02-14-2017, 05:55 AM | #15 | |
Steve Bodalenko
Drives: Toyota 86 GTS
I have the same issue with the Tomei UEL, SME op, Nameless HF catted FP with helmholtz, and Namelees AB with 4" resonators. Sounded great when OEM headers but WAY too loud with the Tomei. Had to resort to refitting OEM AB. Not 100% happy with the tone/note, sounds kind of metallic thanks to the helmholtz, but a least I don't fear being put off the road every time I pass a police car. Still has some rumble but volume is much reduced. With a tune performance seems every bit as good as the Nameless. Put your OEM back on if you can till you can find a fix and at least you won't have a continual headache. What's the actual OD of the OEM midpipe 2.25" or 2.5". |
02-14-2017, 06:30 AM | #16 | |
Its been a few days now and it sounds much better. Its still loud but it doesnt have that annoying tone to it so my only problem atm is the cold start Sent from my iPhone using Tapatalk |
02-14-2017, 10:07 AM | #17 |
Drives: 2015 Raven FRS
Please re-read my suggestions. My new system is as quiet or quieter than stock was. And works well with my supercharger and e-85. What I did is all bolt on you can do your self.
02-14-2017, 03:09 PM | #18 |
Steve Bodalenko
"Its been a few days now and it sounds much better. Its still loud but it doesnt have that annoying tone to it so my only problem atm is the cold start."
OpenFlash Tune will drop the cold start revs and make it a lot quieter. |
02-15-2017, 12:42 AM | #19 | |
The car was dyno tuned recently so its already been done but still loud as Sent from my iPhone using Tapatalk |
02-15-2017, 08:50 PM | #20 | |
Steve Bodalenko
The Vibrant Ultra Quiet method sounds like a solution but can't seem to find Vibrant being available in Oz. Can buy of Amazon and have here for about $200 oz. Just have to climb under car to measure and see where I can get one welded in. |
02-19-2017, 06:53 AM | #21 | |
Drives:
If you're describing a metallic buzz around 2k -3k you may want to check if the expansion joints on the header are contacting the alloy skid plate. I had this with my PSR headers. If its happening, you can see the marks looking down through the engine (ie no need to remove skid plate) Easily fixed with a hammer and punch. I posted about it somewhere here if you need photos. |
02-26-2017, 09:26 PM | #22 |
Just a quick update guys
The sound is a lot quieter now I think i just had to give it a few days for it to settle Cold start is still loud but well nothing i can really do Sent from my iPhone using Tapatalk |
02-26-2017, 09:27 PM | #23 | |
If you could link me the photos i would really appreciate it Sent from my iPhone using Tapatalk |
02-28-2017, 05:09 PM | #24 |
Drives: BR86
I too was in the same predicament as @Armin93 a while back with the UEL header & Perrin CB, best solution was the stock CB. Still I wanted a little more noise but less than before so I managed to find an STI AB which opened up the noise hwy again but not as loud as Perrin. I had an additional resonator in the midpipe added which helped a little by taking some of the bark away and I guess it become livable to me as a DD although it's not one atm. What I'm trying to say is there's very little room under our cars for big midpipes & the best way to shut her up is probably the rear mufler as the stocky does it really well.
Another thing to note is you need to give exhausts a few thousand kms to carbon up & re-evaluate noise levels then. |
03-16-2017, 12:20 AM | #25 | |
Drives: 2017 BRZ Ltd White
The stock exhaust on my new brz sounded terrible until i had done abt 700km and a long country drive. Now it sounds completely different and so much better. Was raspy and tinnie but now has a much deeper roar. |
03-16-2017, 05:46 PM | #26 |
Potato Farmer
Drives: #SLOBRZ
Yes you can.
I have PSR UEL's and Tanabe cat back, it's rather loud on song. But with a tune, you can fix the cold start, Mine is pretty quiet while its warming up. (
this is my exhaust for comparison, just make sure you listen on a something thats got some proper speakers, not a phone or laptop!)
Something something butter..
www.vic86brzclub.com |
03-17-2017, 11:48 AM | #27 | |
Mine sounds about the same And i did get a dyno tune after i put the headers on and tuner said he tried to make the cold start quiet but still loud as Sent from my iPhone using Tapatalk |
03-19-2017, 03:38 AM | #28 | |
Steve Bodalenko
After tune warmup lasts about 1 min and is a lot of decibels quieter. Last edited by Bodalenko; 03-22-2017 at 04:36 PM. |
The Following User Says Thank You to Bodalenko For This Useful Post: | fuddbutter (03-20-2017) |
Similar Threads | ||||
perrin catback resonated - loud enough or too loud? | theflathead | Engine, Exhaust, Transmission | 33 | 01-22-2018 05:46 PM |
J2 exhaust + Headers = too loud! What Can I do | svnintl | Engine, Exhaust, Transmission | 24 | 12-23-2015 08:03 PM |
How loud do you think this would be? | BlueDubbinTDI | Engine, Exhaust, Transmission | 2 | 01-02-2014 12:35 PM |
Injen SES Headers/ Agency Power headers | Choong86 | Engine, Exhaust, Transmission | 10 | 12-27-2013 09:51 PM |
Loud pop during WOT | frosty86 | Issues | Warranty | Recalls / TSB | 5 | 10-02-2013 10:12 AM |
