09-14-2016, 02:04 PM | #7547 | |
Drives: 2013 Scion FRS
ScreamingElectron - SnakeShit |
09-14-2016, 02:12 PM | #7548 |
Drives: 2013 Firestorm FRS
also does it bug anyone else about the brake booster line facing up lol?
Or is that done for a reason. I almost wanna cut it off and re-weld it pointing down. |
09-14-2016, 02:45 PM | #7549 | |
Drives: 2013 Subaru BRZ Limited (Black)
Part of my day job involves quality control and user design experience... I am constantly bothered by lack of clarity in instructions! |
09-14-2016, 06:04 PM | #7550 | |
Someone else will need to comment on using oem check valve. Should be fine if you can reuse it. You definitely need a check valve though so I wouldnt try brakes till you get it. |
The Following User Says Thank You to nmastereal For This Useful Post: | ajcarson11 (09-15-2016) |
09-15-2016, 11:33 PM | #7551 | |
Wondering of any tests I can do to see if its leaking into the manifold before taking off the manifold and sending it for warranty. Also, I am feeling water moving before and after the core that is inside the blower. Just dont know if its any less than when I first installed a year ago. I am not getting any CEL but have some power loss after temps reach normal operating temps. Also does anyone know the operating pressure of the intercooler system? I want to put pressure to the entire system and see what i can find. Last edited by nmastereal; 09-18-2016 at 09:47 PM. |
09-20-2016, 08:06 PM | #7552 |
Drives: 2014 BRZ (SOLD)
Anyone else experiencing issues with extreme jerkiness around 3000 RPM and car stalling that stops. Just started happening over the last week or two.
Sent from my SM-G930T using Tapatalk
Supercharged 2014 DGM Limited
09-20-2016, 08:28 PM | #7553 | |
Drives: Raven FR-S
Welcome to the innovate / Sprintex supercharger!!
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
09-20-2016, 09:05 PM | #7554 |
Drives: 2013 SWP BRZ Limited
09-21-2016, 12:03 AM | #7555 |
Have had this thing on for 10k miles and all of a sudden. Just seem so odd.
09-21-2016, 01:36 AM | #7556 |
Maybe bad batch of fuel is causing you to pull timing, and lose too much power at the surge point. Does kinda sound AFR related if you're stalling.
09-21-2016, 11:30 AM | #7557 |
Been through 2 tanks of e85 from different stations.ill just need to pull logs and just have motoeast change idle rpm on my tune.
09-23-2016, 11:32 AM | #7558 |
All -- I'm looking around for a 72.5mm pulley, but it seems raceseng discontinued it, and therefore it isn't sold anywhere. Would anyone be willing to part with theirs for $$, or trade for a 69mm?
I won't be able to run the 69mm (and it is currently up for sale in the sale section). Thanks! |
09-23-2016, 11:41 AM | #7559 | |
Drives: Subaru Brz
Have you tried contacting motoeast? Sent from my iPhone using Tapatalk |
09-23-2016, 12:05 PM | #7560 |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
