Member's Car Journals Car journals by our members. |
03-07-2019, 09:24 AM | #43 | |
Drives: 2015 BRZ
The Following User Says Thank You to Vital For This Useful Post: | Williampreza (03-07-2019) |
03-07-2019, 10:22 AM | #44 | |
Drives: 2017 Ice Silver BRZ Limited
The Following User Says Thank You to Williampreza For This Useful Post: | Vital (03-07-2019) |
03-07-2019, 11:07 AM | #45 |
Drives: 2015 BRZ
Would you mind posting a pic of your car with the RSR springs installed? Im just curious to see how it looks as those were one of the springs i had considered getting as well. There are not too many people running the Down springs mostly its the Superdowns.
03-07-2019, 02:13 PM | #46 |
BEFORE
AFTER |
03-07-2019, 04:24 PM | #47 |
Drives: 2015 BRZ
Nice and subtle. Looks clean
03-10-2019, 12:16 PM | #48 |
Drives: 2016 Scion FR-S
Bit of a noob here. I am also researching camber options for a new suspension setup. Why is it that more front negative camber is preferred when the engineers designed less negative camber in the front?
03-11-2019, 11:00 AM | #49 |
Drives: 2015 BRZ
Having more front camber is nice because it will allow to maximize grip around corners. Stock alignment specs are very conservative and are geared toward DD and not really any kind of performance driving.
03-11-2019, 03:34 PM | #50 | |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
OEM specs are usually geared more towards the low tire wear and overall safety side of the spectrum. Most cars will have more camber in the rear than the front, which can result in safety understeer from the factory. Having less camber can also help even out the tire wear over the course of a tires life. Sent from my iPhone using Tapatalk |
03-14-2019, 09:37 PM | #51 | |
03-14-2019, 10:02 PM | #52 | |
Williampreza's Kamaitachi: NA BRZ The "Easy" Way
In short, yes. That amount of - camber in the front will have a negligible effect on overall tire wear, but it will make a substantial difference for overall tire grip and performance. You will dig it. Sent from my iPhone using Tapatalk |
03-19-2019, 08:09 PM | #53 |
Some quick notes on lowering springs and current alignment setup. These are mostly for my own reference/journaling.
The car feels under-damped. Lots of bouncing on dips and crests. The unloaded side tends to feel hiked up and there's a bit of wallowing around long curves. Need stiffer dampers or could it be the stock bumpstops? The back end has an unnerving tendency to jump to oversteer, specifically when the rear gets unloaded in mid-turn, such as a corner going over a hill. It seems to catch itself quickly. A rear toe problem? It's almost time for tires, so an alignment adjustment might be in order too. Finally, I'm trying to pin down why the car feels less grippy now. It could be that the tires are worn. They're almost to the wear bars, and I've not been particularly easy on them. Could also be the alignment? |
03-19-2019, 10:07 PM | #54 | |
Hard to say over an internet discussion. If you increased the spring rates and kept the same tires, the car would feel like it has a bit less grip. Generally, you change the springs to cater to your tire choice, not the other way around. Apples to apples, upping the spring rate without upping the grip level will make the car feel skittish. It could be amplified by the car being a bit underdamped, but given your spring choice, I’m not sure...aren’t the “downs” pretty soft? Speaking of springs, are the spring rates quoted by the manufacturer actually the spring rates you are getting? Consistency in spring rates is a hard thing to accomplish in the world of aftermarket springs. That said, the bump stops could absolutely be adding to your issue. Now that you’re lowered, you are on the bumps tops constantly, which through a corner can upset the car pretty noticeably over inconsistent surfaces... As mentioned earlier, a bit of toe-in could help settle down the rear. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to BlueWhelan For This Useful Post: | Williampreza (03-20-2019) |
03-20-2019, 09:52 AM | #55 |
Drives: 2015 BRZ
Try getting better tires first and see if that helps. Also, when you installed the springs did you re-use the OEM bumpstops? or did you trim them a bit?
03-21-2019, 10:46 AM | #56 |
I reused them. I can use some modeling clay and a drive to see if there's interference (theoretically). When I installed the springs, I considered trimming, but there was no clear consensus on whether to trim or not and how much to trim for springs this conservative. I figured pulling things apart again to trim was the lesser of two evils. The other being a bumpstop cut too short.
Tags |
road car, rs-r down |
Similar Threads | ||||
2017 Alfa Romeo Giulia (pronounced "Julia") | DAEMANO | Other Vehicles & General Automotive Discussions | 255 | 03-07-2020 02:49 AM |
2017 PURE RED BRZ LIMITED "LOUBI" BUILD | SGTPanda | Member's Car Journals | 21 | 07-08-2019 04:18 AM |
Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 05:29 PM |
How easy/difficult is it to keep WRB "clean"? | ayau | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 32 | 06-17-2012 10:17 PM |
