Forced Induction Turbo, Supercharger, Methanol, Nitrous |
06-04-2020, 01:27 AM | #29 | |
The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
06-04-2020, 02:20 AM | #30 | ||
Drives: 2017 toyota 86
for a low budget (relative) FI track car i would do a centrifugal like JRSC. for a low budget (relative) FI DD i would choose Turbo. for a high budget (relative) FI track car or DD i would choose Turbo. I chose PD SC myself because for a DD it is better than a centrifugal SC, in my opinion. But I do all the work on my car myself, and didn't trust myself to do a proper turbo setup at the time i installed the SC so PD SC it was. So you could say for a FI DD that is your DIY weekend project i would choose a PD SC unless you really know what you are doing when setting up a turbo. |
06-04-2020, 04:27 AM | #31 |
pessimistic skeptic
06-04-2020, 01:39 PM | #32 |
The T518Z is a small turbo. Going with a larger turbo will not change the HP that much at a specific psi. It will change when the boost starts and how much max boost you can get. I believe that turbo is only good for upper 300hp range. In order to make more HP at the same PSI you have to control IAT and have a good tune. I am sure CSGMike can have a more detailed explanation. Plus his explanation of a “Properly” sized turbo for your goals.
And there is only one correct answer when someone asks if they should turbocharge or supercharge their BRZ...... “Yes!” |
The Following User Says Thank You to Grady For This Useful Post: | mrg666 (06-04-2020) |
06-04-2020, 02:26 PM | #33 | |
pessimistic skeptic
06-04-2020, 02:35 PM | #34 |
06-04-2020, 02:41 PM | #35 | |
Drives: brz 2017 hksv2
and also make engine less knock prone so shitty-fuel friendly only downside of bigger turbo is slower spool, but brings only advantages.. also IAT (actually proper name is Intake Charge Temperature for a FI car) is lower with bigger turbo, for the same HP compared to smaller "properly sized" would be a kind of compromise between fast enough spool, and max hp Those 2 are one the contrary of the other in the choice of turbo size |
06-04-2020, 02:46 PM | #36 |
pessimistic skeptic
All of my arguments are facts, or as conceived as facts. The value I add is countering loudness of fanaticism. That is what I call trolling.
The Following User Says Thank You to mrg666 For This Useful Post: | Tanstin (06-08-2020) |
06-04-2020, 02:54 PM | #37 |
You either restated thing’s already said (which is fine to add reassurance) or just said false opinions/lies/mad up fiction. (Which is trolling, and adds no value). But I don’t see any NEW unique fact that you added to contribute value. But to each their own. Can’t control the internet. 🍻
06-04-2020, 03:46 PM | #38 | |
pessimistic skeptic
06-04-2020, 04:36 PM | #39 |
Actually that's on ACN91. Just a good tune. This is with a stock front pipe in place too.
Turbos don't have the parasitic loss of a supercharger, so the power difference is what the supercharger is eating, all else equal. |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | 86TOYO2k17 (06-04-2020), mrg666 (06-04-2020) |
06-04-2020, 04:38 PM | #40 | |
Because I'm not pushing big boost, a "more efficient" larger turbo is not actually more efficient for me. This can be determined with compressor maps and/or looking at intake charge temps vs pressure. The T518Z with ethanol, will easily clear 450hp crank/350whp. In fact, I do so on only about 10.5 psi. More boost than this goes into diminishing returns, and really should be done with a larger turbo, but I'm okay with the power I have! |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | 86TOYO2k17 (06-04-2020), Grady (06-05-2020) |
06-04-2020, 04:39 PM | #41 |
06-04-2020, 05:22 PM | #42 | ||
pessimistic skeptic
Tags |
forced induction, mopowabby, supercharger, turbo |
Similar Threads | ||||
DC Sports cat back review and new supercharger options for the 86 | Photomikes garage | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 02-09-2017 06:17 PM |
HKS Supercharger V2 vs. Greddy Turbo Kit vs. Crawford Turbo Kit | Ogremair | Forced Induction | 27 | 09-10-2015 04:39 AM |
What are turbo options for AT? | FT&6 | Forced Induction | 7 | 07-13-2015 09:40 AM |
Turbo options | robinsonbond007j | Forced Induction | 42 | 10-19-2014 12:44 AM |
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! | rickspecd | Forced Induction | 4 | 07-12-2013 11:50 AM |
