Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-23-2018, 12:58 AM | #1 |
Drives: 2017 toyota 86
Trans mount Cusco collar vs Whiteline insert
Don’t ask me why, but I already have both.
I am unsure which one to install / is better? I figure they both work pretty well, which one has least NVH? Or pros and cons to both? This is a DD that I can’t stop throwing away money on... basically want a fun streetable DD, for rare track days. I already have sti motor mounts, whiteline diff support insert, whiteline subframe bushing inserts. |
04-23-2018, 01:27 AM | #2 |
Drives: 2014 GT86
I might be wrong, but IIRC whiteline limited gearbox movement just vertically, cusco's also longitudinally. Don't have these, have Perrin's, which works more like Cusco's i guess. I hear now slight supercharger-like gear whine at lowest gears (probably at others too, but drown in road/tire noise at higher speeds). It's quiet/not loud, so i ignore that.
04-23-2018, 11:41 PM | #3 |
Whiteline will add hardly any nvh. The perrin will add some aforementioned gear whine. You'll also hear the tranny turning over when you're in neutral. Easily liveable. I made the hole in the whiteline insert larger to accommodate the perrin, so I'm using both, which is cool I guess
04-24-2018, 01:15 AM | #4 |
I wonder if I could toss the lower big washer part of Cusco and use both. Trying to clean up a little drivetrain slop with least amount of NVH.
Tags |
cusco collar, mount insert, transmission mount |
Similar Threads | ||||
DIY - Whiteline Rear Crossmember Mount Insert Bushings | F1point4 | DIY (Do-It-Yourself) Guides | 91 | 01-17-2021 02:23 AM |
FS: Whiteline Subframe Insert Mount Bushings (KDT926) | bombardius | Brakes, Suspension, Chassis | 2 | 04-16-2016 10:49 AM |
fs: Perrin trans mount and whiteline trans bushing | RWD_FR-S | Transmission and Driveline | 1 | 01-02-2014 05:34 PM |
FS: Kartboy Short Shifter w/Rear Bushing & Trans mount insert | Opie | Transmission and Driveline | 4 | 09-16-2013 05:43 PM |
Whiteline diff bushings and trans mount insert. | Simmons | Transmission and Driveline | 7 | 06-09-2013 08:45 PM |
