Old 04-13-2020, 02:50 AM   #1
Glock_86
Glock_86's Avatar
Drives: 2013 Scion FR-S Turbo 14PSI
Lightbulb LT1 Swap
Crazy as it sounds I have a c4 corvette LT1 engine just sitting in my garage collecting dust. I gave it some thought and I’m curious is there anyone that has done an LT1 swap to frs/brz? I mean I got the engine I just need the adapters, engine bracket/swap kit and esc. I’ve tried doing some research and I can’t find and adapters for the LT1 engine to frs trans. Just curious if anyone has any knowledge on this.
Glock_86 is offline   Reply With Quote
Old 04-13-2020, 03:07 AM   #2
Zer0
Drives: 2015 frs
You need a t56 transmission. Or other GM transmission. The frs/BRZ transmission is weak, and would need to be moved back towards the firewall.
Zer0 is offline   Reply With Quote
The Following User Says Thank You to Zer0 For This Useful Post:
wparsons (05-05-2020)
Old 04-13-2020, 11:01 AM   #3
gtpvette
Drives: 2015 FRS - FFR GTM
I had an LT1 in my 93 Vette. It was a real step up HP wise from the motor in my 85,, like 100HP more. Ran strong. As mentioned above,, T56 out of a 90's Camaro would be the way to go for a transmission. Also,, if you cant find a kit and someone who's done it, it can be a long road doing it all yourself.
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 04-13-2020, 12:17 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Iron block? Distributor?
I would sell the LT1 and buy an LS1/tranny/wirring/ecu from a Camaro. The price difference is probably negligible compared to the cost of the build.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
solidsnake11 (04-17-2020), Ultramaroon (04-17-2020), wparsons (05-05-2020)
Old 04-17-2020, 09:46 PM   #5
GrabTheWheel
Drives: 16' BRZ
If you're talking new LT motor that would be pretty sweet.
GrabTheWheel is offline   Reply With Quote
Old 04-17-2020, 11:41 PM   #6
Irace86.2.0
He said 93, so C4 lt1
Old 04-28-2020, 04:05 PM   #7
Ashikabi
Ashikabi's Avatar
Go LS3. LS1 is more headaches. Just spend the extra couple grand
Sent from my ONEPLUS A5010 using Tapatalk
Old 04-29-2020, 04:06 PM   #8
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
This^
Do it right once.
I used an LS2 and if I did it over, would have went LS3.
spitsnaugle is offline   Reply With Quote
The Following 2 Users Say Thank You to spitsnaugle For This Useful Post:
Sportsguy83 (05-08-2020), wparsons (05-05-2020)
Old 04-29-2020, 05:17 PM   #9
Ashikabi
Ashikabi's Avatar
Originally Posted by spitsnaugle View Post
This^
Do it right once.
LS2 CAN operated?
Old 04-30-2020, 02:53 PM   #10
spitsnaugle
LS2 CAN operated?
Yes. DBW, CANBUS controlled AC, etc. Its just the LS2 is an oddball that is designed around the e40 ecu (doesnt have good canbus integration support), it can be modified (24/58 reluctor wheel) to use an e38, which is a more popular.
Old 05-05-2020, 01:48 PM   #11
vijay.dy06
Drives: Red BRZ
This^
Do it right once.
You can still use which ever LS variant, just swap reluctor wheels and throttle body to a 58x, supporting components and get the rotating assembly balanced. It'll cost a few hundred dollars instead of spending a couple grand more on an LS3 if its not needed.
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
#engineswap, #lt1, #lt1swap, #swap
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
3GR-FSE Swap cf6mech Engine Swaps 0 10-24-2015 01:32 AM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
