Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
12-30-2016, 10:42 PM | #15 |
Off Topic
If you want the ability to adjust your camber for better handling, you need some sort of adjustment mechanism; whether that's bolts or plates. Bolts are much cheaper and have no added NVH, but they have a limited adjustment range. Plates have a greater adjustment range, but they're much more expensive and add NVH because they replace the OEM rubber top mount. It's a question of which trade-off you would rather have to achieve more negative camber. Additional tire wear isn't really a concern unless you have a lot of negative camber or unless your toe is off.
I have bolts on mine and they're maxed out at -1.7. I'd like more, but it's not worth the added expense of plates. -1.7 is fine for a daily driver; I have nice sharp handling without it being twitchy. |
12-31-2016, 12:26 AM | #16 |
Drives: 2014 GT86
BTW, with stock shocks (with larger diameter coils) that range was not drastically wider with camberplates. At -2.5 shock spring cap already started to rub for me, not that much more of neg. camber then -2.2 with cambolts in both holes.
And one shouldn't underestimate increase in NVH at daily driving on subpar state public roads. It was bad enough to decide switching to bolts & stock mounts after having tried camberplates for few months. It might be not that bad with higher spring rates with some aftermarket coilovers, and thus maybe less bottoming out to bumpstops, but not so with softer sprung stock ones. |
01-03-2017, 12:19 PM | #17 |
The Stig's German cousin
Bolts aren't a bad idea. Again, not necessary, but at max adjustment most bolts will provide a reasonable amount of camber so your risk of having too much camber is small.
I'd recommend the OEM crash bolts over others and just set to max camber. Keep it simple... |
01-03-2017, 01:34 PM | #18 | |
Drives: '13 FRS - STX
And the NVH increase was nearly indiscernible, I was the only person who could tell. |
01-03-2017, 02:42 PM | #19 |
Drives: 2014 GT86
strat61caster: probably depends on roads. Was fine on good ones/on track/on some of uneventies. And was like loud hard hits on other ones, that subjectively sounded like if any harder, then it will start to break/bend parts/suspension/wheels. Liked extra grip from negative camber on track and more to my liking changed grip balance (due less camber in rear), but given bad average road state here + me daily driving 99%, not on track, i gave up plates and installed bolts instead. And let me tell you that immediately felt big relief. Like some say - to make human happy first you rob him of something, then return how it was. I could simply drive normally again, not maneuver around many of those road holes that made me feel like breaking car/suspension, even if it just "sounded" like breaking. And it sounded/felt that way too to others i had as passengers when still had plates on.
It's very probably not so on better roads, very probably with several aftermarket coilovers, some of which even have camplates in set yet still are reviewed as more comfortable/compliant as stock. Not so for me, with stock, on roads here. |
01-03-2017, 02:54 PM | #20 |
Drives: 2013 Firestorm FRS
Just get camber plates, I wish I did the first time around. I had ST coilovers which were decent, but I reused the factory top hats and only ended up with -1.5 and -1.8 I think up front. Not horrible, but I just switched coilovers and picked up Velox camber plates to go on the new setup-here's an unboxing video, and I have more stuff coming shortly. @VeloxEric
When/if you decide to go with different coilovers, you can either re-use the Velox plates (they work with a handful of coilovers) or sell them if your new ones come with camber plates. They are absolutely a bargain and well worth the money. Bolts are okay, but I've never been a fan since they aren't really easily adjustable and I was always worried about potential slippage. [ame="https://www.youtube.com/watch?v=NA_E36uJy44"]Velox Motorsport Camber Plates FRS/BRZ Unboxing and First Look - YouTube[/ame] |
01-03-2017, 03:21 PM | #21 | |
I have no doubt your roads are worse than mine |
01-03-2017, 10:35 PM | #22 |
Drives: 2014 GT86
Also raceseng + spring perches for stockers. They were no doubt quality product that i very probably may put back when/if i'll upgrade to aftermarket shocks/coilovers (seem better then many native camber plates), but replacing rubber mount with pillow ball there with soft sprung stockers impacted NVH on bad local roads way more then i expected/was willing to live with (mostly on road holes/bumps of sharp height change). For now it's group n mounts (as bearing in one stock mount binded, so if replacing, why not experiment. Didn't feel difference vs stock to handling but also no change to NVH)+ bolts for me (+rea lca of course).
The Following User Says Thank You to churchx For This Useful Post: | strat61caster (01-04-2017) |
01-04-2017, 10:42 AM | #23 | |
Drives: Fr-s
Similar Threads | ||||
HVT Camber Plates | smg1138 | Tracking / Autocross / HPDE / Drifting | 5 | 08-13-2016 07:47 PM |
FS: HVT Non-raising camber plates & WL camber bolts | trippinbillies40 | Brakes, Suspension, Chassis | 1 | 05-16-2015 09:00 PM |
Camber plates | G-Man | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 10-05-2014 09:47 PM |
HVT Camber Plates | stevo_12v | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 10-01-2014 01:11 PM |
Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
