatar
PCI seat base and sliders are taking forever for the RMS so I had to put the RSG in the driver's side for now. So lit.
ayoshioka1 (07-20-2020), JonAvalon (07-20-2020), thedollarbill (07-20-2020)
Old 07-20-2020, 07:31 PM   #167
ayoshioka1
Drives: 2019 BRZ / E36 325is
LOOKS SICK BROTHER
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu
ayoshioka1 is offline   Reply With Quote
The Following User Says Thank You to ayoshioka1 For This Useful Post:
Route (07-20-2020)
Old 07-20-2020, 08:11 PM   #168
Mike_ZN6
Mike_ZN6's Avatar
Your car looks so good bro! I'll make sure to post up mine with the TE37 OGs mounted up soon.
Did you get the air cups so you can lift the nose up for curbs, driveways, etc? Or to hard park it?
How much weight does the airlift system add?
Route (07-20-2020)
14r, brz, frs, trd, voltex
My Asphalt FRS Build ZaneRL9 Member's Car Journals 14 06-13-2015 03:38 PM
hattrickey's Asphalt Build hattrickey Member's Car Journals 4 08-16-2014 12:00 PM
asphalt.frs.22's Evil fr-s build asphalt.frs.22 Member's Car Journals 1 05-30-2014 07:21 PM
Opposed Asphalt build Opposed Member's Car Journals 30 01-15-2014 11:03 PM
New FRS Asphalt build. Erik-Frs Member's Car Journals 24 09-18-2013 08:18 PM
