Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-29-2017, 11:36 PM | #1 |
Drives: 2014 Scion Frs
Tein SRC vs. KW clubsport
Need a two way coilover.
Right now I am running hks sp. Felt like it is a little unrefined for daily driving. On track, my car felt more planted than stock suspension but I want two way coilover for more adjustment and learn how to adjust compression independently. I want to know you guy's impression on those two coilovers performance wise and which one you would purchase. Thx guys. |
03-30-2017, 12:02 AM | #2 |
Anyone? Bump
03-30-2017, 01:03 AM | #3 |
/scion
Drives: '13 86 M/T
"Practice makes better. Only Senna is perfect." - CSG Mike
03-30-2017, 01:06 AM | #4 |
There's a sizable price difference between the two. Both seem to be well reviewed here but the Teins seem to be more oriented to those looking for higher spring rates.
If you're thinking about KW Clubsports I would recommend having a look at our RCE Tarmac 2 Clubsports, which are a custom valved and custom sprung version built by KW to our specs. Plus we offer a lifetime warranty. - Andrew |
03-30-2017, 01:54 AM | #5 |
Because compromise ®
Drives: Red Herring
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post: | kch (04-04-2017), strat61caster (03-30-2017) |
03-30-2017, 02:56 AM | #6 | |
Drives: Subaru BRZ / Toyota 86 Experts
03-30-2017, 03:59 AM | #7 |
03-30-2017, 04:00 AM | #8 | |
03-30-2017, 09:05 AM | #9 |
Drives: 2017 BRZ
I'm sure you'll hear this again (perhaps less directly), but changing to gain experience adjusting is kinda the wrong reasons for a change. And as already noted, there are some rather big spring rate differences off the shelf.
What do you want the car to do differently? If you can't target a specific handling change you want, adjustable shocks won't help... Because you adjust them based on a change you want. I ran SRC for two years, and have recently changed to a set of Tarmacs. Depending on my goals, I'd happily run the Teins again, but there are some very specific things I'm trying to improve that I couldn't easily do with them. C |
The Following 3 Users Say Thank You to cjd For This Useful Post: |
03-30-2017, 11:18 AM | #10 |
Drives: 2014 GT86
cjd: made me curious, what were those specific things?
The Following User Says Thank You to churchx For This Useful Post: | strat61caster (03-30-2017) |
03-30-2017, 05:51 PM | #11 |
Drives: 2017 BRZ
The Following User Says Thank You to cjd For This Useful Post: | Racecomp Engineering (03-30-2017) |
03-30-2017, 07:08 PM | #12 |
@cjd does a lot of autocross so the setup has to be more autocross focused.
The Following User Says Thank You to CSG David For This Useful Post: | cjd (03-30-2017) |
03-30-2017, 08:54 PM | #13 | |
Drives: 2017 BRZ
@churchx To provide a more thorough answer: As grip went up and courses got faster, the Teins would really show what they were capable of (I'd not be surprised if they did well at nationals, assuming it's dry, for example). I so badly wanted to love them all the time. As grip fell off or surface got bad (one lot requires choosing fast transitions, or fast through the rough... I'm hoping to find a happier medium...) it became a struggle to keep the car behaving consistently well. I've gone down *significantly* on spring rate to start this season, lower than what I think the Teins were suited for, but there's more to it as well. I'll be experimenting with spring rates. My previous comment about color might be enough for you to make some accurate assumptions as well, but I'm not really wanting to go on about it here. Suffice to say it isn't a lateral move. What really is interesting is that, aside from one stretch of highway I drove a lot where the distances the cement was laid down lines up with some harmonic and it feels like the car is a seesaw, highway driving was never an issue - and that includes my wife, who likes to knit while we travel, and did so without trouble. Oh, and that one HORRIBLE road in Michigan, where I thought the car was going to fall apart. And all this goes back to what I asked the OP: what needs to change? Because without that, ... who knows. Note, I haven't driven more than 5 miles on the Tarmacs yet, so have zero opinion of them performance-wise. |
03-31-2017, 12:52 PM | #14 | |
Similar Threads | ||||
KW clubsport coilovers | APEXIT53 | Brakes, Suspension, Chassis | 3 | 11-15-2016 04:54 PM |
Tarmac 2 vs KW clubsport | cjsporl1996 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 05-01-2014 02:39 PM |
KW Clubsport Released | pdreams | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 03-01-2013 10:10 AM |
