Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-08-2016, 07:45 PM | #57 |
Drives: '13 FRS - STX
Only a bit, was more interested in the spring/top hat cup interface, you've got pics of the top of the mounts, but not the bottom. It seems like the spring is located via a 60/65mm ID lip but I don't want to make a $300 gamble on that.
Totally see what happened to you though, the specs for damper shaft diameter are not published on any site that sells the Beatrush that I've seen (or I'm blind), seems like they're meant for OE or OE replacements and many damper manufacturers use a standard size across their lineup that may not match with OE. Which agrees with your measurements, that spacer/bushing should fit an M10 thread which includes OE, Ohlins, Bilstein, KW, Koni, etc. but not brands like Fortune Auto, MCS, and RSR (which you're measuring just under 12 so I assume it's M12 like the others). And if that bushing is threaded or there's a special nut that comes with it the thread pitch could also reduce the compatibility by a lot. |
02-26-2016, 01:53 PM | #58 | |
The Fail Boat
Drives: CWP S.B.
Beatrush Suspension Products (Unboxing, Install, & Review)
Hi just wonder how does the transmission spacer feel? And noise level? I know Custco makes a metal spacer, but it seems beatrush one is much better for daily. Mind sharing your thought? Thank you. Sent from my iPhone using Tapatalk |
02-26-2016, 03:57 PM | #59 | |
Drives:
I'll be installing my HKS v3 supercharger and other performance mods soon as well as a couple more non-suspension Beatrush parts. I'll post my experience with the transmission mount bushing spacer once I get her back on the road. However, I won't be able to give a naturally aspirated opinion about the part. __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix |
04-13-2016, 11:05 PM | #60 |
Drives:
It's been a while since I last posted in this thread... fortunately I feel that my 86 will be back on the road soon. Many of my Beatrush suspension upgrades will be subjected to more power so there should be a feeling out period perhaps some tweaking.
For now, check out this non-suspension Beatrush goodie... Pictured below is the Beatrush air intake duct. Because I am in the middle of my HKS supercharger pro kit v3 install, I do not know if I will be able to use this duct without modification... I will know soon though. Also, there could possibly be a fitment issue with my Beatrush front beam brace and my HKS intercooler... I'll know the answer to that soon as well. This thing is beautiful! __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix |
The Following User Says Thank You to zeal86 For This Useful Post: | Koj (09-06-2016) |
07-02-2016, 04:20 PM | #61 |
Drives:
The Following 4 Users Say Thank You to zeal86 For This Useful Post: |
07-05-2016, 01:08 PM | #63 | |
Drives:
__________________________________________ projekt zeal86 build |
The Following 2 Users Say Thank You to zeal86 For This Useful Post: | Kami Speed (07-05-2016), Koj (09-06-2016) |
09-26-2016, 02:27 PM | #64 |
Drives: 2015 BRZ Limited ISM
A big thank you to zeal86 for the detailed instructions. I installed the Beatrush rear member support rod and the front member support bar along with a Beatrush underpanel and Cusco front lower arm bar braces.
This post was a huge help in the install as well as my decision to go ahead and purchase the Beatrush products. They do improve the ride as well as go a long way to tighten up things as well. Very happy with all these products I put in. Thanks again for all the detail. |
The Following 2 Users Say Thank You to Gin Ryuu For This Useful Post: | Kami Speed (09-26-2016), zeal86 (09-26-2016) |
11-11-2016, 06:04 PM | #65 |
Drives:
I love the finish of all my Beatrush parts... In fact, I modified my build's theme to incorporate the Beatrush gold instead of painting or powder coating over the color.
Since I will be installing a harness bar from Essex Parts Services, I wanted to paint it Beatrush gold to go along with my theme and create some contrast in my interior. For those interested, the output color code my friend's spectrometer spit out is shown in the accompanying image. __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix |
07-14-2017, 11:35 AM | #66 |
Drives: Scion FRS 2016
___________________
2016 MT|Varis Arising II body kit with carbon add-ons|Aimgain x Stancenation Spoiler|Valenti Japan Jewel headlights|Valenti 4th Brakelight|ST-X coilovers|SPC LCA|18x10 TE37RT|Hankook Ventus RS3 265/35|Work Chrome blue lugnuts|Corsa catback|JDM TOM's red taillights|JDM armrest|TRD carbon Fender garnish|Beatrush Rear bumper brace|Cusco front strut |
07-14-2017, 11:59 AM | #67 | |
Drives:
The Following User Says Thank You to zeal86 For This Useful Post: | JT.86 (07-14-2017) |
Similar Threads | ||||
Ohlins Road & Track for FRS/BRZ suspension install/review thread | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 628 | 01-30-2024 05:16 AM |
OEM armrest unboxing/review | supramkivtt2jz | Cosmetic Modification (Interior/Exterior/Lighting) | 508 | 11-22-2017 06:27 AM |
The Ultimate LED Switchbacks VLED V3 Tritons Unboxing Install Review & Coupon | Yruyur | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 01-10-2014 05:59 PM |
Sonar (Spyder) Tail Light Unboxing and Review | Yruyur | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 10-20-2013 03:42 PM |
DIY Unboxing and Install of JDM CLEAR SIDE MARKER LENS! | MrGamer | DIY (Do-It-Yourself) Guides | 11 | 07-07-2013 10:19 PM |
