Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-02-2018, 05:27 PM | #1 |
Drives: 2013 Scion FR-S A/T
A/T CEL, Hard Downshift from 3-2,2-1
Hi everyone,
I’ve been having an issue with manual mode on my A/T 2013 FRS. Like the title says, my check engine light is on and upon downshifting from 3 to 2, or 2-1, it feels as though the car has completely forgotten how to rev match, and I feel a jerk forward as the rpm drudges to normal levels. The issue doesn’t happen in higher gears (6-5,5-4,4-3). There also seems to be a very low downshift limit. Normally, I can downshift even if I’m at 5-6k rpm, but ONLY in 2nd gear, I can’t downshift if I’m above 2.5k. I did some reading and am assuming this to be an issue with the transmission solenoid (?). Just want to find out if I can fix this myself or if I should take it to a transmission shop. Thanks in advance! (Also, yes I know; it’s because I drive an A/T) |
11-02-2018, 06:18 PM | #2 |
Drives: 2016 BRZ Limited, Stock
You really shouldn't be downshifting at 6k ever, or above 2.5k going into 1st (honestly why do you need to downshift into 1st?). I drive manual though so I can't really comment on the rest.
11-02-2018, 08:35 PM | #3 | |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
....but with this being the auto it should be a piece of cake...I was always only in M mode when I had my auto FRS and I would always engine brake, downshift & hit limiter back down into 1st at every stop light with no problems... as for OP I stopped at the check engine light. Clearly something is wrong with your car and you're asking about other issues? Do you even know what code is coming up? |
The Following User Says Thank You to HKz For This Useful Post: | whataboutbob (11-02-2018) |
11-02-2018, 08:59 PM | #4 |
Drives:
When was the last time you changed the trans fluid?
Sent from my SM-G965U using Tapatalk |
11-02-2018, 10:41 PM | #5 | |
AutoX-10/10ths every run
+1 on figuring out why you have a CEL first.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
11-03-2018, 11:32 AM | #6 |
@arkanist hahaha I know, just saying that even at that rpm on other gears I have the option to do so, but only on second, I don’t. @HKz Yeah, im gonna go get it scanned right now. I was just wondering what could potentially be causing these issues. I’ve had the issue before, but the CEL just kinda disappeared last time, literally on the way to the shop hahaha. @FL4WLSS less than two months ago. @whataboutbob on my way to do so right now!
11-05-2018, 07:19 PM | #7 |
Hi guys, so the CEL disappeared on the way to autozone but came back up today. Immediately went to get it scanned and P0351. After looking around, I’ve found that it’s a problem with my coil pack and I’ll probably be replacing it as soon as I can afford parts hahaha. Thanks for the help all!
11-06-2018, 05:50 PM | #8 | |
11-07-2018, 08:46 PM | #9 |
Tags |
a/t, automatic frs, cel, downshifting, transmission |
Similar Threads | ||||
How to Heel Toe Downshift | justinco | Tracking / Autocross / HPDE / Drifting | 3 | 06-04-2018 08:30 PM |
AT downshift issue | FRSBRZGT86FAN | Issues | Warranty | Recalls / TSB | 92 | 12-04-2015 01:11 AM |
Can't downshift while warming up | HMX-92 | Issues | Warranty | Recalls / TSB | 25 | 12-20-2014 02:20 PM |
CEL and hard downshift to 1st(AT) | KungFuWaffle | Engine, Exhaust, Transmission | 23 | 10-13-2014 10:49 PM |
downshift to first | swpbrz | Engine, Exhaust, Transmission | 13 | 05-07-2014 08:33 PM |
