#18187 |
Drives: 2013 Gt86
Just took my '13 gt86 to the dealer to replace the driver door window, that was badly scratched. Warranty repair even though the car is almost 5years old
![]() I'll get it back after job |
#18188 |
ಠ_ಠ
Drives: 860 SansOverspray
Realized some punk keyed the passenger side of my car, from the mirror to the top of the rear wheel. Paint chipped at the gap beween the door and quarterpanel. Luckily none of the panels bent.
[ame="https://www.youtube.com/watch?v=VO48Vr4KIc8"]My sentiment[/ame] |
The Following User Says Thank You to mrderp For This Useful Post: | Adam_L (01-15-2018) |
#18189 |
Drives: 2013 frs
Hi guys didn't want to make a new thread for this simple question
Was checking under the hood today only to realise that one of my pulleys is wobbling .. is this normal and if not how do I fix it? Sent from my SM-N950W using Tapatalk |
#18190 |
Drives: 2015 FR-S
No problems there, that's normal.
The Following User Says Thank You to Impureclient For This Useful Post: | Young_makaveli (01-13-2018) |
#18191 |
Weight Weenie
Drives: 15 FR-S
As said above, normal. That's the belt tensioner at work.
The Following User Says Thank You to new2subaru For This Useful Post: | Young_makaveli (01-13-2018) |
#18192 |
Drives: 2013 frs
Thanks for the reply guys !
Does yours wobble like in my video? It's my first time noticing this that's why At first I thought it was an idler pulley but if it's a tensioner I guess that makes sense for it to have some sort of play Good to know it's normal 😁 Sent from my SM-N950W using Tapatalk |
#18193 |
Drives: 2015 FR-S
Just started up to see exactly how much it moved and without using a light like you did, it's hard to say.
It seems like a little less, like if yours is moving 1/16" back and forth, then mine looks like 1/32". You have a bright light on yours so it could be just seeing it lit up amplifies the visual movement some. Nothing to adjust since it's adjusts it self. Good to go! |
#18194 | |
Drives: 2013 frs
Appreciate your input 😁👍👍 Sent from my SM-N950W using Tapatalk |
The Following User Says Thank You to Young_makaveli For This Useful Post: | Impureclient (01-13-2018) |
#18195 |
Drives: .
Drove it with a buddy from work through the mountains! A picture before we took off!
![]() Last edited by ERA; 01-14-2018 at 10:48 PM. |
The Following User Says Thank You to ERA For This Useful Post: | HachiRokuX (01-29-2018) |
#18196 |
Drives: GTS 86 auto
I believe LED bulbs use less battery. I fitted the brightest compatible one and WOW is it bright and nice and white (not that weak yellow glow). While I was at it I changed the black (DOH??) interior of the light housing to white with correction fluid. Al foil would work but might make an unwanted electrical connection.
GTS86 Auto (Australia)
The Following User Says Thank You to notout86 For This Useful Post: | StraightOuttaCanadaEh (01-15-2018) |
#18197 |
Country Boy 4 Life
Trying a new look...
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | Overdrive (01-21-2018) |
#18198 |
The Following User Says Thank You to humfrz For This Useful Post: | Leonardo (01-15-2018) |
#18199 |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Ohhhh, if Tony Montana would have been there.... big party, forget the cars!
Math is like Love, simple idea at first that quickly gets complicated
#18200 |
Drives: Silver FRS
It has been a long time since I have posted on this forum.
Installed the Perrin transmission mount and Perrin shifter bushing Here is how she currently sits @thornleanMotors on Instagram if anyone is interested. ![]()
The Following 12 Users Say Thank You to Thornley For This Useful Post: | 86geek (01-16-2018), Adam_L (01-21-2018), Kestrel (01-15-2018), Leonardo (01-16-2018), MJones_RB (01-19-2018), monkeybike (01-15-2018), MrSkubi (02-05-2018), new2subaru (01-21-2018), olsonpg (01-15-2018), Overdrive (01-21-2018), stranger things (01-16-2018), Street_Shark (01-21-2018) |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
