Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
04-02-2019, 10:45 AM | #1 |
Drives: 2013 ultramarine blue fr-s
INSTALLED NEW AXLE: LEAKING DIFF FLUID?
Recently installed new driver side axle after inner cv joint went bad. Everything went well until the next day when I went to change the diff fluid and found a large amount leaking from the side with the new axle and was covering the diff. I currently have no way to figure out if it is from a bad axle seal, improper installation, or not a good axle period. Am in college so have to wait a few days before I am able to check the car again. Thought I would try and be proactive and post this in the meantime. Axle was from Trackmotiv, bought on Ebay. Hope the pictures can help. Thanks.
04-02-2019, 11:04 AM | #2 |
Benz Tech
Drives: 2017 BRZ Premium
Clipped the seal on the way in? That or the ebay axle is junk.
The Following User Says Thank You to maslin For This Useful Post: | Tcoat (04-02-2019) |
04-02-2019, 11:11 AM | #3 |
likely you damaged the seal in the process of replacing the axle. You'll have to pull the car apart to find out which is bad. I would imagine if the axle was damaged enough to cause a leak you would have noticed it prior to install.
04-02-2019, 11:23 AM | #4 |
Geeeeez dude raise that car an inch. Based on the rust marks you have already clipped the diff a few times and the body structure is dam near worn through (looks like it may even be punctured at the top of the pic). You are flirting with serious damage if you crack that diff housing open or cause much more structural wear. I am lowered almost 2 inches and although I have a few scraps underneath it is no place near as bad as that.
Not to mention that you will just keep destroying axles. Nasty!
The Following 5 Users Say Thank You to Tcoat For This Useful Post: | BirdTRD (04-02-2019), FRSBRZGT86FAN (12-08-2023), Grady (04-02-2019), humfrz (04-02-2019), x808drifter (04-02-2019) |
04-02-2019, 11:44 AM | #5 |
Really hope its just the seal, looking back I probably should have gone for an OEM axle. The axle looked perfectly fine before install, but I'm worried it may not have been built to spec or has some random flaw, which could explain it leaking as well
04-02-2019, 04:57 PM | #6 |
Is it a used axle, a reman, or a new aftermarket axle?
Could take it out and mic it compared to your other if you are that worried about it. |
04-02-2019, 06:43 PM | #7 |
[insert cool phrase here]
Drives: BRZ Premium
Shit happens. You just need a new seal. A true pain in the ass for a $3 seal.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
The Following User Says Thank You to Mr.ac For This Useful Post: | Tcoat (04-02-2019) |
04-02-2019, 08:04 PM | #8 |
04-02-2019, 09:01 PM | #9 |
Drives: BRZ Premium
Oh shit that much?
04-02-2019, 11:05 PM | #10 |
Benz Tech
$17.40 full price from Subaru. Getting 3 in case you pinch it again?
https://parts.subaru.com/p/Subaru_20...031143009.html |
The Following User Says Thank You to maslin For This Useful Post: | Tcoat (04-03-2019) |
04-03-2019, 05:57 AM | #11 |
Drives: _
*Generally* speaking, Toyota OEM parts run slightly cheaper than Subaru OEM, for future reference.
04-03-2019, 10:22 AM | #12 | |
12-07-2023, 11:06 PM | #13 |
Drives: 2015 Scion FR-S Release series 1.0
Were you ever able to fix this issue? I'm also in the same boat.
Replaced both side axles, passenger side diff fluid leaking everywhere. I think I may have damaged the seal while removing the passenger side axle. I also did notice an elastic metal spring ring came out when removing the old axle. Didn't know that was part of the seal at that time, but right now I'm on the hunt for a diff axle shaft seal ASAP. Local Toyota/Subaru doesn't carry them in stock and only for special order. Going to try calling NAPA locations tomorrow or find other ways.. |
12-08-2023, 10:08 AM | #14 | |
Drives: 2013 frs base
Similar Threads | ||||
Dirty Clutch Fluid, leaking slave cylinder? | J41v33 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 11-22-2017 12:16 AM |
Axle Leaking Grease | 636 | Engine, Exhaust, Transmission | 14 | 07-20-2017 08:09 PM |
White smoke, burning smell, puddle of brown fluid leaking. | driftking96 | Engine, Exhaust, Transmission | 5 | 02-20-2016 01:54 AM |
Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 03:11 PM |
Brake fluid leaking from pistons/seals normal? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 12-06-2012 02:54 PM |
