#631 | |
The Stig's German cousin
You will want to monitor knock and AFRs carefully. This is not a "set it and forget it" tune like the Stage 2. |
The Following User Says Thank You to renfield90 For This Useful Post: | smg1138 (08-22-2016) |
#632 | |
There's a thread on this here you should read through instead: http://www.ft86club.com/forums/showthread.php?t=79059 I do believe there is a VVT edit you do in romraider that makes it run noticeably better with the jdl uels @steve99 would probably know about this.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | smg1138 (08-22-2016) |
#633 |
Drives: White frs
I just read this whole thread and I just want to make sure that the new stage 2 ofh tune is ok to use with E85, thanks in advance
#634 |
Drives: United States
I really need to get an oft. I have tomei fuel header, tomei op, invidia catless resonated fp, invidia N1 exhaust and no tune. Honestly other then sound I noticed much difference in performance, I'm looking to get the most out of what i have.
#635 | |
Drives: 15 BRZ LTD, 05 FXT
The header makes a big difference, and the frontpipe makes a medium difference. The rest of the parts will just help throw the tune off that much more.
#636 | |
It's next on my list foresure. If I can sell some of these stock part I have I'll grab it up soon. Luckily I don't drive it that much. |
#637 |
Trade that noisemaker, (N1,) for an OFT, or find a local with a Tactrix cable that can flash the OFT tune on for you.
#638 |
Drives: 2013 FR-S in Whiteout
Hate to be that guy,but it's been awhile.. what exactly do I need to do to get this update on to my oft tablet? Plugged in to pc and got a update done that and went to site and downloaded the new files,but now I'm lost,lol.
#639 | |
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
The Following User Says Thank You to alxtheoreo For This Useful Post: | ANTLAY (08-24-2016) |
#640 | |
Ok, removed one of the El (since I'm uel) and went through and found the bin folder and used the stage 2 uel 93 on that slot, used the one that had same "a01c.bin" assuming that is right how do I save it to that slot |
#641 | |
I'm at the gym right now, so I can't be that precise. Lol Sent from my SM-G930V using Tapatalk
#642 |
Drives: 2015 86 GTS
Go to the "Upload" section in OFM.
Allow population of curent tune files - should be around 30 secs. Use "x" on right to delete unwanted tune file. Use file browser icon to find and add new tune file. Once new file is on list, scroll down to the section that says something like "Create tune file". Hit the "Start" button and wait for completion prompt. You're finished! ![]() |
The Following User Says Thank You to fibble For This Useful Post: | Teseo (08-25-2016) |
#643 | |
Drives: frs
#644 |
Drives: 15' FRS
Hey guys,
I'm doing the usual tweaks for every tune I'm going to load on my OFT, just came across the Stage 2 OFH specific tune. I'm trying to implement the usual values for the quiet cold start, the exact same as seen in steve99's post. According to his post, the tables that require editing are the following: -Ignition Timing Post start -MAF Correction After Start (In-Gear) -MAF Correction After Start (Neutral) -Idle Control -and turning off the P050B Engine light.. It seems that both the MAF Correction tables are absent. I triple checked that I am using the correct XML definition- ZA1JD00D. Would I still achieve a quieter cold start with these tables alone? Any help is appreciated ![]() |
Just how noticeable is OFT+OFH and stage 2 tune? | BBYZILA | Software Tuning | 58 | 03-20-2018 11:56 AM |
OFT 2.0 Stage 1 93 Tune | MurderRider | Software Tuning | 57 | 03-21-2016 12:30 AM |
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
FA20club.com Turnaround Times On Modified Tune Files | FR-S Matt | Software Tuning | 103 | 11-13-2013 01:48 PM |
So whate does stage 3 tune do? I already have 2 | Frsexxxy | Engine, Exhaust, Transmission | 17 | 05-14-2013 06:30 AM |
