Northern California NorCal |
09-20-2018, 08:51 PM | #1 |
Drives: Sold 16 FRS, 22 Neptune 86 on order
Ticket for smoked tail lights and exhaust
Hey everyone, sorry if this isn’t the right place for this post. Today I got pulled over, reasons being my smoked Valentis and my loud exhaust (understandable). I was under the assumption smoked valentis were DOT approved. The officer told me if I can find documentation from the manufacturer saying it is approved, or if I take it for inspection and they check the lumen output of the taillights. My questions are, where can I find this document (if it’s out there), and where do I go for this inspection? Sorry if this is a stupid question, I can’t find more info and this is my first interaction like this. Thank you all
09-20-2018, 09:06 PM | #2 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Kushkaki (09-20-2018) |
09-20-2018, 09:20 PM | #3 | |
Drive 2 Eat, Eat 2 Drive
Drives: FUN SUPERCHARGED 2013 Limited BRZ
I don't recall where I read it before but there is a code that states that the light output of rear taillights need to be clearly visible up to x-amount of feet (I believe it's close to 1000 ft.) You could probably google this and it'll come up. Mainly to keep you from getting rear ended and what not. Imagine if you were behind a black car at night with lights that were just blacked out and you could barely, BARELY, make out that they are stepping on their brakes. I also believe CHP stations have a system that can measure if your lights are actually emitting enough light.
The Following User Says Thank You to FUN BRZ For This Useful Post: | Kushkaki (09-20-2018) |
09-20-2018, 09:28 PM | #4 |
Drives: 2014 Subaru BRZ
You'll have to go to a State Inspection center to get proof that your exhaust is/has been "fixed" to be below 95.00 Db, The officer should have given you some information on how to scheduled the inspection.
The'll be able to test your lumen output there as well |
The Following User Says Thank You to VIP BRZ For This Useful Post: | Kushkaki (09-20-2018) |
09-20-2018, 09:47 PM | #5 |
09-20-2018, 10:16 PM | #6 |
09-20-2018, 10:18 PM | #7 |
Thank you! The officer told me i need to be at 80 DB, is 95 the actual limit? Because I’m catless headers and no muffler, and hoping just putting the muffler back on will solve the issue.
09-20-2018, 10:19 PM | #8 | |
09-20-2018, 11:12 PM | #9 | |
09-20-2018, 11:23 PM | #10 |
helmholtz resonator
Drives: '15 ultramarine
Catless header, no muffler, blacked out lights = giant sign saying "pull me over".
It worked. Good luck getting it cleared up. I would put a legal exhaust back on. They will notice at the inspection station and you will be worse off if you pull up without the cats. |
The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
09-20-2018, 11:49 PM | #11 | |
09-20-2018, 11:57 PM | #12 | |
helmholtz resonator
The Following User Says Thank You to Sapphireho For This Useful Post: | strat61caster (09-21-2018) |
09-21-2018, 01:01 PM | #13 |
Drives: 2017 DGM BRZ PP
Just a heads up, I'm pretty sure Valentis don't have enough reflective surface on them to be CA legal. I've heard of someone getting pulled over and they had to put some reflective tape on their tails to make it compliant. You might get hassled about that as well.
The Following User Says Thank You to Horrid_Funk For This Useful Post: | Kushkaki (09-21-2018) |
09-21-2018, 01:11 PM | #14 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Put all your cats back in, stock intake, etc. Not worth the risk of multiple trips, extra violations, etc. |
The Following User Says Thank You to finch1750 For This Useful Post: | Kushkaki (09-21-2018) |
Similar Threads | ||||
VA smoked tail lights | VirginiaBRZ | Mid-Atlantic | 0 | 11-10-2015 10:54 PM |
WTT OEM tail lights practically new for Spyder V2 tail lights smoked red | KungFuWaffle | Exterior Parts (Aero, Lighting, Etc.) | 1 | 06-10-2015 12:26 PM |
FS: Smoked LED Tail Lights | 86_ZN6 | Exterior Parts (Aero, Lighting, Etc.) | 9 | 07-28-2013 01:08 PM |
Smoked tail lights with vinyl | FAC3M3LTER | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 04-28-2013 12:29 AM |
FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 08:38 PM |
