#57 |
Drives: 2005 Toyota Camry
#58 |
The Dictater
Drives: '13 Red Scion FRS
The BMWs were probably slow because of new drivers not hitting their shift points. Shifting properly in a BMW has a steep learning curve, as unlike other cars the stick is located in the middle of the drivers seat.
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
#59 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Hmmm. What else runs in your class/group? Other than the Mini.
Slow is smooth, and smooth is fast
#60 | |
http://speedventures.com/results/Def...id=-1999999043 If I wasn't forced to run the all-season tires I drove to/from Austin on, I probably would've been around 2:50 or so on timing. Instead, stupid me mounted a tire wrong, tore it up after it lost pressure, and couldn't get below 3:00 all day. |
#61 |
Drives: '13 BRZ
That's right, when people say "the 86 can't even pass cars on the highway", what they really mean is that they are unable to pass GT3 and Z06's that are at WOT.
Or, just maybe, if you can't pass a cruising car that is doing the same speed as your car on the highway, you don't know how to drive a stick. Last edited by LudwigMiles; 09-11-2017 at 09:02 PM. |
The Following User Says Thank You to LudwigMiles For This Useful Post: | stevesnj (09-12-2017) |
#62 | |
chicken tonight
![]() Actually, I've come back to re-read and I feel a little torn. I also play in the passing/oncoming lane in order to stay accustomed to being there. I also practice aborting a pass. I'm repeating stories but when I was 13 I watched a woman hit a motorcyclist head on in a panic move. She pulled out from between two semis to pass. When she realized her error, instead of backing off, she dove for the shoulder on our side; the same place the motorcyclist went. Watched the whole thing go down while my dad calmly slowed to avoid being part of the mess. I may be overly sensitive to it but I think passing is an under-appreciated skill.
#63 |
How do I shift?
Drives: '13 GBS BRZ
The proper, safe way to pass is to make sure you are doing 1 mph above the driver on the right, that way you can keep your eye on them and watch out for any sudden move. By doing that, you also prevent cars behind you from trying to push you off the side. Maintain control of the speed and eventually you will make a safe pass and you'll be able to go home to your kids.
#64 |
How to pass:
[ame="https://www.youtube.com/watch?v=u13cDmKpo-4"]Just ordinary day of dashcam in Russia - YouTube[/ame] |
#65 | |
chicken tonight
#66 | |
Persona Non Grata
#67 |
Persona Non Grata
Sarcasm?? I apologize if you're just playing along.
The Following User Says Thank You to Capt Spaulding For This Useful Post: | Ultramaroon (09-11-2017) |
#68 |
chicken tonight
#69 | |
Persona Non Grata
Between 2 semis is a really uncomfortable place to be. That said, these guys cannot afford to get tangled up with a car. If you need to get around slow down enough to force the guy behind to give you some room. Stick your nose out and take a peek. If it's not clear then move back over and wait for an opportunity. Use geography. Uphills will slow these guys down. Use the chance to carve out some maneuvering room. See if you can make the pass after the crest. A little patience and a bit of planning will help immensely. i'm sorry you had to witness the MC collision. I can certainly understand the trauma witnessing a catastrophe like that can cause. When I was about 20 I was on my way home late one night after playing tennis with a friend and watched in my rearview mirror as a guy in a pick up took a corner at a speed neither he nor the truck could pull off. He slid into a curb, rolled the truck, was ejected and run over by the truck. We made a quick U-turn and went back to render aid. The driver was conscious when ems picked him up, he died on the way to the hospital. It's not the stuff of nightmares, but I'll never forget his name. I sure as hell don't have all, or even most, of the answers. I'm convinced, however that far too many people are behind the wheels of cars who should not be. And a big problem with most of them is they are not drivers - they are simply operators. They don't take their responsibility seriously. And, people die.
#70 |
Tags |
odds on b& b4 october? |
PA EZ-Pass Screwup? | FRSBRZGT86FAN | NY / NJ / CT / PA | 5 | 12-23-2015 01:04 PM |
WTB: oem hood, pass fender, pass headlight, front bumper. | trboboostr6 | Want-To-Buy Requests | 5 | 10-19-2015 01:24 PM |
Snoqualmie Pass | Limit | Northwest | 3 | 12-29-2014 05:03 PM |
by-pass oil filter? | aznatama | Engine, Exhaust, Transmission | 2 | 06-16-2014 01:32 PM |
WTB: FRS OEM PASS MIRROR | cdlc | Canada Classifieds | 0 | 05-10-2014 06:48 PM |
