07-30-2016, 06:11 AM | #29 | |
Drives: GT86 Harrop S/C
Is there a reason you guys went for just the 2.5inch cat back when you ran the TVS1320 on the 86 with stock internals. Would you say that is the most important exhaust mod to make if I was going to make any? Thanks. |
07-30-2016, 02:51 PM | #30 | |
Drives: GBS BRZ Harrop SC/PTuning Header
Id imagine around the same power ad the edelbrock owners with full exhaust. It shouldn't be too difficult to maintain that. |
07-31-2016, 05:48 PM | #31 | |
Drives: Harrop TVS1320 Supercharged 86
The reason we mention it on our dyno sheet is that we are all about 100% transparency. Thats what the car had on it when we bolted the SC kit on so we need to mention it. A Cat back is certainly not a huge performance mod. So to answer your question, i think the most important exhaust mod is a good quality set of headers. We use and recommend the CS400 Ace Headers. |
The Following 4 Users Say Thank You to HarropOz For This Useful Post: |
07-31-2016, 09:07 PM | #32 | |
Drives: BRZ + Ducati M796
08-01-2016, 12:30 AM | #33 |
Just saying.
[ame="http://youtu.be/azPKIjxmmdU"]http://youtu.be/azPKIjxmmdU[/ame] |
The Following User Says Thank You to Irace86 For This Useful Post: | sato (04-30-2017) |
08-01-2016, 05:11 PM | #34 |
I just Drive.
Drives: in the womb still
E85
To educate a few here on E85 and not hoping to hijack..
E85 from corn is typically from a type of corn or can be from a process that the cows wont eat(yes cows eat corn/grain on large commercial farms) and not for human consumption. Yes you have to spend time making it and gathering it will equipment...like everything else. 2nd, the best ethanol producer is cattails. Yup no joke.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
The Following 2 Users Say Thank You to Swift For This Useful Post: | Irace86 (08-02-2016), kuczynskika (08-01-2016) |
08-01-2016, 08:47 PM | #35 |
...Just add nauseum
Drives: 2003 (AP1) S2000
This has been posted before.
I have called it out before. I have illustrated it mathematically before. That engine / example is in no way comparable to our cars. First, it's running fixed AFR, fixed ignition timing, and fixed cam timing. Second, it's a large displacement, 2 valve engine on which VE peaks below 90%. In other words, that is not comparable to our engine at all. I'll bet anyone double or nothing the cost of a header and my dyno time, that I can bust that myth on a dyno on this engine, on this car. I'll bet anyone triple or nothing that I can cut the power in half on a motorcycle engine with the same size dents. (has to be the right motorcycle engine. I'm sure you could practically duplicate their results with a Harley motor, but I digress.) Your point about stock decatted headers is valid though. .
Inline 4 is best 4
There are many ways to displace. -Spartarus |
The Following 3 Users Say Thank You to Spartarus For This Useful Post: |
08-02-2016, 03:05 AM | #36 | |
I have a few arguments for your video critique and motorcycle comments, but I don't think they are necessary, and I'd rather not go off-topic too much. My point is above. |
The Following User Says Thank You to Irace86 For This Useful Post: | blues15dp (08-01-2017) |
08-02-2016, 06:00 AM | #37 |
Drives: 968
Does the harrop supercharger have a lubrication system?
08-02-2016, 10:35 AM | #38 | |
...Just add nauseum
Not counting the hero runs, I'm certain (from memory) the dyno numbers are very close together. It's been done here before - gutting the cat, that is. That all said, the area under the curve for a UEL vs EL header is distinctly different, and I think many experienced drivers could distinguish those in a deaf acceleration test, if they were paying close attention. But that's making significant changes to the layout of the header.
Inline 4 is best 4
The Following User Says Thank You to Spartarus For This Useful Post: | Irace86 (08-02-2016) |
08-02-2016, 06:21 PM | #39 |
Drives: Harrop TVS86 STi BRZ tS
Yes it does. All TVS systems have an internal lubrication system that is good for some 100,000 miles I believe? See the technical video on the first page for more details.
08-03-2016, 12:36 AM | #40 |
The Edelbrock video states the eforce supercharger has an integrated valve that bypasses the charger at low loads like on the highway so there is no parasitic loses to gas mileage. Is this common on most superchargers? If not, is it part of the Harrop kit? Gas mileage is not a big deal for me because my commute is just a few miles a day but some may care for this feature, and I'd like to know.
The Following User Says Thank You to Irace86 For This Useful Post: | djwishbone (08-03-2016) |
08-03-2016, 02:29 AM | #41 |
Drives: GTS86
I have had the Harrop S/C fitted by Harrop for only a week now, so i can only comment on initial impressions.
As shown in the videos it almost looks OEM N/A if it wasnt for the "Supercharged" lettering on the top of the unit, at least to those not knowing what to look for. In car there is zero whine, its completely stealth which avoids any unwanted attention which i am happy about. I went for the 90mm pulley (95mm was std), which i was told provides 10psi at 7000rpm approx. According to the dyno sheet provided i'm getting 280nm torque at 5000rpm through to 5750rpm and just under 180kw at 6750. For me, i am shifting at around 6000rpm which feels like its sweet spot, at least for traffic light take offs and general road fun. I have an auto trans with an Invidia Q300 catback and 45000klm of the clock, no other power train mods. I am lucky enough to live not far from the main Harrop plant so the decision to go with them was easy. As far as a company to deal with, i cant praise them highly enough, very professional and happy to answer my most basic questions. They even contacted me a few days after install to make sure i was happy with everything. Mileage seems to have suffered a little but that may just be a result of my now extremely heavy right foot. I have discovered that torque is a drug and i'm now an addict, so already considering the E85 upgrade. Cheers |
The Following User Says Thank You to Vulcan For This Useful Post: | CxG (04-26-2019) |
08-03-2016, 02:35 AM | #42 | |
Similar Threads | ||||
HKS Supercharger owners thread | wbradley | Forced Induction | 1048 | 10-12-2023 08:03 PM |
JDL turbo kit owners thread | yomny | Forced Induction | 1346 | 08-29-2023 11:07 PM |
P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 02:50 PM |
**Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
