Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
09-28-2019, 03:26 AM | #1 |
#1819
Drives: Lightning Red Subaru BRZ
18x9.5 +45 rubs on my front spring perches. Help me please.
So I read on the forums that 18x9.5 +45 fits on our cars without spacers. I put the wheels on tonight and to my dismay found that the tires are right up against the spring perch. I'm using 255/35/18 tires on these rims.
I'm gonna guess that everyone that got them to fit is using coilovers vs stock struts? Is there any detail that I'm missing here? Thanks everyone for any help you can provide. |
09-28-2019, 03:56 AM | #2 |
Drives: MY15
Are you on stock struts?
09-28-2019, 04:41 AM | #3 | |
Drives: 2017 Pure Red BRZ w/ Perf Package
This is your setup currently at stock height and nothing else added (given your notes in your post). If you're running camber bolts or anything else, it may affect your fitment but idk so I"m using base numbers as a guideline. Clearly it has 12mm clearance issues. The other thing you can do is get 15mm spacers to clear the perch. The 15mm will make your wheels technically +30 offset in this case. To dial in the poke you'll have at +30 offset, I then recommend camber bolts to about -2 degrees to tuck in the wheel. In theory it should clear with these add-ons. If this all seems too complicated... Just get a set of coilovers and you won't have to worry about a +45 fitment on a 9.5 wheel. Hope this helps! |
The Following 4 Users Say Thank You to Skyehigh55 For This Useful Post: |
09-28-2019, 10:51 AM | #4 |
Purist
Drives: 2013 FRS - Hot Lava
17x9 +45 does not fit. So yea, you will have fitment issues. +15 stud spacer until you get coils?
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
09-28-2019, 01:58 PM | #5 |
#1819
Are there any coil overs that would not work for my wheels? Are all coil overs roughly the same diameter?
09-28-2019, 02:52 PM | #6 |
Country Boy 4 Life
18X9.5 +38 Fits with a 235/40/18 on stock suspensions.
18x9.5 +35 fits with a 245/35/18 on stock suspensions. Get extended studs, 10mm to 15mm spacers, and camber bolts minimum. Edit: yeah with a 255/35/18 already... you will want coils.
I LIKE TIRES! Last edited by Leonardo; 09-28-2019 at 03:06 PM. |
10-07-2019, 03:13 PM | #7 |
Drives: 2018 BRZ PP (Modified)
18x9.5 +38 with 245/35/18 fits on stock suspension too, full lock to lock no rub. I know because I had it for two weeks while waiting for my coils
10-07-2019, 03:27 PM | #8 |
Country Boy 4 Life
Thanks! I know, but not all 245/35's are the same width. And with a +38 offset, which is very close, not all 245/35s fit on stock suspension.
I LIKE TIRES! |
11-02-2019, 09:32 PM | #9 |
Drives: 2015 Firestorm FRS
Planning to do the advan tc4 which is 18x9.5 +45 with 255/40/18 tires.
Will it fit using tein flex a/z or bc br coils? Thanks. |
11-03-2019, 01:43 AM | #10 |
#1819
11-03-2019, 01:37 PM | #11 |
Drives: 2019 BMW ///M4
I had 255 35 R18s on my 18X9.5 (MP4S), you definitely need coils to run 255s or you will rub. You need like 235s to be on the safe side to not rub on stock suspension on the fronts. You will also need to dial in some negative camber, at least -2 degrees or you'll get some poke. That +45 is not helping you either.
11-04-2019, 05:17 AM | #12 | |
Yes. Im on tein flex z coils now. Im using 57cr 17x9+38 245/40/17.
And im planning to change it to advan tc 18x9.5+45 245-255/35/18. Will it rub? Even if i change my coils to flex a or bc? Thanks Quote:
11-04-2019, 07:23 AM | #13 |
Rust bucket enthusiast
Please let us know where you heard that a 9.5" wheel with a +40 offset would fit so we can correct them. I had light rubbing on +35 8.5" wheels with stock struts.
Your only option is to either gets coilovers, or get some serious bolt on spacers. Since you'll be spending the money anyone, I'd just get some coilovers to avoid the issue altogether. |
11-04-2019, 06:48 PM | #14 | |
Sir. 18x9.5 +45 with 255/35/18 tires will not rub if i have tein flex z/a or bc coils?
Thanks Quote:
Similar Threads | ||||
Coaxial Spring Perches Rear Coilovers | Butterballz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-14-2019 06:05 PM |
BRZ/FRS stock spring perches (MCS) | AndrewMcG | Brakes, Suspension, Chassis | 2 | 08-23-2017 10:32 AM |
[SOLD] Raceseng Cas/Cam Plates (90mm perches) | Shark_Bait88 | Brakes, Suspension, Chassis | 4 | 07-31-2017 02:05 PM |
Lowered on coilovers with camber, front swaybar endlink rubs/binds inner wheel well? | Krovi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 09-28-2016 10:02 AM |
17x9 et45 245/40/17 rubs no more. | garfull | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 11-26-2013 07:41 PM |
