Software Tuning Discuss all software tuning topics. |
04-09-2020, 05:19 AM | #1 |
Drives: 2017 Toyota 86
Post up your best 0 to 60 time
Here is mine so far...full tank of gas no tire warm up, full tire pressure @ 40 psi and I could have ran my rpm's up some more before, I shifted at 7,300 rpm I set my fuel cut off at 7,950 rpm per OFT.
04-09-2020, 05:52 AM | #2 |
Drives: '15 BRZ RA
0 - xx mph times are not that useful, because it depends on how you lunch the car and you might have wheel spin . A more meaningful timing would be 20 - 60 mph in 2nd gear ...
The Following User Says Thank You to nikitopo For This Useful Post: | DarkPira7e (04-09-2020) |
04-09-2020, 08:49 AM | #3 |
Drives: 2017 toyota 86
also what you use to measure it, as most phone apps are inaccurate. also doesn't account for slope. need dragy to do verified runs.
04-09-2020, 03:27 PM | #4 |
And the BRZ is anything but a 0-60 car.
04-09-2020, 04:40 PM | #5 |
Drives: 2013 frs red
These cars are tricky to launch and your times will be all over the place. My best runs were done with some wheelspin and were under 6 seconds.
04-09-2020, 06:19 PM | #6 |
With an auto, full bolt ons, about 120lbs weight reduction, full drag reduction aero, 92octane 4.56fd, cold 225 A/S tires, 2300rpm launch. Using dragy did a verified 6.6sec (6.4 w/ 1ft roll out) 0-60.
W/ exact same setup as above but with IC sprintex 210 on 72mm pulley and WMI but only 700rpm(idle) launch did a 5.1sec (4.9 w/ 1ft roll out) Since then I’ve switched to 69mm pulley, 4.3FD, os giken lsd, stage 2 valve body, 255 tire, suspension, lightweight bucket seats, light weight wilwood BBK. But haven’t had time or cared to do more 0-60 since. Still don’t have traction to launch above idle anyways, so probably 4.8-4.9 (4.6-4.7 1ft) now. But 40-120 is what i care about more anyways. Also if it isn't taken from a drag strip slip, a vbox, or dragy. It don’t count. Phone apps and OBDII are all inaccurate. And Easy to go down hill for faster time. |
04-09-2020, 06:35 PM | #7 |
Drives: 2014 GT86
Why don't count? They count as much as max whp/wtq from different dynos w/o baseline . Same level of credibility.
04-09-2020, 06:44 PM | #8 |
ProCrastinationConsultant
i once hit 60mph in 35 minutes!
04-09-2020, 07:47 PM | #9 |
Lol was just messing around nothing serious...some of you guys take things way to seriously lol...and yeah it was a GPS timer. Its been pretty consistent recording, I am not running a supercharger or anything all N/A with just a tune. Before the car consistently hit 7.4 now with the OFT tune and a little weight loss shaving of nearly a full second...I was happy about that some will disagree at how I measured my time and thats fine.. I just know it definitely improved my car with little work. Peace out brothers stay safe stay home.
The Following 2 Users Say Thank You to Contender For This Useful Post: | MilkyWitness (04-10-2020), SuperTom (04-10-2020) |
04-09-2020, 08:19 PM | #10 | |
Now using same form of measuring in exact same scenario to record personal improvements from modifications is fine. But comparing to others times is pointless unless you can create a pretty accurate and fair standard in which to measure and perform the test. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | nikitopo (04-10-2020) |
04-10-2020, 11:45 AM | #11 |
Only 3 people posted any times. All the rest were experts opinions lol
04-10-2020, 01:42 PM | #12 |
Drives: Crapcan
I don't think it has anything to do with being elitist. I think most people on this forum don't care about 0-60. It's not that type of car. I could easily log 0-60 on my Solo, but why bother The only numbers that interest me from that data are my lap times, and lateral G's.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (04-10-2020) |
04-10-2020, 01:45 PM | #13 |
Truth is many on here don’t really care about any numbers, the only number that counts is smiles/cost and this car does it very well.
The Following User Says Thank You to Ernest72 For This Useful Post: | soundman98 (04-10-2020) |
04-10-2020, 03:34 PM | #14 |
But the guy was just looking to compare 0-60 times
Similar Threads | ||||
Post roll cage lap time differences | Walldodger | Tracking / Autocross / HPDE / Drifting | 7 | 05-25-2017 01:06 PM |
Long time lurker making his first post. | JNthe86 | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 02-05-2017 11:41 PM |
alright my tenth post so i can officaly post in the marketplace | destiny86 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 02-04-2016 12:49 PM |
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install | The Sentinel | Engine, Exhaust, Transmission | 92 | 03-09-2015 05:20 PM |
post Your 1/4 mile time!!!!! | PrDarkKnight | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 06-01-2013 09:07 AM |
