Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-11-2012, 11:39 PM | #1 |
Drives: Scion FRS raven
EBC dimpled/slotted rotors installed
Hey guys,
Just installed new front EBC rotors, they are dimpled and slotted with black zinc. Easy installed, roughly 15-20 minutes. Looks great, the black zinc comes off right away but it leaves the dimples/slots black and the centre area is black which I like. Got them through a friend that works at a supplier in Toronto. Last edited by kleung93; 11-11-2012 at 11:50 PM. |
11-11-2012, 11:44 PM | #2 |
Now w/ over 400 womprats!
Drives: BRZ LZR
I like it! It looks slick!
- The Ancient BRZ Sacrament by Zaku |
11-12-2012, 12:18 AM | #3 |
Drives: 2013 Subaru BRZ
looks great
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
11-12-2012, 12:21 AM | #4 |
Drives: FRS :D
Have these on my old civic dd works great compared to stock
Out of the FRS game
06-12-2018, 11:39 AM | #5 | |
GT86PersianClub
Drives: 2014 Crystal Black Silica GT86
this is the noise
Follow Me on Instagram: @Stock_GT86
Admin & Founder of @GT86PersianClub Nur Spec Body-Rays Gramlights 57Xtreme-Rays Dura Nut L42 Straight type Lug nuts-EBC Brake Rotors-K&N Filters-D2 Racing RS Coilvers-GReddy EVOlution GT Catback-HKS Dual Resonated Front Pipe-JDL Catted UEL Header-Valenti FT86SF tail light & 4th Brake light |
06-12-2018, 11:45 AM | #6 |
helmholtz resonator
Drives: '15 ultramarine
Got the same for the Lotus, but the slots and dimples aren't coated. @Tcoat says they are good quality.
06-12-2018, 11:51 AM | #7 |
What are you running for pads?
06-13-2018, 05:52 PM | #8 |
GT86PersianClub
im on OEM pads but im changing it to EBC Greenstuff in 2 weeks
06-13-2018, 06:03 PM | #9 |
helmholtz resonator
06-19-2018, 12:15 PM | #10 |
Drives: NSX, G35, E36 328i racecar
Looks good! What are you doing for lines?
06-19-2018, 03:05 PM | #11 |
Stock is generally fine for most people. I put stop tech lines on mine when it was < 1 year old and it was slightly better, but not really noticeable on the street that much. Just replaced the stop techs with Goodridge lines, they're definitely a higher quality line and the price was about the same. I only replaced mine because it sees enough track time to justify replacing the lines every couple years. The lines are different than what is pictured here: https://www.ft86motorsports.com/brak...-fr-s-brz.html They actually look like this: They have the curved hard portion of the banjo fitting on the rears just like the spiegler lines, and the tab that mounts to the rear knuckle or front strut has a nice solid extension to prevent the line from being pinched if it shifts around while tightening the bolt.
Similar Threads | ||||
DBA T3 rotors fitted | AVOturboworld | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 04-16-2013 02:28 PM |
FS [WA] GTS Rotors(Ventilated) | stevo_12v | Australia Classifieds | 0 | 10-21-2012 04:47 PM |
OptionJDM - DBA Rotors | OptionJDM | Brakes, Suspension, Chassis | 6 | 07-21-2012 11:50 AM |
StopTech Slotted Brake Rotors (Front/Rear) for BRZ/FRS at Redline360 | Redline360 | Brakes, Suspension, Chassis | 0 | 07-13-2012 10:58 AM |
DBA 4000 T3 Slotted Rotors for BRZ/FR-S at Redline360 | Redline360 | Brakes, Suspension, Chassis | 0 | 07-07-2012 12:41 AM |
