Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
#29 | |
Drives: '06 AM V8V Coupe
The way to think of it is this, it takes more energy to spin the engine at 3000rpm or whatever it is at highway speed than the 700rpm it spins at idle. If you aren't stopping (aka throwing away all the vehicle's kinetic energy), then you want to optimize both energy usage (speed, engine braking) and energy production (engine load). |
#30 | |
Drives: 2008 STi
I've replicated these conditions with instrumented cars, both with scan tools and with an oscilloscope, measuring the leads leading into the fuel injectors. The signal controlling the injector is a 12-volt square wave. It's pulse-width-modulated, varying from 5 percent or so at idle to around 80 percent or so at full throttle. The higher the percentage of on time to off time, the more fuel. There's one on pulse for every cylinder firing, so the consumption also varies with engine speed (rpm). All vehicles show a short pulse width at idle, regardless of whether they're sitting in traffic at a red light or coasting downhill—at idle—in neutral. (Actually, they use a fraction more fuel sitting in drive at a traffic light, because of the drag in the torque converter, but I digress). Almost all vehicles show a pulse width of zero when coasting while in gear. Zero, as in there is no fuel injected at all. Yes, the engine is turning over, the pistons are going up and down, the water pump, alternator and a/c compressor are working, so technically you can say the engine is running, sort of. But it's not consuming any fuel. And that goes for automatic or manuals. Okay, eventually, at the bottom of the hill or as you creep up to the traffic light, the engine finally will slow to idle rpm—at which point the fuel injection will wake up and start adding fuel to keep the engine from stalling. That usually starts at around 1000 rpm, and if you pay attention, you can sense when it's happening as the engine will rev up slightly. And that's when the scan tool or oscilloscope will show injector dwell rise from 0 to 5 to 10 percent. So you're actually wasting gas by putting your car into neutral. I hear this argument as well: My car-mileage-information computer goes wild with increased mileage while coasting. The algorithm the trip computer uses is not based on how much fuel is actually consumed, but on some calculated value based on airflow past the mass airflow sensor, manifold vacuum and engine rpm. And it's not accurate under these coasting conditions. That's why when we report fuel economy here at PM, we never just print the numbers we read off the trip computer's display: We use the gallons pumped into the tank divided by the mileage on the odometer—which we check against a handheld GPS. I use a Scangauge II for a lot of diagnostics and general tinkering. It's a great tool—but I've learned not to trust the economy or gallons-used function too closely. That's why the Scangauge has a function that allows you to tell it what the engine-idle cutoff is for your particular car to get somewhere closer to the truth. Bottom line: Don't coast in neutral. It's dangerous and won't save fuel. Turning off the key at traffic lights might. Read more: Coasting in Neutral or Gear to Save Gas - Coasting and Fuel Economy - Popular Mechanics |
The Following 2 Users Say Thank You to Thunderchicken For This Useful Post: | 7thgear (07-13-2012), Sportsguy83 (07-13-2012) |
#31 |
Jesus christ, when were we talking about coasting to a stop light? I was talking about on the highway, and I said that many many times. Reading fucking comprehension. I know what deceleration fuel cutoff is.
#32 |
Drives: 2008 STi
My reading comprehension is just fine. The same thing applies on the highway you run your car up to XYZ speed release the accelerator and when you feel like you need to speed up you press the petal again. The time you are off the accelerator you are not consuming fuel because your injectors aren't running. There is no reason to be out of gear unless you are changing gears. It's plain unsafe to be coasting in neutral.
The Following User Says Thank You to Thunderchicken For This Useful Post: | Sportsguy83 (07-13-2012) |
#33 | |
Drives: 2008 STi
While I run my car to 70 mph let off the gas the ECU knows there is a load, but knows that the motor doesn't need to fire the injectors to keep the motor from stalling the car is happy to stay in motion without fuel because the load keeps the motor in motion. Yes my kinetic loss is going to be more but lets say it take 5 seconds to decelerate before i have to get back on the accelerator. so in summary I got 5 seconds of no injector spraying while you got 10 seconds of very rich idle fuel. Last edited by Thunderchicken; 07-13-2012 at 08:05 AM. |
#34 |
Drives: 01 Toyota Corolla / Porsche 911 C2
enough talking lol; i actually went out and did an experiment yesterday.
