Member's Car Journals Car journals by our members. |
10-11-2017, 09:43 PM | #1 |
Poor Adult Male
Drives: 2013 Subaru BRZ
LS3 HPDE / Time Attack Build
This is my BRZ.
It has always been a DD/trackday car, and will continue to be one. Some modifications before the swap: -Ohlins Road and Track Coilovers w/ Swift 9k/9k springs -SPC Lower Control Arms -Racesceng Camber Plates -Racesceng Strut Mounts -Whiteline Positive Traction kit -Whiteline Differential Bushing kit -Whiteline 22mm front swaybar -Whiteline 18mm rear swaybar -AP Racing BBK -JDL UEL Ceramic Coated Header -JDL Overfrontpipe -Nameless Muffled Track Pipe -Velox Diffuser -Velox Splitter -Perrin Oil cooler -Velox AOS w/ Drainback -Innovate gauges -Nexus 7 + OBD interface -many more mods Stay tuned for the sound of freedom
The Following 7 Users Say Thank You to RavioliG For This Useful Post: | dattran86 (10-12-2017), DustinS (10-12-2017), Iceman (10-12-2017), pgranberg11 (10-13-2017), ScoobsMcGee (10-13-2017), Summerwolf (12-20-2017), Vic4uf (10-13-2017) |
10-11-2017, 09:49 PM | #2 |
Poor Adult Male
Apologies in advance for any unfinished thoughts. I'll clean everything up as things move along.
Weight Last time I had the car weighed, it came in at 2680lbs. Weight of FA20 and transmission: 480lbs Weight of LS3 and Tremec Magnum XL transmission: ~578lbs Total theoretical weight up: 100lbs Total theoretical weight of car: 2780lbs F/R theoretical weight distribution: 52/48. WAY better than stock (56/44) due to the weight of the trans and how far back the LS will sit. Here's the vorshlag thread on the entire swap going into detail on this. http://www.vorshlag.com/forums/showt...?t=8275&page=2 Engine In order to not surpass the limit of the NASA TT2 of 8.0 weight to horsepower, I will be capping my competition tune power at 380whp (250 + 2780 / 8). But on the street tune, I'll let it rip to whatever it wants to make. Considering the stock C6 GS would dyno around 381/375, I am going to guess that with the 2.5" catless exhaust system, the power output will be similar to this one below: To keep the engine cool, I'll be using an oil cooler and better radiator. Plaguing the LS3 are also oil starvation issues. To get around this, I'll be running an an Aviaid 3 stage dry sump system and mounting the 3 gallon dry sump tank in the trunk. Another advantage of doing this: I can retain my whiteline front swaybar due to the added clearance. I'll also be using an accusump to to prime the engine with oil in order to reduce internal wear before the pump can build pressure. Something like: Drivetrain For the trans, I'll be using a close ratio Tremec T56 Magnum XL. I already have 600hp DSS axles. I'm going to run the stock diff until it explodes and then change to an OSGikken unit. Currently, I'm running 255/40/17 Maxxis RC1s. In order to put the power down on the track I'm going to try and fit the widest tire I can on an 18x9.5 without cutting my fenders. Currently looking at Toyo Proxes RRs in 275/40/18. Practicality I need the car to fully integrate with my existing Subaru FI system. I do plan on keeping it road legal (no inspections in ohio). It just so happens that part of what I do at work involves working with CAN networking. I'm hoping in the end, i'll have working everything on the meter, and of course, no lights on. I will retain the OBD functionality of the GM FI, and run my nexus bluetooth gauges in order to monitor vehicle data The car in the end will be very similar to the LS3 S13 that the MotorTrend boys built, only the chassis won't feel like a wet noodle. The weight of their 240ss comes in at 2808lbs, running a 0-60 time of 4.1s, and the 1/4 mile in 12.3s at 120.7mph. I watch their video to hype myself up when things get slow: [ame="https://www.youtube.com/watch?v=bL4kIk8mXSk&t=513s"]1993 Nissan 240SX Part 4: The 240SS Is Born! (With the Help of an LS3) - Ignition Ep. 120 - YouTube[/ame]
10-11-2017, 09:59 PM | #3 |
Poor Adult Male
Have been waiting for parts since October. Car has been ready to go. Work began on the engine, took off the wiring harness, stock oil lines, accessories, and finally got it up on the stand.
