Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-05-2019, 01:45 PM | #1 |
Drives: Subaru BRZ, Toyota MR2 Turbo
Racer X Intake manifold design, development, and results
As some of you know, we have been tinkering with the intake manifold for a little over a year now, with the most work being completed in the last couple of months. We have openly stated that we have tested 4 intake manifold variations, but we have actually tested 6 and we still plan to test 2 more variations. Let’s start at the beginning and we can bring this to our current stage of development.
Design: The plenum, runner diameter, and runner length were the primary concern. We started with a plenum size that was slightly larger than engine displacement and quickly found that airflow was bias to the rear cylinders which is not of much surprise. If you look at the OEM manifold, it’s quite simple to see that would be the case. The runners closest to the throttle body make it difficult for air to enter. With our plenum design we moved the rear middle section of the plenum forward, ran several CFD variations to find a happy medium of airflow to all cylinders and then altered the radius and angle to optimize further. This worked quite well and would prove out in testing (or so we thought). Next, we looked at runner diameter. We started with the intake valve diameter and multiplied this by 80%, all the way up to 120% (and slightly larger). We then used the closest runner diameters from standard material stock to find which diameter would provide the best velocity without hurting overall flow and in turn make best power. (We started with roughly 80% due to the fact that airflow passing the valve is not 100% efficient). Finally, we moved on to runner length, although this is slightly more difficult due to the fact that it must fit in the engine bay and be packaged with the plenum and flanges. The runner length would remain unchanged with the exception of manifold #6 which would require a runner length that was roughly 1.5” longer. Development: We started with the optimized plenum design for manifold #1. We used the smallest runner diameter and the standard runner length that would be used through out all of the testing. Manifold #1 would provide decent results at the beginning of the power band, but falls on its face around 5800 RPM. Our initial thought was the runner diameter is too small. Manifold #2 would increase runner diameter by 7% (I know doesn’t seem like any change would happen). We found similar results, gains through the majority of the RPM range, but again falling around 5800 RPM but making more power than manifold #1 (around 10 whp). With this increase in power we decided to go back to manifold #1 and check to see if there was any power gain from increase plenum size. Manifold #3 would increase the plenum size by 50%, the easiest increase would force us to comprise our optimized design. It would allow us to see if there were any differences or gains from increasing the plenum volume. The results would be quite similar to manifold #1, however there were slight losses in the bottom compared to manifold #1, but it would produce slightly more power at the higher end of the RPM range. We concluded from the 3 previous tests that we would keep the optimized plenum design for manifold #4 and increase the runner diameter again. The runner diameter increase would be 21% this time. We thought this would yield much better power at the higher end of the RPM range, but after testing the results did not provide much, if any gain over manifold #2. This an anomaly to us, why did manifold #4 produce such similar results to #2? The conclusion was quite simple and we ended up redesigning our cylinder head flanges to accommodate the reasoning. Manifold #5 was the same runner diameter, runner length and plenum, the only change would be the cylinder head flange. We determined the angle we used to open the flange was causing the airflow to decelerate enough that it was impacting overall power. Manifold #5 is currently the closest to overall power compared to the OEM manifold, with the exception of the low and mid RPM gains that can be seen in the graphs. For manifold #6 we decided to test an outlier that would share a plenum size that was similar to OEM. The OEM manifold uses quite a small plenum, we estimate the volume around 80 to 100 cubic inches. The plenum we designed would be smaller than that, at 50% of our original plenum size. The results were very interesting. Enough so that we plan to test 1 more that is larger with a few extra tricks. The gains from the small plenum in the lower RPM range are very impressive with gains of up to 20 whp in the torque dip, however it lacks the plenum volume and runner size necessary to provide the power that is needed at the upper RPM range. Manifolds #7 and #8 are currently designed. We plan to build and test them soon, however we would like some feed back from the community. Do you think this is a product that you would be interested in? We have spent a considerable amount of time designing, machining, and testing. What would be the ideal results you would like to see from an intake manifold? Looking forward to the feedback from the community, please let me know your comments and thoughts. Last edited by Jeff@Racer X Fab; 03-05-2019 at 08:23 PM. |
The Following 21 Users Say Thank You to Jeff@Racer X Fab For This Useful Post: | BatStig (03-05-2019), Carlitoz3 (11-10-2019), churchx (03-05-2019), Code Monkey (03-05-2019), conehead (03-05-2019), Detroiter (03-05-2019), DustinS (03-05-2019), D_Thissen (03-05-2019), G-awesome (03-05-2019), gtengr (03-07-2019), humfrz (03-05-2019), Joveen (03-05-2019), Lantanafrs2 (03-05-2019), nastynate88 (03-05-2019), new2subaru (03-05-2019), NoHaveMSG (03-05-2019), PulsarBeeerz (03-05-2019), sato (04-16-2019), Somerandom18 (03-10-2019), SuperTom (03-05-2019), weederr33 (06-28-2019) |
03-05-2019, 03:00 PM | #2 |
Drives: 2013 frs red
More midrange with equal top end would be nice but probably hard to attain. Nice work though. Impressive commitment on your part
The Following 4 Users Say Thank You to Lantanafrs2 For This Useful Post: |
03-05-2019, 03:04 PM | #3 |
OEM knew what they were doing with i.m. design.
The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Teseo (05-26-2019) |
03-05-2019, 03:20 PM | #4 |
That Guy
Drives: 2013 asphalt FRS MT
Are you testing these with the stock exhaust manifold? I haven't seen any reference to resonance tuning...? I highly doubt you didn't consider it, but I thought I'd ask.
