Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-15-2019, 10:44 PM | #15 |
Time Traveller
Yep, your TOB is on its' way out. Get it fixed soon.
You can optionally take the opportunity to upgrade the clutch, clutch fork with pivot, and either resurface or replace the flywheel at the same time. |
The Following User Says Thank You to DAEMANO For This Useful Post: | Evil Jesus (09-16-2019) |
09-16-2019, 09:29 AM | #16 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Evil Jesus (09-16-2019) |
09-16-2019, 10:54 AM | #17 |
Drives: 14 BSP Edelbrock BRZ
Make sure you get a new TOB from the dealer and tell them you want the part for a '17+. It is the only place you can get the upgraded unit. Only way to tell is that there will be a white or yellow paint dot on it when you get it.
The Following 2 Users Say Thank You to toast For This Useful Post: | Evil Jesus (09-16-2019), Tcoat (09-16-2019) |
09-16-2019, 11:06 AM | #18 | |
Make sure it part #SU003-07349 and has the dot like Toast stated. When I had mine done they were originally going to use the old part number which could have started the whole process over again.
09-16-2019, 11:23 AM | #19 |
Drives: '13 FR-S Raven 6MT
I had heard there was a new part. I'll be sure to get that one. Thanks for the part number and dot info.
EDIT: Hey, sorry to bother you, but do you happen to know the part number for the old TOB? Just want to be armed with the proper information tomorrow when I go in. Last edited by Evil Jesus; 09-16-2019 at 02:53 PM. |
09-16-2019, 03:55 PM | #20 | |
09-16-2019, 04:47 PM | #21 |
Excellent. Thank you so much.
09-18-2019, 02:37 PM | #22 |
So I took it in yesterday, 3 different techs looked at it. They said nothing is wrong and to just see if it gets worse.
09-18-2019, 02:50 PM | #23 | |
Drives: 2015 Subaru BRZ Series.blue
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
The Following User Says Thank You to Strife26 For This Useful Post: | Evil Jesus (09-20-2019) |
09-18-2019, 02:57 PM | #24 |
The Gunshine State
Drives: '14 BRZ Limited
Try another dealership.
Current DD: M235i |
The Following 2 Users Say Thank You to 8RZ For This Useful Post: | Evil Jesus (09-20-2019), Strife26 (09-18-2019) |
09-18-2019, 06:37 PM | #25 |
Drives: GTS 86
Throw out bearing, no doubt. Had issues with mine, opened up and voila...the tob was toast. At some point the clutch pedal got stuck at the bottom. Because I drove with it f..ed as it was, i had to replace the pressure plate too because it worn out the pressure plate legs. As a matter of fact I replaced the whole clutch with a brand new one, even though the clutch disk was still ok with some life left in it.
The Following User Says Thank You to Hawk77FT For This Useful Post: | Evil Jesus (09-20-2019) |
Similar Threads | ||||
High pitched chirping when AC on?? | Spectral Entity | Issues | Warranty | Recalls / TSB | 8 | 01-29-2021 05:50 AM |
whining/whirring noise during high load/rpm clutch engagement | 7thgear | Issues | Warranty | Recalls / TSB | 105 | 06-19-2017 11:04 AM |
Is it bad to have my ankle fully extended forward when pressing the clutch? | cat94 | Scion FR-S / Toyota 86 GT86 General Forum | 70 | 11-24-2016 04:10 PM |
high pitched noise when clutch is engaged ( video attached) | jotig | Issues | Warranty | Recalls / TSB | 9 | 07-05-2015 09:22 PM |
TSB - FRS (re: High pitched chirping...) | PNW FRS | Issues | Warranty | Recalls / TSB | 1 | 01-19-2013 01:05 AM |
