Old 03-06-2017, 11:57 PM   #1
DG-86
DG-86's Avatar
Drives: 17' WRB BRZ Limited P.P. 6MT
2017 BRZ Performance Package Wheel Clearance Concerns
Can anyone confirm if a set of Enkei RPF1 17X9 +35 wheels will clear the PP Brembo calipers on a new 17? Thank you in advance.
DG-86 is offline   Reply With Quote
Old 03-07-2017, 01:23 AM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Edit: RPF1 17x9" spoke design sucks for brake clearance. Edited for clarity.
SkAsphalt (03-08-2017)
Old 03-07-2017, 10:35 AM   #3
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
17x9 +35 RPF1 WILL NOT CLEAR. I had to use a +8mm spacer to get them to clear and its still bonkers close in the front.
uno momento and i'll get a picture uploaded
http://imgur.com/a/FgUmV
Ranatsu is offline   Reply With Quote
The Following 2 Users Say Thank You to Ranatsu For This Useful Post:
BRZ FTW (03-08-2017), DG-86 (03-07-2017)
Old 03-07-2017, 10:39 AM   #4
Ranatsu
Cone basher
The link is there, for whatever reason the tags aren't functioning it seems like.
Old 03-07-2017, 01:37 PM   #5
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
Uploaded picture for Future reference.
Hope OP doesn't mind
SG02WRX is offline   Reply With Quote
The Following User Says Thank You to SG02WRX For This Useful Post:
DG-86 (03-07-2017)
Old 03-07-2017, 01:39 PM   #6
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You have to put .jpg at the end of the link if you're putting it between the IMG tags.
Old 03-07-2017, 01:43 PM   #7
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Did your PP car come with a spare tire in the trunk?
The Following User Says Thank You to switchlanez For This Useful Post:
funwheeldrive (03-07-2017)
Old 03-07-2017, 02:20 PM   #8
DG-86
DG-86's Avatar
Thank you for the insight.
How's do the wheels sit with that 8MM spacer in regards to the fender well fitment? Do they stick out past the fenders? Pics? Are you lowered yet?
Old 03-07-2017, 04:02 PM   #9
Ranatsu
Cone basher
it fits fine in the front and doesn't rub anywhere from what I can tell. The rear can rub if you are too low or are on really soft springs. Keep in mind you don't need the spacers in the rear, only in the front.
I'm fairly low, I'll upload a picture for you to see.
http://imgur.com/a/XvXGb
Old 03-07-2017, 04:24 PM   #10
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Just FYI, Kosei K4R 17 x8 fit just fine. I run these with my All Seasons on.
Pics for reference. Just sharing info.
http://www.ft86club.com/forums/attac...1&d=1488921841
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following 2 Users Say Thank You to brzaapi For This Useful Post:
Prax (03-23-2017), weederr33 (03-08-2017)
Old 03-07-2017, 04:43 PM   #11
Ranatsu
Cone basher
WedSport TC105N should clear as well in 17x9 with the 38 offset. I'm going to test fit one on Thursday night to be sure.
Old 03-07-2017, 05:23 PM   #12
CSG David
CSG David's Avatar
TC105N +35 has very good BBK clearance. Brembo PP kit uses similar calipers as the STI but has different piston setup so the caliper is not that large compared to the Brembo GT unit.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
brzaapi (03-08-2017), Ranatsu (03-07-2017)
Old 03-08-2017, 06:58 AM   #13
brzaapi
CAR-AHOLIC
brzaapi's Avatar
In addition, once I have time in the next week or two, I post up some clearance pics of some TWS T66, but don't imagine there will be any issues.
Daily: Audi TT RS
Old 03-08-2017, 02:01 PM   #14
switchlanez
Does your Performance Package BRZ have a spare tire in the trunk?
2017 BRZ Performance Package DD Build mjanmohammad Member's Car Journals 230 11-01-2023 12:31 PM
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 09:36 AM
2017 BRZ w/ Performance Package Brake options mjanmohammad Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 04-07-2017 08:12 PM
WTB: OEM 2017 Performance package wheels mjanmohammad Want-To-Buy Requests 1 03-03-2017 02:35 PM
Bristecom's 2017 Subaru BRZ Performance Package Bristecom Member's Car Journals 16 01-26-2017 09:05 PM
