Old 06-08-2018, 08:37 PM   #1
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
JRSC C38 with an RS Pulley
I can't seem to find any information on people running the RS racing pulley for the JRSC C38 blower? I would assume at this power level people go turbo, but it's definitely interesting. Obviously you'd need forged everything, but what kind of power gains would you expect to see over the high boost pulley?
majixmatrix is offline   Reply With Quote
Old 06-09-2018, 02:52 AM   #2
valtore101
Drives: 2016 FR-S
The C38-80 blower will do 450+HP with the right supporting mods and this pulley. Fueling, MAP, and headwork/cams would be necessary in addition to built internals.
valtore101 is offline   Reply With Quote
Old 06-11-2018, 08:00 PM   #3
GrabTheWheel
Drives: 16' BRZ
I would love to see this also. I don't think you'll ever see a C38 with 400whp on anything but a dynapack dyno. Someone please prove me wrong...
GrabTheWheel is offline   Reply With Quote
Old 06-11-2018, 08:10 PM   #4
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
We currently had a customer put down over 400hp at the wheel on a AT with a Built motor and the RS kit. We don't know the full extent to his build. One of our Time Attack sponsored cars put down over 500hp.
Depending on your build you will likely see a number around 450hp.
Our shop car with the High Boost Pulley put down nearly 400hp.
Jackson Racing Staff
-Chris
Jackson Racing is offline   Reply With Quote
Old 06-11-2018, 11:54 PM   #5
D-rek07
How much boost does the RS pulley put out? What fuel is necessary to support that boost level?
D-rek07 is offline   Reply With Quote
Old 06-12-2018, 02:23 PM   #6
Jackson Racing
Drives: JR FR-S,
its about 17psi. Race Fuel or E85 is needed.
-Chris
Old 06-12-2018, 02:33 PM   #7
valtore101
Drives: 2016 FR-S
-Chris
I'm asking this for a "friend" who has interest in an ignorant build with the rotrex sc.
Has anyone looked into the C38-91/92 blower? According to the data sheet from Rotrex, the 91/92 model has an even higher output. Is it just not feasible to use one of these with the stock rev limit? Or not able to de-tune enough for reliability on stock internals?
Old 06-13-2018, 10:04 AM   #8
D-rek07
-Chris
What boost levels are okay to run on CA 91 octane? Would lowering the compression ratio increase the amount of boost possible on CA 91? But does lower compression ratio and higher boost create the same hp/tq of higher compression and lower boost?
Old 06-13-2018, 05:31 PM   #9
Jackson Racing
Drives: JR FR-S,
The simple answer is Yes. It has been done.
The real question is What is the goal for the build? And would it be beneficial to upgrade?
You mentioned stock internals. If that is one of the goals, the C38-81 is MORE than enough.
-Chris
Old 06-13-2018, 05:46 PM   #10
Jackson Racing
Drives: JR FR-S,
Anything more than the standard pulley requires a higher grade than 91 to make more power. Lowering the compression does allow you to run more boost, and it is possible to make a little more power on 91, however does the money spent on a full engine build justify the amount of power that you would make? Probably not.
-Chris
Old 06-14-2018, 01:16 AM   #11
GrabTheWheel
Drives: 16' BRZ
Chis, I know most of your customers are more into track performance than dyno numbers but that being said can you please post a dyno? Preferably one that isn't from a hub type dynapack. The highest numbers I've seen are 370 whp on Church's dyno with E85 and the HBP.
The Following User Says Thank You to GrabTheWheel For This Useful Post:
Nightflo (06-18-2018)
Old 06-18-2018, 05:19 AM   #12
Nightflo
Nightflo's Avatar
Hey! That’s my car you saw! Lol, I took it a while back when I installed the HBP. It was stock internals and I was only E65(there’ was still 91 in my tank) generally I get E82 when I fill up around my area. I have DTFlexfuel so it tells me my ethonal content.
Nightflo
Fresno, CA
BOOSTED ‘15 BRZ
Since ‘14
Nightflo is offline   Reply With Quote
Old 06-18-2018, 05:20 AM   #13
Nightflo
Nightflo's Avatar
If you have any questions about the build PM me
Nightflo
Fresno, CA
BOOSTED ‘15 BRZ
Since ‘14
Old 06-18-2018, 01:32 PM   #14
SPCorBUST
SPCorBUST's Avatar
@Nightflo
Originally Posted by SPCorBUST View Post
Pretty sure he means this. That was my dyno.
I'm on my 6th setup right now and was thinking of trying the C38 with the RS pulley. I don't know any public builds that have gone this route yet.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
c38, high boost, jrsc, pulley, supercharger
Anyone of JRSC or Edelbrock? tian105 Mid-Atlantic 11 10-02-2017 11:56 AM
JRSC &a Delicious Tuning VABeachBRZ Forced Induction 6 08-10-2017 04:44 PM
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2017 11:39 PM
JRSC oil use xsnapshot Forced Induction 3 03-27-2016 10:22 PM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
