Old 01-01-2017, 06:58 PM   #85
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by CygnusX1 View Post
Well strange...on the CAE website you can find this anodised blue...but it's not named WRB.
I'm sure that means they can do it, I am also sure they can't advertise that specific name for copyright reasons.
why? is offline   Reply With Quote
Old 01-02-2017, 02:05 PM   #86
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
If this becomes available for the newer STIs, I might just do it lol.
The looks of it alone makes me want it. Even if it felt not different than stock haha
Old 05-27-2017, 10:06 PM   #87
15limited
15limited's Avatar
Did any of you guys utilise the bottom plate that mounts from under the car, up to the CAE base? Factory bolts weren't long enough to go through the factory shift base, cae base and still have enough thread to get nuts on the bottom side of the plate. Having a hell of a time trying to get the cae rubber boot to stay on the base while on the car. Any help appreciated, thanks!
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 06-04-2017, 10:46 PM   #88
15limited
15limited's Avatar
Anodized black and titanium silver knob
Old 06-05-2017, 08:47 PM   #89
tony-brz
tony-brz's Avatar
Drives: '17 BRZ PP
I really want one of these. To those that have it can you please try to articulate the change in NVH ?
tony-brz is offline   Reply With Quote
Old 06-05-2017, 08:52 PM   #90
15limited
15limited's Avatar
Originally Posted by tony-brz View Post
I really want one of these. To those that have it can you please try to articulate the change NVH ?
It's a bit hard for me to tell besides a bit more tranny whine, you'll definitely hear it. I suspect it's partly from removing the oem rubber shift boot but by no means deafening. I actually noticed less vibration that the BPS Short throw I had before this.
Old 12-10-2017, 07:57 PM   #91
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
are there any rattle issues like the IRP shifter with this?
Surok is offline   Reply With Quote
Old 12-10-2017, 10:50 PM   #92
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
would it be possible to rotate the nut at the end of the reverse cable to the side so that you do not need to hack the console apart?install a low profile nut, weld the cable etc.
Old 12-25-2017, 02:23 AM   #93
15limited
15limited's Avatar
None
The Following User Says Thank You to 15limited For This Useful Post:
Surok (12-26-2017)
Old 01-13-2018, 05:16 PM   #94
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Not without extensive modifications.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
Surok (01-14-2018)
Old 02-16-2018, 05:52 PM   #95
Kordless
Drives: '13 BRZ Limited
Can anyone help out with getting the shifter to feel right?
I bought mine used and installed it on the car. How do you tune the centering spring properly? Also what does that 17mm nut on the back of the shifter do? I'm having trouble making 3-4 smooth and the centering function is just too tight.
Thanks,
Kordless is offline   Reply With Quote
Old 02-16-2018, 06:18 PM   #96
15limited
15limited's Avatar
Thanks,
I don't think there's adjustment for the spring, just small Allen head set screws to control left to right movement. Do you have mtec shift springs installed too? I do and it's not for the limp wristed shifts I usually throw. Try little dabs of lube in movements parts as tolerances are exceptionally tight and dirt/dust may hinder smooth shifts.
Also, I remember if you don't have the base mounted just right it can fight your shifts a little, I had to go back and forth between moving the base, tightening and rowing through the gears a few times. I believe upgraded trans and engine mounts are recommended too if you didn't do those.
Sent from my SM-G950U using Tapatalk
why? (07-27-2019)
Old 02-18-2018, 02:15 AM   #97
Kordless
Yes I have the MTEC springs. I'll probably be taking those out.
Thank you!
cae ultra shifter
Perrin Rear Shifter Bushing Install F1point4 DIY (Do-It-Yourself) Guides 55 10-21-2021 02:39 PM
Shifter wobble after Kartboy install ? Simon99 Engine, Exhaust, Transmission 5 04-13-2015 12:06 AM
Shifter rattles after CF driveshaft install? Venz1028 Engine, Exhaust, Transmission 5 03-28-2015 02:43 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Shifter bushing install Bullnettles Engine, Exhaust, Transmission 4 06-20-2013 04:36 PM