I would be interested in this product, but it'll have to give decent gains across a good chunk of the power band while not losing anywhere. That ~7% lose in the top end is a hard pass but I look forward to what you come up with from here. I do appreciate your commitment and research. Thank you for sharing! |
03-05-2019, 03:36 PM | #5 |
Drives: 2014 GT86
Hmm, you were running with stock tune? Have you logged engine params apart from dyno performance numbers? Just that i think that some designs may have underperformed due stock ecu tune, not custom tailored to design of these manifolds. For example - what if different design means that at specific rpm range it's not so much that intake manifold optimisation itself is at work, but with stock tune/stock MAF nonrescaled sensor it may run too lean at some rpms, resulting in extra knock and tune retarding timings & robbing power? Or too rich, and not producing power it might have?
The Following User Says Thank You to churchx For This Useful Post: | Hawk77FT (03-05-2019) |
03-05-2019, 04:55 PM | #6 |
Drives: RS 2.0
I love the scientific method based testing you are using here, and the honesty in showing that it is pretty difficult to beat modern OEM design. That is sadly lacking in so much of the performance aftermarket.
I would be interested in any intake that could help reduce the torque dip without penalties in the top end, especially one as good looking as this. |
The Following 3 Users Say Thank You to conehead For This Useful Post: |
03-05-2019, 05:23 PM | #7 |
So hopefully there will be no more claims that the stock manifold is a "bottleneck "
The Following User Says Thank You to Lantanafrs2 For This Useful Post: | wparsons (03-06-2019) |
03-05-2019, 05:33 PM | #8 | |||
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post: | Calum (03-07-2019) |
03-05-2019, 06:27 PM | #9 |
Without a doubt this will stir interest. Especially with you guys being super transparent in the development process and saying the OEM manifold doesn't leave alot on the table. Some people don't want to spend the cash on the 2017+ red manifold and would like something like this with all the parts needed for install included and such. Also I can imagine CNC fabrication time is risky and may be expensive, so you might need to compare this all in cost to the cost of someone doing the OEM style red manifold install before mass market sale.
Also if someone like shiv from OFT can assist with OTS tunes for it and if the edits made can be done by everyone easily, it will without a doubt get buyers, I can imagine a uel, intake manifold and an OFT tune on a 2013-2016 car would be amazing. Everyone is looking for bolt on plug and play solutions these days anyway.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | BEZO760 (08-09-2019) |
03-05-2019, 06:45 PM | #10 |
Drives: 2014 GT86
Jeff: also what do you think of choosing different materials for prototypes? Plastic plenums, plastic/silicon hoses and such .. shouldn't it make much cheaper/quicker prototype turnaround (if not on-site adjustment)/requiring less work to test multiple configurations vs welded metallic one? Flexible hoses also should enable simpler testing of constructions less tied to cylinder location/manifold plenum size & shape, allowing eg. even longer runners, if one were to test longer then distance from cylinders and rigid plenum width. If some such temporary prototype of cut hoses config may show up promising, just then think of putting it into "iron", with putting extra length via extra bends, connection to back of plenum, not sides, for example.
Also .. do you still have stock resonators with your intake manifold or they are deleted? Shouldn't volume of them also be added to stock plenum volume, as it's "after" most restrictive bit, airfilter? That "reserve" probably will affect more throttle response, not flow |
03-05-2019, 06:47 PM | #11 |
Drives: JRSC BRZ SOLD
An alternative to the JUN IM is what I'm seeking. But rationality an extrude honed MY17 IM was my future choice.
I like the method you all are using however searching for gains in the torque dip was something even oem could never fix. Going catless with a UEL or 4-2-1 header solves this. The potential buyer who is looking for a IM already has a catless header and tuning software of some sort. Without running a catless header your setup isnt close to representative of potential costumers who all do. Your results will get even more interesting testing as a typical tuned system. |
The Following User Says Thank You to PulsarBeeerz For This Useful Post: | Hawk77FT (03-06-2019) |
03-05-2019, 06:49 PM | #12 |
Rust bucket enthusiast
Any plans to test this with forced induction upon completion? I'd be interested to see the results, and the ease of access to the intake ports would make resolving vacuum leaks there much easier..
Looks extreme, it's shiny, let's do it. |
The Following User Says Thank You to DarkPira7e For This Useful Post: | q335r49 (06-30-2019) |
03-05-2019, 07:15 PM | #13 |
Good research!
humfrz |
03-05-2019, 08:36 PM | #14 |
Drives: 2015 Firestorm Scion FRS
I have nothing constructive to say other than I love the dinosaurs on the graphs.
The Following User Says Thank You to G-awesome For This Useful Post: | J1Avs (03-10-2019) |
Similar Threads | ||||
Racer X Fabrication air intake design and development! | Jeff@Racer X Fab | Engine, Exhaust, Transmission | 45 | 08-01-2019 12:29 PM |
FRS / BRZ Intake Manifold - Development Thread - FT-86SpeedFactory by Velox | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 733 | 12-11-2018 10:13 PM |
2013 intake manifold vs 2017 Aluminium intake manifold | Bobster | Engine, Exhaust, Transmission | 29 | 12-19-2016 10:40 AM |
Project BRZ Intake Manifold Development | TurboBRZ | Engine, Exhaust, Transmission | 27 | 08-05-2015 07:44 PM |
Racer X Fabrication oil pan design and development! | Jeff@Racer X Fab | Engine, Exhaust, Transmission | 87 | 06-03-2015 11:10 AM |
