Engine Swaps Discussion of engine swaps. |
11-22-2019, 10:24 AM | #1 |
wiring aftermarket ecu question
I have an emtron that I'm getting ready to start wiring in. When people wire in aftermarket ECU's, do they just wire the basics to get the engine running or do they do thinks like evap and all the other oem stuff to the ecu? I'm trying to dissect the wiring schematics and not sure if things like heater and all that stuff wire into the ecu.
11-22-2019, 10:30 AM | #2 |
Rust bucket enthusiast
There's no golden standard, people pick their battles typically. I feel like starting with just the basics is the best strategy. Why over complicate it if you don't need to?
Also depends on your goals. Do you want to pass vehicle emissions regulations or a state inspection? or do you not care if the tachometer works and it starts on fire half way through it's first tractor pull competition |
12-06-2019, 05:58 PM | #3 | |
Drives: 2013 Ultramarine FR-S
For instance, my LS swap runs pretty well separate of the car with the only connection between them being the two canbus wires for the canbus converter. Though I did use the factory relays and wiring for the fans as it made sense to tap into stuff that was already there.
Similar Threads | ||||
Factory Sub Wiring to Aftermarket HU | Unholypanda | Electronics | Audio | NAV | Infotainment | 3 | 10-11-2019 08:15 PM |
Correct aftermarket LED wiring? | leevanf | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 09-28-2017 11:39 PM |
Horn wiring for aftermarket wheel? | acpstunts | Electronics | Audio | NAV | Infotainment | 0 | 12-06-2016 11:52 AM |
Rear View aftermarket wiring... help! | DV84 | Electronics | Audio | NAV | Infotainment | 0 | 07-27-2016 12:07 PM |
2016 Aftermarket HU - Stock Wiring | Luftwaffel | Electronics | Audio | NAV | Infotainment | 19 | 12-07-2015 04:44 PM |
