Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-17-2018, 04:38 PM | #1 |
Does this exists?
I'm looking for a quiet catback, or better an axle back, in 60mm with just resonators and no mufflers.
Do you know if this exists? |
07-17-2018, 04:39 PM | #2 |
Drives: 2015 BRZ Limited
anything without a muffler is going to make more noise than stock. you might be better off changing your exhaust tips if you want the look without the noise.
07-17-2018, 04:55 PM | #3 |
Site Moderator
Drives: ichi 86 Project
This? Namelss Single exit without muffler. FYI it's louder than stock. Even muffler ver was louder.
07-17-2018, 04:57 PM | #4 | |
https://shop.namelessperformance.com...r-s-2013-2016/ humfrz |
07-17-2018, 05:24 PM | #5 |
I am with humfrz, mufflers muffle sound. Resonators resonate sound. Not sure you can get quiet without the muffle.
07-18-2018, 12:53 AM | #6 |
Supersprint just use resonators, and they are very quiet. But the one for 86 is 63 mm.
07-18-2018, 02:01 AM | #7 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | fika84 (07-18-2018) |
07-18-2018, 05:52 AM | #8 |
Drives: 86
Can I ask why 60mm is required and 63mm is unsuitable?!
07-18-2018, 07:10 AM | #9 |
Nope, Supersprint just uses resonators in its exhausts, even the version with 1 resonator, it has Y drilled pipe inside. 63 mm moves torque toward high revs.
07-18-2018, 08:02 AM | #10 | |
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
07-18-2018, 08:58 AM | #11 |
Drives: 86
You will be lucky to have any horsepower or torque difference with a catback so 3mm either way isn't going to shift your torque curve.
You said the supersprint has the resonators and the volume you want and basically the size you want. I'd just go with that. Don't get hung up on paper specs. |
07-18-2018, 09:35 AM | #12 | |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
I agree somewhat with your concern for pipe diameter. I would go with keeping the piping the same as what is coming off your header/overpipe. For example I had Gruppe-S UEL with overpipe that ended in 60mm. Therefore I went with An Invidia FP an HKS catback 60mm. This keeps VELOCITY consistent all the way through. Now I have just installed ACE 350 Headers/overpipe that end in 63mm(2.5"). So I just now ordered a Hooker HF cat/Helmholtz J-pipe Front pipe, And Agency catback exhaust all 63mm (2.5") Will there be a huge change in HP/TQ I doubt it. But I like knowing the flow will be consistent all the way through without either bottlenecks (too small piping) or too slow velocity (too large piping).
07-18-2018, 09:38 AM | #13 |
I'm also with @humfrz I can't find a version of their exhaust WITHOUT mufflers... https://www.supersprint.com/ww-en/to...-hp-12-16.aspx
Maybe the terminology or translation is different? Are you thinking of the Catalytic Converter? |
The Following User Says Thank You to fika84 For This Useful Post: | humfrz (07-18-2018) |
07-18-2018, 12:03 PM | #14 | |
humfrz |
Similar Threads | ||||
Racism and igorance still exists in America? | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 03-09-2011 02:37 PM |
