Old 02-26-2017, 04:41 AM   #1
86raus
86raus's Avatar
Drives: 2017 blue toyota 76
High mount longbar brake light
Deleted the rear brakelight and installed a high mount brakelight from cjpony parts. I modified two brake light bars into one long one. Now i need some plastic to cover the holes from the old brakelight if anyone knows of a kit or what i could do to clean up that section let me know.
Sent from my SM-G935F using Tapatalk
86raus is offline   Reply With Quote
The Following User Says Thank You to 86raus For This Useful Post:
korhun (08-23-2019)
Old 02-26-2017, 12:35 PM   #2
zeal86
zeal86's Avatar
Drives:
I used sticky back felt that can be found at craft stores or even some large department stores... Dependong on the brand, the felt may match your interior more or less than mine.
Covered the new clip and bracket with sticky-back felt.
Color match looks better in this pic...
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
Eman (02-26-2017)
Old 02-26-2017, 04:35 PM   #3
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Id like to see more on how you did the modification, looks good.
VIP BRZ is offline   Reply With Quote
Old 02-27-2017, 08:43 AM   #4
86raus
86raus's Avatar
I didn't take pictures of the process. But I'll explain it.
I just cut off the corners and sanded it down with a small angle so the two lightbars are on a wide V angle to conform with the shape of the rear roof. The two other corners i trimmed off a little so they tuck in to the pillars better.
The roof does fit the length of a straight bar but with the rear roof being curved i think it looks much sexier on a v.
I was going to glue the two lights together but the two lightbars sat flush together so i left it and It most probably would be easy to tuck them into the roofliner as two separate units.
Soldered the two light bar wiring together, wrapped it in electrical tape where i did the solder.
Pop off the 4 popclips on the rear shelf and 3 roof popclips.
Brakelight on the shelf is popped up andhalf taken off.
(bottom half of the brakelight housing is glued to the shelf).
Remove rear shelf. The rear shelf has 4 internal clips you have to be careful when dismantling slowly push up where the 4 pressure points are. you will deform your shelf to get it out but mine came out all ok. You could be safer and dismantle the pillars first but i couldn't be bothered with that.
Bottom brake housing is held on with glue stamps on the underside, i drilled all the glue stamps out and it came off easily.
snip off the old brake light connector and solder it onto the new brakelight.
Clean window then
Install brake light, wire cable went through the pillar, i didnt remove it i just pressed the wire in the small slot and you see no wiring.
Put rear shelf back on and all the popclips and voila you now have one longbar baller executive baus raus looking brake light =).
Old 02-27-2017, 08:45 AM   #5
86raus
86raus's Avatar
Nice, Much better than what i was thinking of going to a wrecker to cut some of the shelf off ha.
Old 02-27-2017, 12:28 PM   #6
Kerrija
Drives: 2016 Subaru BRZ Limited
I have the sticky felt on mine as well to cover the holes. I was thinking of getting a large sheet of felt and some spray glue and doing the whole deck eventually to cover up everything.
Kerrija is offline   Reply With Quote
The Following User Says Thank You to Kerrija For This Useful Post:
zeal86 (02-27-2017)
Old 02-27-2017, 02:20 PM   #7
arkanist
Drives: 2016 BRZ Limited, Stock
I've heard a '98 Cadillac STS 3rd break light (the bar on the trunk) fits really well for this application. I plan on buying one soon and giving it a go.
arkanist is offline   Reply With Quote
Old 02-28-2017, 09:36 AM   #8
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Not bad. Here is my version of the same thing.
Sent from my E6883 using Tapatalk
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
The Following User Says Thank You to MemphisR For This Useful Post:
korhun (08-23-2019)
Old 03-04-2017, 02:13 PM   #9
MemphisR
Memphis
MemphisR's Avatar
The STS brake light is what I used for mine. And it is easy to cut it down to size ☺️
Old 03-04-2017, 02:35 PM   #10
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
No offence guys - 'A' for effort and execution, but these long brake light bars just seem to overwhelm and unbalance the arse ends of your otherwise fine rides.
geezerbrzeezer is offline   Reply With Quote
Old 03-04-2017, 02:40 PM   #11
MemphisR
Memphis
MemphisR's Avatar
None taken. It's just one of those times where 'to each their own' comes to mind. I have been rear ended twice in one year, so I thought that this was a nice and functional way of trying to help the issue I also love the Tesla, Bentley and and bmw 6 series, and any othersim missing, high mounts. It is as subjective as wheels, body kits and and every other part.
But I appreciate you being respectful about the discussion, as many on this forum seem rude when expressing their opinion. So thank you.
MemphisR
Old 03-04-2017, 03:14 PM   #12
geezerbrzeezer
Geezer
Pics tend to exaggerate the intensity of the light, so that could be a factor in what I'm seeing.
Your rear end concerns are so valid. I installed the Intec as I fail to understand the 'logic' of having a 'high mount stop lamp' mounted on the upper trunk, trunk mounted spoiler, bottom of the rear window, or anywhere other than a significantly high point on the vehicle. The whole idea behind the high mount stop light was to enable drivers two or more cars behind to see the light activating for advance warning.
I looked at the same light you installed but was concerned about it being taped to my tint - the Intec tape failed with summer heat - I found another solution to keep it in place, but what a drag.
What I now want to install is the roof mounted brake light from the Ford Fusion or newer Mustang - just wasn't sure how exactly it would conform to our roof, or how to conceal the wiring (other than tucking along the window glass down to the trunk). But it's very bright even in sunlight and so low profile.
Old 03-30-2017, 04:08 PM   #13
Captain_Awesome_Pants
Captain_Awesome_Pants's Avatar
Drives: FR-S: Firestorm
Any pics of the install from the inside?
Captain_Awesome_Pants is offline   Reply With Quote
Old 03-30-2017, 05:38 PM   #14
MemphisR
Memphis
MemphisR's Avatar
Who are you asking? I can post some tonight, if it is me you're talking to.
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 02:47 PM
Intec High Mount Brake + Rear Dash Cam SmartedPanda Electronics | Audio | NAV | Infotainment 7 02-11-2017 03:44 PM
Top mount 3rd brake light Jonesy86 Northwest 1 06-12-2015 02:41 AM
