04-13-2020, 02:50 AM | #1 |
Drives: 2013 Scion FR-S Turbo 14PSI
LT1 Swap
Crazy as it sounds I have a c4 corvette LT1 engine just sitting in my garage collecting dust. I gave it some thought and I’m curious is there anyone that has done an LT1 swap to frs/brz? I mean I got the engine I just need the adapters, engine bracket/swap kit and esc. I’ve tried doing some research and I can’t find and adapters for the LT1 engine to frs trans. Just curious if anyone has any knowledge on this.
04-13-2020, 03:07 AM | #2 |
Drives: 2015 frs
You need a t56 transmission. Or other GM transmission. The frs/BRZ transmission is weak, and would need to be moved back towards the firewall.
The Following User Says Thank You to Zer0 For This Useful Post: | wparsons (05-05-2020) |
04-13-2020, 11:01 AM | #3 |
Drives: 2015 FRS - FFR GTM
I had an LT1 in my 93 Vette. It was a real step up HP wise from the motor in my 85,, like 100HP more. Ran strong. As mentioned above,, T56 out of a 90's Camaro would be the way to go for a transmission. Also,, if you cant find a kit and someone who's done it, it can be a long road doing it all yourself.
2015 FR-S - One Day I'll Finish The Swap |
04-13-2020, 12:17 PM | #4 |
Drives: Q5 + BRZ + M796
Iron block? Distributor?
I would sell the LT1 and buy an LS1/tranny/wirring/ecu from a Camaro. The price difference is probably negligible compared to the cost of the build.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post: |
04-17-2020, 09:46 PM | #5 |
Drives: 16' BRZ
If you're talking new LT motor that would be pretty sweet.
04-17-2020, 11:41 PM | #6 |
He said 93, so C4 lt1
04-28-2020, 04:05 PM | #7 | |
Sent from my ONEPLUS A5010 using Tapatalk |
04-29-2020, 04:06 PM | #8 | |
Drives: LS Swapped Scion FRS = 440HP
Do it right once. I used an LS2 and if I did it over, would have went LS3.
The Following 2 Users Say Thank You to spitsnaugle For This Useful Post: | Sportsguy83 (05-08-2020), wparsons (05-05-2020) |
04-29-2020, 05:17 PM | #9 |
04-30-2020, 02:53 PM | #10 |
Yes. DBW, CANBUS controlled AC, etc. Its just the LS2 is an oddball that is designed around the e40 ecu (doesnt have good canbus integration support), it can be modified (24/58 reluctor wheel) to use an e38, which is a more popular.
05-05-2020, 01:48 PM | #11 | |
Drives: Red BRZ
Sent from my SM-G950U using Tapatalk |
Tags |
#engineswap, #lt1, #lt1swap, #swap |
Similar Threads | ||||
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
3GR-FSE Swap | cf6mech | Engine Swaps | 0 | 10-24-2015 01:32 AM |
Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-21-2015 11:38 PM |
