Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
10-11-2018, 11:45 PM | #1 |
September
Drives: 2015 BRZ
2015 BRZ Shakes during burnouts??
Hey guys, I find this forum very helpful with car maintenances, interior, and etc and rn im having some issues with my right rear suspension/ differential?
I own 2015 brz with rays gramlights, lowered spring with hankook ventus v12 evo 2 (265) and during trial of burnout wet/dry surface as soon as wheels start to turn, right rear wheel starts to skip/ vibrate up and down. does anyone know solutions to this problems? im hoping to get new coilovers so i dont have to rely on lowered springs. Also if you have any recommendations for good coilovers and suspension mods help yo brother out with good infos |
10-11-2018, 11:56 PM | #2 |
Drives: 2013 Scion FR-S 10 Series
Read this thread and come back to us with questions:
https://www.ft86club.com/forums/showthread.php?t=29020 Why do you want to do burnouts in your car in the first place? |
10-12-2018, 12:26 AM | #3 |
Drives: Toyota 86 GTS
My 2015 does it too, with factory suspension etc. In the old days we used to refer to it as axle tramp and it only happens at low road speeds when spinning the rear tyres. I get no such effect if drifting, ie. there is a sideways component to the slide, it just spins and slides. If I'm going fast enough, and can spin the tyres on say a wet greasy road in third there is no shake either.
10-12-2018, 01:51 AM | #4 |
chicken tonight
Because it's fun.
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
10-12-2018, 02:14 AM | #5 |
Drives: 2014 GT86
There are lot of compliant bushings for these cars in transmission & suspension for comfort and to reduce NVH. Some of technical design decisions are for safety. They all add up that when your wheels are spinning in burnouts, that several components rattle/shake up a lot.
You can change that, eg. install less compliant aftermarket mounts/bushings, eg. rear subframe, diff, gearbox bushing & mount, engine mounts, but not without increased NVH during DD. Some shaking may be attributed also to two piece drive shaft, which is designed this way to fold in case of frontal accidents, to allow engine move down instead up straight, possibly injuring legs and shaft breaking off and piercing cabin or digging into ground and breaking something else in unexpected fashion. Everything is compromise, so not sure if not that frequent use type warrants compromising other areas. |
10-12-2018, 02:19 AM | #6 |
The Following User Says Thank You to humfrz For This Useful Post: | RJasonKlein (10-13-2018) |
10-12-2018, 02:37 AM | #7 | |
First off, doing "burnouts" in this car isn't doing it any favors, it's hard on the whole driveline and suspension. Second off, it doesn't have enough power to impress anyone with a chirp and a puff of smoke. Third off, you bought the wrong car to do burnouts. OK, it's old grandpa's med time - |
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
10-12-2018, 07:50 AM | #8 |
Drives: 2017 manual BRZ
Get poly or solid bushings for rear subframe and diff mounts. This helped a lot for me. Now only the transmission is shaking like mad instead of the entire car.
Sent from my Pixel 2 XL using Tapatalk |
10-12-2018, 10:15 AM | #9 |
Panda Trueno
Drives: No twin now.
All the people saying not to do burnouts, or you bought the wrong car.... stfu. It's a rwd sports car.
My guess is you're not using enough initial rpm to get it going or your tires are too sticky without enough power. A 265 is a decent sized tire for sure. You're getting what's commonly known as "wheel hop." Obviously changing bushings will help driveline vibrations, but my guess is not enough power for the tires / road surface. If you continue to have issues only on one side you can try a different half shaft (available in the aftermarket) on that side. Although that is a last ditch effort imo several manufacturers actually build different weights / diameters into their axle shafts to combat this very thing. |
10-12-2018, 12:13 PM | #10 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
[ame]https://www.youtube.com/watch?v=7f526kO7IMw[/ame]
"I gotta rock." -- Charley Brown |
10-12-2018, 01:30 PM | #11 |
Drives: '13 Whiteout
Yes stop doing burnouts. I pity the person that buys cars from these guys. The abuse I read about on this forum is frightening.
10-12-2018, 02:00 PM | #12 |
Panda Trueno
10-12-2018, 06:13 PM | #13 | |
Burnouts and drifting are significantly harder on a car than a track day...
The Following 2 Users Say Thank You to wparsons For This Useful Post: | TommyW (10-12-2018), Ultramaroon (10-12-2018) |
10-12-2018, 06:20 PM | #14 | |
Panda Trueno
What's worse? A 30 second burnout or multiple track laps at 8/10's? Lots of factors at play.... everyone is going to enjoy the car how they want to. |
The Following User Says Thank You to Summerwolf For This Useful Post: | HKz (10-12-2018) |
Similar Threads | ||||
RPM drops 200 rpm and shakes when coming to a stop | spatcha88 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 38 | 04-21-2015 07:27 AM |
Like burnouts? Give it some air. | D4S | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 06-03-2013 07:53 PM |
Video - Ebraking and Burnouts | Yruyur | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 10-17-2012 12:06 PM |
Car Magazines Shakes Down Toyota 86 at Killarney Track | ZakD | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 24 | 10-12-2012 02:07 PM |
burnouts | switchkick | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 09-07-2012 12:13 AM |
