12-24-2018, 05:22 AM | #1219 |
Drives: 23 BRZ
Merry Christmas!
Short video of a PTuning BRZ on Christmas Eve night in Mexico. |
The Following User Says Thank You to rb6freak For This Useful Post: | Mrc@ptuning (12-27-2018) |
12-27-2018, 11:16 AM | #1220 |
Drives: S1000RR
01-03-2019, 06:22 PM | #1221 |
Drives: Black BRZ
Screw all you guys in this thread! This thread is just terrible for my wallet! LoL!
01-03-2019, 06:28 PM | #1222 |
Drives: Bone stock
01-10-2019, 03:30 PM | #1223 | |
Drives: Black BRZ
Aside from properly tuned FA20s blowing up there are plenty of issues popping up with the transmission not being able to keep up either. Have you had any issues with 3rd and 4th gear yet? Also, do you track the car a few times per year at least or is it strictly a street car? |
01-10-2019, 04:39 PM | #1224 | |
Drives: 23 BRZ
No issues with tranny. I change gear oil once a year with motul 75 90 if I recall correctly. I also don't run tons of power, 91 octane street ~9psi and 101 octane track ~12psi with more ignition timing advance. I'm tuned to 15.5 psi up to 7700rpm but I simply just don't ever switch to that max power on my maps/solenoid, no need to risk it. I tracked my first car dozens of times. My second one has only seen a few track days as I haven't been out to the track in a long while. Edit: Both cars I went turbo pretty much at a few hundred miles on the ODO. Block and tranny stock. |
The Following User Says Thank You to rb6freak For This Useful Post: | BlaqkHavok (02-03-2019) |
01-11-2019, 07:07 PM | #1225 | |
Drives: Black BRZ
Just to be sure, you have the GTX2867r, correct? At around what rpm would you say the kit reaches full boost and how would you compare lag to other kits that use shorter piping (i.e. pretty much all other kits that are using a front-mount turbo and, as a result, shorter piping). |
01-12-2019, 03:50 AM | #1226 | |
Drives: 23 BRZ
I'm running a 7lbs single spring in my CompGate40. I chose to configure my own boost solenoid in my case, rather than having the tune control it. The tune would be much better at reaching max boost faster than my AEM TruBoost. My boost controller is very simple and the way I set it up, it reaches max boost in a more linear fashion. It is a simple solenoid that is not referencing the actual MAP, only a predefined WG spring number and duty cycles. If I were to do it over again, I'd have my tuner control the boost. As for lag, I'm no expert. I've driven one other turbo BRZ with a Greddy turbo, it didn't feel as exciting is all I can tell you for comparison LOL. I do daily drive a newer WRX and my 2867 setup doesn't spool as fast as that turbo that's for sure. But my 2867 doesn't bitch out towards redline either haha. |
05-16-2019, 12:54 AM | #1227 |
Drives: 2014 DGM BRZ
Ok so quick question... freddy or anyone else in the community who has this kit... what rear swaybars you suggesting or using to complement the ptuning turbo front away? I'm installing this on a 2017 BRZ PP and would love to keep the same front to rear ratio on the swaybars as it is in stock form... pretty much want it to be the same balance to stock, just stiffer all around.. this is to complement a set of KW v3s(dont know if they are the newer spring rates or the legacy [f6k/r7k] springrates)
Thank you! |
05-21-2019, 01:28 PM | #1228 | |
Drives: 23 BRZ
I went with PTuning 18mm. https://www.ptuning.com/subdir/itemd...&ModelDesc=BRZ |
06-16-2019, 06:26 PM | #1229 | |
thank you |
06-17-2019, 10:54 AM | #1230 |
Drives: 23 BRZ
Can't help you there. I never drove this car stock, other than home from the dealer so I could install the turbo |
06-17-2019, 03:35 PM | #1231 |
Drives: 2013 Scion FRS
One of the advantages of our turbo kit is that since it is a mid mount turbo setup it keeps the weight lower. Our kit weighs under 100lbs, most of which is low mounted and near the middle of the vehicle. Because of this it retains a very balanced, like stock feel. We have corner balanced several of these cars with our turbo kit and it is close to stock in terms of weight distribution.
07-04-2019, 05:32 AM | #1232 |
Drives: Black BRZ
Just out of curiosity, I'm wondering if the owners in this thread were able to get some kind of a deal on this kit - perhaps even around black friday or holiday season or whatever it may be.
Would any current owner(s) be able to share via pm if they got a better price? On the website it shows $6,200 for the V2 kit with 2867R, I believe, and ohhhh MAN, is that priced in the stratosphere! |
Tags |
ptuning, turbo kit |
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
Full Blown Turbo Kit Owners Topic | King Tut | Forced Induction | 2637 | 12-27-2020 03:44 PM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 06:27 PM |
