03-08-2019, 05:04 PM | #141 | |
Regardless it's still a BS excuse to get off the hook for shit work. |
The Following User Says Thank You to ermax For This Useful Post: | Ultramaroon (03-08-2019) |
03-08-2019, 05:10 PM | #142 | |
03-08-2019, 05:52 PM | #143 | |
Drives: brz 2017 hksv2
What Magoo wrote about what dealer said, seems to me that they found something that gives them leverage against him, but what in particular? it would be also interesting for people who care about warranty of a new car but tune it without worrying too much I don't have access of course to the ecu like the dealers have, i just have a friend, that has a friend , that is a tech at a Subaru dealer and he said with a software called GTS (?) they can see a hystory of everything, rpm reached, eventual rpm overrange and don't know what else, and those things shouldn't just erase by themself with just a battery disconnect.. but got nothing more to it than that |
The Following User Says Thank You to tomm.brz For This Useful Post: | ermax (03-08-2019) |
03-08-2019, 05:53 PM | #144 | |
Drives: 2013 Scion FRS
They stopped short of calling me out on it, said it was consistent with what they've seen in the past with the ECU being reflashed and they were going to run with that and not take the blame. Sent from my Pixel 2 using Tapatalk |
03-08-2019, 05:57 PM | #145 |
So the best for people doing the recall is to just keep stock tune after the recall and wait a bit so if breaks like yours at least they won't have the dealer against them regarding if the ecu was reflashed or not
that s very unfortunate for you not much you can do about it.. |
03-08-2019, 09:06 PM | #146 | |
Unless he can find proof they made errors on the rebuild. For example it’s hard to blame a tune for a plugged pickup screen. |
03-08-2019, 09:36 PM | #147 |
Drives: 2013 Subaru BRZ
03-08-2019, 09:56 PM | #148 |
The Following User Says Thank You to humfrz For This Useful Post: | NoHaveMSG (03-09-2019) |
03-08-2019, 09:59 PM | #149 |
Drives: Car Collector
Picked mine up this morning. Seemed to run just as before during my 15 min drive home. I checked oil finding it at normal level and clean. Guess I will check to make certain it has antifreeze and not just replaced with just water
Odd thing is the odometer did not increase a single mile between drop off and when I picked it up. No test drive needed ??? Repairs done within 48 hours after I dropped it off. What stinks is normally the car would just sit in the garage for another couple of months waiting for dry / Spring weather. Now I feel compelled to put some winter miles in to find any recall work issues if present. |
03-08-2019, 10:02 PM | #150 |
chicken tonight
Added a quote to my sig line.
03-08-2019, 10:08 PM | #151 |
Drives: frs
The Following User Says Thank You to Teseo For This Useful Post: | Ultramaroon (03-09-2019) |
03-08-2019, 11:38 PM | #152 | |
humfrz |
03-09-2019, 12:26 AM | #153 |
chicken tonight
I have been expressing my professional opposition to this idiotic recall since I first heard about it. All the springs that were going to fail have already done so long ago.
03-09-2019, 02:00 AM | #154 |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | Ultramaroon (03-09-2019), why? (03-09-2019) |
Similar Threads | ||||
Valve spring recall - where did you get it done? satisfied with the work? | fiveoneoh | Northern California | 105 | 09-25-2020 02:10 PM |
Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
valve spring recall/ additional work performed when engine is out | swfrs | Issues | Warranty | Recalls / TSB | 172 | 07-31-2019 12:10 AM |
Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-08-2019 11:38 PM |
Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
