#29 |
Drives: 2015 Scion FRS - Raven
Maybe but there is a lot more to it then just running a wider tire, like suspension setup and what not. If you are on stock suspension run a narrower tire, save some money and track more. The fastest time at Fabi I have recorded with my DL was in another persons car (green BRZ, I think his name was Derrick?) he was about a second faster then my car but with wider tires and coil overs. I don't have enough data to compare between wider and narrower tires to know for sure.
The Following User Says Thank You to TRAKRAVN For This Useful Post: | infinity21 (09-19-2016) |
#30 | |
You'd really need to be logging back to back sessions on different tires to get the full picture.
The Following 2 Users Say Thank You to wparsons For This Useful Post: | infinity21 (09-19-2016), Lynxis (09-19-2016) |
#31 |
Drives: 2013 WRB BRZ 6MT
Shannonville is definitely tough on tires, primarily because there is no camber built into the track and also that the asphalt is really rough. Besides that, I also think that it is a factor of how much track time you actually get there. I've been to full lapping days where you get half an hour for every hour you're there or lapping evenings and half-days are often completely open lapping. That is more time on track than I've gotten at other full lapping day events where you usually get 20 minutes on track for every hour that you're there. It's certainly the most seat time you can get for your money anyway.
The Following User Says Thank You to Lynxis For This Useful Post: | wparsons (09-19-2016) |
#32 | ||
Drives: 2014 BRZ Sport-tech
At the end of the day, I don't have budget to do a proper test and so I'm only speculating. With my money, I erred on the side of going too wide since it lets me stay out on track longer and will wear better. |
#33 |
That's a good point too. 225's might be faster on some tracks, but you'd be more likely to overheat them much faster. You might get two faster laps, then a bunch that are MUCH slower.
#34 | |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
once you get into the track dedicated tire realm of lets say under 200tw, do different tires resist over heating noticeably better than others? Next year I plan on dropping down to a 235 or 245 tire but I'm focusing the mods on my car toward longer sessions so I'm worried now that reducing width may cause my sessions to be limited by tires. I'm not set on any tire yet but what tires have the best resistance to overheating in the re71r, R888, NT01 range? |
#35 | |
The Following User Says Thank You to Lynxis For This Useful Post: | wparsons (09-24-2016) |
#36 | |
NT01's will definitely take a ton more heat than RE71R's. I would give the Maxxis VR-1 a try, the closest to ideal size for us is a 255/40/17, I've heard they take 20-30 minute sessions easily, even in Atlanta heat in the middle of the summer.
#37 |
Drives: Rocket Bunny BRZ, Track FRS
We got 1:21.86 on our FRS on 245 RE71R. Still NA bolt ons + suspension + brakes. Our ultimate goal here is to get into 1:20s NA which we do not feel is out of reach
On one of our BRZs we got 1:23.75 on 225 RE71R which is stock apart from coilovers + Endless MX72 on stock calipers. From the data we collect, should be able to get into the low-mid 1:23s as is. |
#38 |
Drives: 2015 Scion frz
Would love to go for a ride along with one of the faster guys. Second time at the track and I only managed a 1:33, way slow compared to you guys haha.
#39 |
Won't be at TMP, but come out to an SPDA/ATTS day at the DDT next summer and you can get some coaching as well as as many ride alongs as you can handle!
The Following User Says Thank You to wparsons For This Useful Post: | Trac Toy (05-07-2017) |
#41 |
Drives: 2018 Subaru BRZ
2014 FRS
Stock Drivetrain Tein Control Master Flex 17x9 +35 RPF-1 245/45R17 Bridgestone RE71-R 1:26.4 First time at TMP About 8* Early November day Its a shame because I only live 35mins away. This year I plan to have far more seat time there. My first time at Shannonville Full I managed to squeak out a 2:11.6 |
The Following User Says Thank You to Scracho For This Useful Post: | icybrzzz (02-10-2017) |
#42 |
Drives: 2015 AOZORA EDITION
Did a 1:20.7 on TMP last WED pretty good for first shakedown of the season, hoping to get under 20 next time out
Fastest Track Times Thread | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 406 | 11-07-2023 10:40 AM |
NZ Track times | diss7 | NEW ZEALAND | 2 | 03-03-2014 12:42 AM |
FI Track Times | wrxgoose | Forced Induction | 0 | 07-24-2013 02:17 PM |
Can too much grip hurt track times? | ayau | Tracking / Autocross / HPDE / Drifting | 53 | 04-22-2013 10:28 AM |
Top Gear (UK) track times | GeeTee86 | AFRICA | 29 | 02-15-2013 07:04 AM |
