Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-19-2018, 07:41 AM | #15 | |
Drives: raven FRS
IACRO RAVEN86
https://www.instagram.com/louislee0828/?hl=en |
11-19-2018, 08:54 AM | #16 |
Talk to them but most likely you would already have the later springs. All depends on when the short block was made though.
11-19-2018, 12:34 PM | #17 | |
Drives: 240sx, 2013 frs
And potentially they will not have sourced the engine from a used source. If it is new, then they also have a history of work performed |
11-19-2018, 07:55 PM | #18 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
A "long block" is crankcase and heads. So no, a short block would not have a fresh set of springs, even if the heads were taken apart for the rebuild process, it's original springs should have been reinstalled if there was no notice to do otherwise at the time. |
The Following 5 Users Say Thank You to RZNT4R For This Useful Post: | Gunman (11-21-2018), humfrz (11-19-2018), Rampage (11-19-2018), snk828 (11-24-2018), Summerwolf (11-21-2018) |
11-19-2018, 08:02 PM | #19 | |
Apparently I had a mind fart moment.
11-19-2018, 08:58 PM | #20 |
The Following User Says Thank You to gravitylover For This Useful Post: | humfrz (11-19-2018) |
11-19-2018, 09:33 PM | #21 |
The Following User Says Thank You to humfrz For This Useful Post: | gravitylover (11-20-2018) |
11-19-2018, 09:37 PM | #22 |
chicken tonight
brain diarrhea
The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (11-20-2018) |
11-20-2018, 12:20 PM | #23 |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (11-20-2018) |
11-20-2018, 04:05 PM | #24 | |
Drives: frs
11-21-2018, 10:20 AM | #25 |
That's what I'm hoping. I know it's time to change the plugs and I'm hoping they only charge for parts and a minimal labor charge rather than the regular $300.
11-21-2018, 02:55 PM | #26 | |
Drives: 2019 Mazda Miata RF
01-15-2019, 10:23 AM | #27 |
Drives: Firestorm
I am having my spark plugs changed. Rockingham Toyota is charging me a .5hr of work. plus the OEM spark plugs,
01-15-2019, 10:50 AM | #28 |
Rust bucket enthusiast
A half hour of work while they're doing the recall? They take the plugs out anyway, there's no way there should be any more labor to put in different plugs than what they took out
Similar Threads | ||||
Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
valve spring issue? | nikitopo | Issues | Warranty | Recalls / TSB | 1037 | 05-01-2019 10:55 PM |
Broken Valve Spring | sybrite | Engine, Exhaust, Transmission | 45 | 11-02-2018 04:20 AM |
Valve spring swap | rcmf5525 | Engine, Exhaust, Transmission | 6 | 05-19-2018 03:12 PM |
GSC FA20 Valve Spring Kits | MAPerformance | Engine, Exhaust, Transmission | 41 | 07-20-2015 10:22 AM |
