Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
10-23-2016, 08:18 PM | #1 |
Java Programmer
Drives: 2016 FRS Red
First time lowering the suspension. Need advice
I just bought a set of coilovers from Yonaka. They all have camber plates on top which means I can adjust the camber when the car is lowered without having to purchase adjustable control arms correct? Please help out, I am very new to the car mod game
10-23-2016, 09:02 PM | #2 |
Drives: 2013 FR-S Argento
Nope, won't fix the camber in the rear, you'll need rear LCA's if you want to adjust rear camber. That said you can be just fine depending on what alignment specs you want and how much you're dropping the car.
What alignment specs you say? How much can I drop the car? Search this forum and you'll find all that info. |
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post: | ModBargains.com (10-25-2016), nhuyvan1106 (10-24-2016) |
10-23-2016, 09:05 PM | #3 |
Drives: Toyota GT86
There are "camber plates" and there are "adjustable camber plates".
Those in the rear are never adjustable on the FT86, hence you need lower control arms for the rear or live with the camber resulting from lowering. If you don't lower it crazy much, you can probably do without. Even if the camber is slightly off left to right in the rear, you probably won't notice depending on what you plan to do with the car.
The Following User Says Thank You to Tor For This Useful Post: | nhuyvan1106 (10-24-2016) |
10-24-2016, 01:50 PM | #4 |
Java Programmer
10-24-2016, 01:52 PM | #5 |
Java Programmer
It is my daily driver, I plan on lowering by 2 inches. Also, when I change the camber angle, do I need new alignment?
10-24-2016, 02:12 PM | #6 |
Loading...████████] 99%
Drives: #0517
10-24-2016, 03:04 PM | #7 |
A 1" drop puts you at roughly -2.5*, a 2" drop will definitely be over 3*, probably more like -4*.
The Following User Says Thank You to wparsons For This Useful Post: | nhuyvan1106 (10-25-2016) |
10-25-2016, 02:18 AM | #8 |
Java Programmer
10-25-2016, 02:20 AM | #9 |
Java Programmer
10-25-2016, 07:31 AM | #10 |
10-25-2016, 08:35 AM | #11 |
Drives: 2013 Scion FRS
I lowered my car ignorantly low, over 2" with the wheels tucked in and the camber is ugly as hell to me in the rear. I'm going widebody as soon I get a new wheel setup so I don't really care right now, I'm tired of going into my shed to look my RB v1 flares. I would also advise, during installation to make sure the end links are aligned and installed correctly or you may get noise. Make sure everything is tightened the right way, you may need adjustable endlinks as well going 2" lower. My alignment is fine though, I haven't gotten an alignment and no issues with my tires or anything aside from minimal camber wear.
2013 Scion FR-S | 6-MT | Raven Black | Performance Mods: Invidia N1 Catback, Invidia Catless Frontpipe, BC Racing Extreme Lows Coilovers, 1320 Performance UEL Catless Headers, 1320 Performance Overpipe, OpenFlash Tablet (Stage 2 UEL, 93 Oct. tune), Whiteline Front Swaybar, Whitelight Adj. Front Endlinks | Asthetic Mods: DS Style Front Lip, Rocket Bunny style flares, F1R F21s | MY BUILD THREAD!
The Following User Says Thank You to Songha For This Useful Post: | nhuyvan1106 (10-27-2016) |
10-27-2016, 02:15 PM | #12 | |
Java Programmer
10-27-2016, 02:17 PM | #13 |
Java Programmer
Yeah, I will have XXR wheels size 17 by 8.25 offset +35 installed at Discount Tires this Saturday and they will do the alignment as well. Are they good at aligning the suspension?
10-27-2016, 04:25 PM | #14 | |
I would take it to a performance shop unless "close enough" or "within the spec range" is good enough for you. Personally I want my alignment to be a lot more accurate than that.
Tags |
adjustable, camber, camber plate, coilovers, control arms |
Similar Threads | ||||
Tein Street Flex suspension issue (lowering itself over time) | Sportsguy83 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 64 | 07-26-2015 05:00 PM |
Long time Lurker seeking advice on a budget suspension setup | sunset_blvd | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 12-28-2014 05:48 PM |
Need advice lowering my car just a bit... | dejxx | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-08-2014 10:58 AM |
Need some Lowering Advice / Rims | kbass808 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 04-18-2014 02:19 PM |
advice on lowering car. | juanam0909 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 04-30-2013 04:23 PM |
