Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
#15 |
High pressure or low pressure?
#16 | |
Oooooo - SHIT - wrong forum - strike those instructions ![]() humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | brzcui (03-25-2019) |
#17 |
Drives: 2014 supercharged brz
I mean so far i know, first owner went w the supercharger and something w the tune wasn’t doing good (flash tablet plug in tune), my guess is he went e85 without tune? So he sold the car for a steal w the modified parts to the second owner which i bought it from, the second owner didn’t expect anything to go wrong, drove it hard, blew the engine... swapper a new fa20, went to the tuner to get new ecu and tune and it seemed like a temporary fix and sold it to me when it was running ok... and im the idiot whos in this shit hole lmao
#18 |
OK, @brzcui which fuel pump was tested and showed low pressure -
![]() Get back to ol Tcoat - he missed my attempt at humor - ![]() humfrz |
#19 | |
#20 |
Wait there’s two fuel pumps???? They didn’t tell me which one, i thought there’s one fuel pump by the driverside backseat ?? What do you which one
#21 | |
No idea which if either is the problem with yours.
The Following User Says Thank You to Tcoat For This Useful Post: | brzcui (03-25-2019) |
#22 |
#23 |
Is low pressure pump and high pressure pump one thing together ?or is it two different location,as far as i know, they are going to replace the one under the backseat inside the fuel assembly, idk if that is high pressure or low pressure because i thought there’s one physical fuel pump inside the car
#24 |
All that poop talk in Random!
Not sure how you took those comments as grumpy though.
The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (03-25-2019) |
#25 |
Low in trunk
High in engine bay. High is the source of the "cricket" noises you have probably heard of.
#26 |
Benz Tech
Drives: 2017 BRZ Premium
There are two fuel pumps, an electric low pressure pump and a mechanically driven high pressure pump.
Edit: Tcoat beat me to it. |
The Following User Says Thank You to maslin For This Useful Post: | brzcui (03-25-2019) |
#27 |
Ok then they are replacing the high pressure fuel pump because they called me today saying the pump they r going with is dw300c or something like that, i looked that up its like the physical thing in the fuel assembly, idk if they are aware of the need to change the low pressure one? Maybe they assume i know what they are talking about and with their test data they found out the low pressure sends signal to high pressure about the mass air going in , and the high pressure fuel pump didn’t do its job and inject the amount of juel requested. Ya but is there a fix to the cricket sound? Its definitely not something I noticed a lot, i think the first owner did the exhaust super loud to cover that sound but when sometimes im going from neutral to first before going to high gears or slowing down in low gears i hear the cricket sound coming from the passenger side air van area
#28 |
E85/ fuel system components update | Sportsguy83 | Engine, Exhaust, Transmission | 36 | 01-19-2019 03:18 AM |
Fuel Filler Neck Problem | afohlin | Issues | Warranty | Recalls / TSB | 7 | 01-01-2014 01:13 PM |
Open Flash Tablet Manager Software (problem after internet update) | SloS14 | Software Tuning | 6 | 10-31-2013 03:33 PM |
Fuel Gauge problem | adan | CANADA | 2 | 09-24-2013 11:12 PM |
AFR Problem (maybe Fuel Pump installation bad) | whitefrs | Engine, Exhaust, Transmission | 37 | 08-30-2013 02:36 PM |
