Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
07-10-2017, 05:47 PM | #15 |
Drives: 1980 corvette, 2014 Subaru BRZ
from Texas, we can 100% overheat tires. single driver maybe on your 5th run if its hot(100+) out, have a co-driver and spraying them down after each run you will get 3-4 runs each before they go.
The Following User Says Thank You to G-Man For This Useful Post: | strat61caster (07-10-2017) |
07-10-2017, 06:00 PM | #16 | |
Drives: '13 FRS - STX
As above it's an autocross setup. Like mentioned elsewhere in this thread, for a general performance setup on an NA 86 7.5" and 8" wheels are going to do you good but I'd only do that if you wanted to run a 225 tire, 215 fits great on a 7" wheel and it doesn't need to be stretched imo and you can save more money by sticking to a lightweight 7" (I'm doubled down on that opinion after seeing a new BRZ with 7.5" wheels and stretched OE 215 Michelins, I drive another car with 225's on 7.5). I'm sure some will disagree on that. Also as above MPSS are good street tires that hold up to abuse better than most but they're not some magic transformative thing that'll turn your car into a Lotus level corner carver. Pretty much no tire above 200TW is. What are you actually going to do with your car OP? The tl;dr is yes, the wider wheels/tires are bought by people who want the traction for track/autocross OR for looks, totally unnecessary for just driving around. (As a tip, it's pretty easy to tell based on the tire they're running, Bridgestone RE71R, BF Goodrich Rival-S for autoxers, Dunlop Z2SS, RS3/RS4, RE11, Rival (non-S), Nitto, etc. etc. for track. Anything with lots of little tread blocks: just for looks) Based on the questions I think you're overthinking it, just grab something that looks good to your eye, <20 lbs, if you go with 7" stick with OE tire sizing, 7.5 and 8 jump up to 225's, and don't put 225's on 7" wide wheels and you'll be a happy camper (caveat being for competitive autox 225 w/ 7" is worth losing the steering feel). Also, don't go staggered (wider in the back) |
The Following 2 Users Say Thank You to strat61caster For This Useful Post: | G-Man (07-10-2017), Icecreamtruk (07-12-2017) |
07-10-2017, 06:07 PM | #17 | |
I can see it being the case that it's hard to get up to temp (I struggled for awhile getting heat in my Bridgestones last year) especially in colder regions and with short <40s courses, but that's definitely not universal, tire sprayers are common at competitive events out here for people to cool off tires between runs. |
07-10-2017, 06:33 PM | #18 | ||
Proud of BOXER
Drives: Subaru Boxer
Hey I DD 245/40 RE71R!
But I'm also a moron. Quote:
The Following 2 Users Say Thank You to Clipdat For This Useful Post: | mrg666 (07-13-2017), strat61caster (07-10-2017) |
07-10-2017, 06:54 PM | #19 |
Hey if you can use 'em up within a year at least you're posing hard.
If you're still running 'em next year and they're not bald you should be exiled to the old man car meets next to the Cadillacs with original whitewalls. |
07-10-2017, 11:22 PM | #20 | |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
You're forgetting one extremely important fact: the sidewall height. For example a 235/45 is significantly taller than stock and that elongates your gear ratio, so you accelerate slower and therefore feel very noticeably heavier. 245/45 would be awful. I run a 235/40 (can't get PSS in that size tho unfortunately) for this reason: light, wide, and a better rear end gear ratio. The car felt instantly lighter going to them from 225/45/17 PSS despite the combo actually weighing .5-1 pound more.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
The Following User Says Thank You to Keenercarguy For This Useful Post: | chaoskaze (07-12-2017) |
07-11-2017, 12:02 AM | #21 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Some people do it because they plan to go forced induction in the future and in some states in Australia having a wider wheel and tyre for the increased torque and power makes it easier to get the car engineer certified so you can drive it without having to worry about getting pulled over by the local police and slapped with an unroadworthy certificate.
07-11-2017, 11:45 AM | #22 |
A.K.A. Starlord
Drives: 2015 Series.Blue
I went with 18x9 wheels with 255/35 tires for my daily setup. I did that because I loved the look of the 18s in black (I think lighter colored wheels look too big in 18s on our cars, personally.) I went with a 9" width because they didn't offer anything narrower, and I'd heard good things about how much grip you could get out of some 255s. That setup "only" weighs 3.9 lb more than the OEM setup, despite being significantly larger, but I'm okay with that for my DD setup.
For autocross, I have a set of 17x9s with 245/40 tires. That was the "best" width for autocross according to just about everyone I talked to, and everything I read. That setup is also quite a bit larger than stock, but weighs only 0.4 lb more than stock because of the lighter wheels.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
07-11-2017, 11:54 AM | #23 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
I don't understand why people think wider is better. I run 225's (nitto NT0'1s mind you) and can put down 300whp no problem.
07-11-2017, 12:59 PM | #24 |
A.K.A. Starlord
Straight-line power delivery isn't the only thing wider tires are good for.
The Following User Says Thank You to Stang70Fastback For This Useful Post: | go_a_way1 (07-11-2017) |
07-11-2017, 01:05 PM | #25 |
A.K.A. Starlord
07-11-2017, 02:20 PM | #26 |
Not Bаnned Anymore
No idea what I am talking about I am drunk apparently lmao!!! |
07-11-2017, 06:55 PM | #27 |
Drives: 2019 Mazda Miata RF
Surprised the question about the larger contact patch hasn't come up....is it larger, or just a different shape with the wider tire?
/pot stirred |
The Following 2 Users Say Thank You to Gunman For This Useful Post: | Keenercarguy (07-12-2017), wparsons (07-11-2017) |
07-11-2017, 08:31 PM | #28 | |
Hombre
Drives: 1994 Supra Turbo
( I guess there might be some slight differences at very high lateral g's). |
The Following User Says Thank You to Silver Supra For This Useful Post: | Gunman (07-11-2017) |
Similar Threads | ||||
FS ATL: Winter Goodyear Ultra Grip Ice WRT tires & steel wheels $400! | mweidner311 | Wheels and Tires | 7 | 02-21-2016 05:20 PM |
15" ultra deep dish wheels. | Yamajee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 02-26-2015 03:19 PM |
Fs in sfv work wheels ultimate cr ultra concave | Scoobysteve11 | Wheels and Tires | 7 | 02-19-2015 02:07 AM |
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance | Jason@DSG | Wheels and Tires | 37 | 12-17-2014 02:50 PM |
I have a 18x7.5+38 wheels..How wide can i go with tires | Bmore_Raven86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 07-23-2013 12:04 PM |
