Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-15-2017, 09:23 AM | #29 | |
Drives: Subaru BRZ Limited
The Following User Says Thank You to JoeC For This Useful Post: | lutfy (05-15-2017) |
05-17-2017, 11:57 AM | #30 | |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Rears were static -1.9 and -2.0 spot on. THANKS a lot guys. This car desperately needs front camber and am excited for the next event where it will be a NASA (Time Trial) TTE contender. Cheers, Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
The Following User Says Thank You to lutfy For This Useful Post: | strat61caster (05-17-2017) |
05-17-2017, 12:08 PM | #31 |
Drives: 2014 GT86
-2.2 was not sufficient for me to fix uneven wear/ripped tire outside on track. I guess, one needs -3 minimum for that. Unfortunately that's above what can be got with camberbolts alone.
The Following User Says Thank You to churchx For This Useful Post: | strat61caster (05-17-2017) |
05-17-2017, 01:09 PM | #32 |
I'm worried about this... next event is in two weeks and I'm hoping someone has a pyrometer handy so I can try to evaluate my tire wear
05-17-2017, 01:18 PM | #33 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
It always depends on driver and setup but yeah, -3+ is usually the ballpark it seems
05-17-2017, 01:28 PM | #34 |
Drives: 2014 GT86
JoeC: don't mind too much. Yes, very probably camber will be insufficient .. but some is better then none/stock-ish "0deg". At least handling/extra grip wise improvement will be felt, even on very same tires. And while wear still uneven, better then if with stock alignment.
More camber .. one will have to start sacrificing something. Like irreversibly modding parts, eg. slotting struts, or adding camber plates, which will mean more spendings and less compliancy/more NVH, due all camplates being pillowball mount. (cursing Whiteline for inability to make non failing Com-C mounts for twins, would be hole grail for my preferences/car use) Hmm. And you wrote "TRD springs"? Lowering? And you have just one set of camber bolts, right? Then IIRC you should be able to go to -2.5 on lowered car, by installing camber bolts in upper hole too (Whiteline KCA416) in addition to SPC in lower hole. |
05-17-2017, 01:33 PM | #35 | |
Churchx, based on your experience, is -3 degree possible with slotted struts? My goal is to get a set of MCS Remotes and they can be ordered with the slots at the bottom. Wondering that get to the desired high two low three neg camber. Pillow balls or solid ones are too rough on the roads where I live, there is already too much drama in the neighborhood, last thing I want is a car with rattles and such as I will be driving to and from the track with occasional DD. Cheers, Lutfy
05-17-2017, 01:55 PM | #36 |
Drives: 2014 GT86
With extra slotting - certainly possible (-3.3/-3.1). But if suspension gets heavy hits, imho bolt may slip there, getting alignment out of whack.
I've heard though advices that using paint /fingernail paint or blue loctite/or epoxy in place, while sounds hack-ish, may help prevent slipping. Otherwise recall reading to NOT use camberbolts in slotted holes. Though then again, why not use full strength bolt in eg. upper slotted hole, and then fine-adjust with just one camberbolt in lower, non slotted? Ideally one should weld on one side extra material/washer (above simple DIY skills/tooling needed), or use inserts similar to these (often used in rally coilovers (thus should be proven to hold up to heavy abuse) coilovers to get fixed amount of offset in slots (should come with different hole offsets) - you keep both reliability & adjustability. P.S. If you mentioned to be able to order customized .. why not ask instead of slotted to drill hole excentric to stock location in first place? P.P.S. At some point one should be careful, that wheel/tire, depending on width/offset, may start to rub, if adding camber on just one end (camberbolts/slotting @ lower end of coilover), not also at top (with camberplate). Last edited by churchx; 05-18-2017 at 01:31 AM. |
05-17-2017, 01:59 PM | #37 | |
Thank you again. Makes sense. I will discuss it with MCS when ordering the shocks. Cheers! Lutfy Sent from my iPhone using Tapatalk
05-17-2017, 07:26 PM | #38 |
FYI, usually the paint is to show if something has moved or slipped, not as a lock tight substitute. We mark many of the suspension bolts and parts to show what has to be readjusted after an incident.
05-18-2017, 01:20 AM | #39 |
Drives: 2014 GT86
Is1ac: depends. Some may use it as indicator .. but some may use it exactly to reduce slippage/locktite substitute. Check some of those links, there people clearly are stating for what for they were doing that.
EDIT crap. Seems that i misinserted for most of links same url :/. Going to fix that Last edited by churchx; 05-18-2017 at 01:32 AM. |
05-29-2018, 03:30 PM | #40 |
Drives: 2017 WRB Subaru BRZ Sport-Tech
Bringing back old thread...
Hey guys, prepping to install camber bolts up front. Form what I gather in this thread I have two options:
1. Run SPC bolts (81305) in bottom hole and move the OEM 14mm crash bolts to the top. OR 2. Run SPC bolts (81305) in bottom hole and Whiteline bolts (KCA416) in the top. Can anyone tell me if they are running the first option and how it's holding up, or if it's better to spend more for the second option. Thanks! |
05-30-2018, 06:15 PM | #41 | |
Drives: 2017 DGM BRZ PP
The Following 2 Users Say Thank You to Horrid_Funk For This Useful Post: | Richard_BRZ (05-30-2018), strat61caster (05-30-2018) |
05-30-2018, 06:17 PM | #42 |
Similar Threads | ||||
Camber Bolt Help Please! | ft86Fan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 114 | 02-27-2019 11:13 AM |
Camber bolt on KW V3 | derek1ee | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-25-2017 11:21 AM |
Camber bolt | bhbnuckle | CANADA | 3 | 04-16-2014 08:05 PM |
Camber bolt help | oofie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-22-2013 01:36 PM |