10-11-2017, 10:17 PM | #4 |
Drives: 2014 Subaru BRZ Limited 6MT SSM
So in.
Love red on these cars, goes really well with the black trim (usually not a fan of red cars). Really interested to read the story behind the two FA20s blowing up. Makes me a little paranoid... |
The Following User Says Thank You to ApexEight For This Useful Post: | RavioliG (10-12-2017) |
10-11-2017, 10:33 PM | #5 |
Drives: 2017 WR BLUE BRZ
Nice! Should be able to get some cash back from those headers! Looking forward to watching your build.
The Following User Says Thank You to ILLSMOQ For This Useful Post: | RavioliG (10-12-2017) |
10-12-2017, 07:56 AM | #6 |
Driver
Drives: 2013 Whiteout FRS
this should be interesting
10-12-2017, 11:28 AM | #7 |
Drives: 2013 Ultramarine FR-S
Glad to see you posting a build thread!! Can't wait to see the swap progress. Good Luck and if you have any questions, feel free to ask.
The Following User Says Thank You to DustinS For This Useful Post: | RavioliG (01-31-2018) |
10-12-2017, 12:31 PM | #8 |
Drives: 2013 WRB BRZ
I'm local. Any chance for a ride when that thing is done?
The Following User Says Thank You to slipdog For This Useful Post: | RavioliG (01-31-2018) |
10-12-2017, 12:52 PM | #9 |
I just Drive.
Drives: in the womb still
Sooo I am going to be the **** head here....
You list your mods and say you blew up your motor twice, but yet I do not see a modified oil pan or anything to say you went after oil starvation/temp oils?? If so, what did you attempt since it may be beneficial to any to know if it is worth even trying to keep the FA20 for racing.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
10-12-2017, 08:39 PM | #10 | ||
Poor Adult Male
For sure!! Quote:
I think the FA is fine, as long as it gets an oil pressure gauge, oil cooler, a high quality oil, and most importantly.. an accusump. While I did use a cooler and best oil out there, and I never saw above 235F or below 45PSI on track, I should have probably ran 5w-30 instead of 0w-20 with an accusump.
10-13-2017, 07:30 AM | #11 |
JHerbert Racing
Drives: 2013 Scion FRS
Yikes. So many FA20s blowing up on the track this year it's really making me uneasy about mine.
Sub'd.
10-13-2017, 07:30 AM | #12 |
Same! If you ever make it back to an autocross in Cincy/Dayton!
10-13-2017, 08:38 AM | #13 |
BoostedBRZ
Drives: Turbo BRZ
yikes, this reminds me of my own BRZ. it went on the track too. the rod snapped in half. I'd love to see where this goes. good luck!
12-20-2017, 03:30 AM | #14 |
Drives: 2015 Toyota 86
subbed!
Similar Threads | ||||
Joel's BRZ - Low Budget Time Attack Build | DIY | Member's Car Journals | 403 | 12-11-2023 05:59 PM |
Amor Autosport U-RWD LS3 Time Attack Build | AmorAutosport | Member's Car Journals | 50 | 05-19-2018 01:47 PM |
King Tut's Time Attack Build | King Tut | Member's Car Journals | 225 | 05-15-2017 01:44 AM |
Robispec TIME ATTACK Build | robispec | Tracking / Autocross / HPDE / Drifting | 254 | 11-18-2014 04:27 AM |
The time attack build by Rob | SavingManuals | Member's Car Journals | 8 | 04-27-2014 08:01 PM |