I did three types of highway cruising; Each test was along a flat section of the highway. I did the experiments consistently across roughly a 30 km (18.6 miles for you americans) stretch each (i was driving from niagara falls to toronto and was bored). All windows were open, Air conditioner was off; and stereo was off. After the results of each test, id reset the mpg counter and restart the next one. The tests: 1. in 6th gear; accelerating to 120kmph (74.56 MPH), lifting foot off pedal and letting car slow to 90kmph(55.92 MPH) without touching clutch or gear shifter. Average speed was ~105kmph (65.24 MPH). 2. Cruise control on 6th gear set at 105KMPH (65.24MPH). 3. Accelerating in 6th gear to 120kmph (75 MPH), putting it in neutral, coasting down to 90 (56MPH) ; then rev matching and accelerating back up to 120kmph (75 MPH). The results: 1. Coasting in gear: 32.7 mpg 2. Cruise control: 33.1 mpg 3. Coasting in neutral: 38.6 mpg After deciding coasting in neutral was the most efficient, i drove the remaining part of my trip like so. I turned on AC for the last bit noticed my idle rpm when coasting in neutral went from about 800rpm to 1.1k rpm. This dropped my coasting in neutral mpg from 38.6 to 37.8 Those are the results guys. p.s ive already started heel toeing two weeks into learning manual (^^,) EDIT: regarding thunderchicken's post. Sure you get 5 seconds of no fuel, while we get 10 secs of rich idling, but at the end of the day; you have to get on the accelerator pedal twice as many times as we do. |
The Following User Says Thank You to Saibot For This Useful Post: | serialk11r (07-13-2012) |
#35 | |
Senior Hoonigan
Drives: 2016 Hot Lava 6MT FR-S
![]() The right pedal is an investment, the middle pedal throws your money away ![]() This car is quite capable of whipping around corners at speeds, and you can use that to your advantage by braking only when necessary, or only to the speed necessary to safely negotiate a corner. Braking is evil! |
#36 | |
Drives: 2008 STi
#37 |
? I'm not stating instantaneous mpg, but average over a trip. Instantaneous would have infinate or near infinate mpg during coasting.
#38 | |
Drives: 2008 STi
315.2 miles driven / 11.223 gallons filled = 28.09 miles to the gallon by the way that was my '02 Honda Si just filled up this afternoon with no highway miles on this tank. |
#39 |
Master Troll
Drives: 2013 BRZ Limited
If you are that concerned with gas mileage, I think you should have gotten a VW diesel. Seriously? That much effort to save MAYBE $1.00 per tank?
#40 |
The Following User Says Thank You to serialk11r For This Useful Post: | Thongpocket (07-22-2012) |
#41 |
i'm sorry, what?
Drives: Canada
but you'll spend half an hour writing up a scientific argument?
#42 |
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado | huma | BRZ First-Gen (2012+) -- General Topics | 15 | 06-14-2012 11:33 AM |
pulling e-brake with auto tranny | carbonBLUE | Engine, Exhaust, Transmission | 2 | 05-16-2012 04:27 PM |
How strong is tranny? | theaero | Engine, Exhaust, Transmission | 14 | 04-27-2012 07:51 AM |
MT vs AT tranny... better MPG, 0-60? | subatoy | BRZ First-Gen (2012+) -- General Topics | 163 | 03-26-2012 06:08 PM |
Manual tranny takes another step into oblivion | madfast | Other Vehicles & General Automotive Discussions | 82 | 03-06-2012 09:40 PM |
